Need some opinions
Discussion in 'Suspension' started by Joehs, Sep 17, 2010.
  1. Sep 17, 2010 at 8:25 AM
    Joehs
    Joehs [OP] Well-Known Member
    Joey
    AL
    Hey all,
    So here's where I stand right now. I drive a 08 DC SB 4x4. I have 5100's @ 2.5 with the stock coils, and a rear TSB. I'm alittle front high, but only by about half an inch. Recently, I've been considering swapping the 5100's out. With the springs pre-loaded at 2.5, the ride quality has suffered quite a bit, and overall, I'm just considering doing a full round upgrade and moving on to something a bit more "full".
    Here's a few options I've thought about, but I thought that the guru's here might have a bit more insight to the pro's and con's of each setup, at least more so than I have.
    I'm looking at maybe just swapping springs, to either the eibachs, or the OME lift coils. I don't really want to drop any lift height from what I've got now, and wouldn't mind increasing it a bit either, but nothing too substantial.
    Or, I've considered swapping out to the full OME front setup, and doing away with my 5100's.
    I'm also looking at the All-Pro 3" leaf pack to replace to rear TSB leafs, and a set of UCA's in order to fix the alignment problems I have right now.
    So, to summarize:
    Replace stock coils with OME/Eibach coils while retaining the same height, pick up an all-pro leaf pack, and a set of UCA's to fix alignment.
    or
    Go full OME front, with all pro leaf pack, and a new set of UCAs.
    Getting alittle less "rough" with the front is my ultimate goal, while maybe achieving a bit more lift in the process. I do light to moderate wheeling, but nothing intense.
    Which will yield the better end result? Opinions on which way you would go? Is there a better option for the money? Eventually, I'd like to squeak some 285/75/16's under the fenders, but that'll come after I fix all this stuff.
    Well, what do you all think?
  2. Sep 17, 2010 at 8:29 AM
    brutalguyracing
    brutalguyracing BIG DADDY
    F.U> GUYZ
    broken mods
  3. Sep 17, 2010 at 2:07 PM
    tacos
    tacos Well-Known Member
    Andrew
    NKY
    05 A/C Off Road 4x4
    BHLM,5100's set 2.5,Toytec 2" aal,FJ TRD wheels,AFE pro-dry, Duratracs
  4. Sep 20, 2010 at 8:21 AM
    Joehs
    Joey
    AL
    no opinions at all?
    I didn't get a "search newb" :(
    No love haha.
  5. Sep 20, 2010 at 8:24 AM
    brutalguyracing
    F.U> GUYZ
    broken mods
    go with ome springs and the 5100's
    and new leaf pack
    and l.r. uca
  6. Sep 20, 2010 at 8:29 AM
    JLee
    JLee The Man! Vendor
    Jerry
    Benicia, CA
    02 Extra cab SAS Linked front and rear
    I lost track thousands of dollars ago.
    I just put on the Eibach springs with 5100's and ride is awesome. I got 3" set at 0 on a 1st gen now I don't know if you will get 3" at 0 with a 2nd gen but you will like the ride. I think you can set the 2nd gen's to .85 with the Eibach's
