need some questions answered bout towing
Discussion in 'Towing' started by Big Al 55, Jun 13, 2011.
  1. Jun 13, 2011 at 4:52 AM
    Big Al 55
    Big Al 55 [OP] Member
    87 Pickup
    6,000 pound warn winch, grille guard, tow hitch, cb radio, after market radio, took out the bucket seats and put in brand new bench seat
    i drive a 1987 toyota pickup auto 4cylinder. it has an ect normal or power button on it. for one what does ect do? also, if im towing in 4wd low, should i leave the ect button on power or normal?
  2. Jun 13, 2011 at 5:41 AM
    skytower
    skytower Well-Known Member
    Dave
    virginia
    08 Tacoma 4x4
    Hitch and wiring, aux back-up light, rear strobe lights, radio and underseat sub.
    IIRC, that changes the transmission's shift points. Power=higher rev before shift and quicker downshift with less accel input. Normal= lower rev before shift and more accel input before downshift.
    Personal preference is the call of the day for that setting in 4lo.
  3. Jun 13, 2011 at 12:37 PM
    PR45
    PR45 Well-Known Member
    Los Angeles
    PreRunner SR5 4cyl
    Towing in 4 low? Not on asphalt I hope....
  4. Jun 13, 2011 at 1:29 PM
    Big Al 55
    87 Pickup
    if u have something heavy to tow u can tow it in 4low to keep the strain off the transmission
  5. Jun 13, 2011 at 1:38 PM
    macgyver
    macgyver Well-Known Member
    Brad
    Canton, GA
    '13 Tundra double cab SR5 4x4
    ONLY use 4Lo to get it out of the water and up the ramp. DO NOT turn the wheels and drive on dry pavement in 4LO, you run the risk of binding the drivetrain and grenading your T-case.
  6. Jun 13, 2011 at 1:49 PM
    OZ-T
    OZ-T You are going backwards
    Peter North
    British Columbia
    Uh , no
  7. Jun 13, 2011 at 2:18 PM
    PR45
    Los Angeles
    PreRunner SR5 4cyl
  8. Jul 3, 2011 at 5:06 AM
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    An "87" has manual lock hubs you can drive all you want in 4X4 as long as the hubs are not locked don't think I would take it out on the highway. Either normal or power you'll probably not notice the difference in low. What you do want is an transmission cooler in line with the stock one.
