Need some serious help/advice from you experts
Discussion in '2nd Gen. Tacomas (2005-2015)' started by dee_bo, Dec 6, 2009.
  1. Dec 6, 2009 at 10:33 PM
    dee_bo
    dee_bo [OP] Well-Known Member
    DFW
    2007 TRD Sport Tacoma
    None yet
    I just bought a used 2007 Tacoma TRD sport. I changed the oil, plugs, air filter and differential fluid. I'm just paranoid but there are a bunch of things going on now and I have no idea from what:
    1. After it rains and i press the brakes for the first 3-4 times they squeek loudly...is this normal or does it mean the pads are low?
    2. For the past week right after I start it and turn the wheel the first couple times the whole truck sort of vibrates and I can feel it on the steering wheel and even brake peddle. WTF is going on??
    3. Also today the engine seems to be idling very high on neutral...at 1000rpm. Don't recall it being that high before....is that normal?
    Please advised so my OCD doesn't get the best of me lol. Thanks
  2. Dec 6, 2009 at 10:34 PM
    Krazie Sj
    Krazie Sj Resident Jackass
    Power Serge
    LV-426 (Acheron)
    07 TRD Off Road 4x4
    Borla Catback Exhaust, Snorkel, 33s on either 16's or 18's, ARB Bumper, All Pro LT w/Walker Evan Shocks front and back, All Pro expedition leaf pack, 10,000lb Superwinch, Intake Manifold Spacer, Bed Rack with ARB RTT, Rotopack and Hi Lift mounted, Husky Liner mats and an air freshener from 1995.
    #1 I believe is normal.
    #2 Do you have 4x4 engaged on Dry hard ground?
    #3 Is it cold?
  3. Dec 6, 2009 at 10:40 PM
    dee_bo
    DFW
    None yet
    Thanks for the quick reply.
    It's not a 4x4. Just regular pavement. Only does it right after starting and for the first couple times I turn/brake. Sorta feel a vibration at the wheel and brake...not sure if it's the brake system or power steering.
  4. Dec 7, 2009 at 5:18 AM
    dee_bo
    DFW
    None yet
    Well it did the vibration thing again this am. Any suggestions....is it something potentially serious?
  5. Dec 7, 2009 at 6:18 AM
    Asgard
    Asgard Well-Known Member
    06 PreRunner DC SR5 w/LSD
    ^^Did you use the LSD additive in your diff ? What type of oil did you put in ? Sounds like your rear diff gears are binding.
  6. Dec 7, 2009 at 9:23 AM
    dee_bo
    DFW
    None yet
    No I did not use additive but used Valvoline which stated is was good for LSD vehicles. This only usually happens when the vehicle is cold and I have figure out with turning the wheel only. Why would it be the differential...but then again I have no idea what i'm talking about lol. Thoughts are appreciated.
  7. Dec 7, 2009 at 9:37 AM
    Asgard
  8. Dec 7, 2009 at 9:39 AM
    dee_bo
    DFW
    None yet
    THanks I used 75w-90 which is the recommended type. I will check out that thread again. Can someone please comment if I it could be the LSD that's acting up and causing to truck to vibrate for only a few turns when cold and then clears right up. Thanks
  9. Dec 7, 2009 at 10:04 AM
    dorkman
    dorkman Well-Known Member
    Some have had issues with 75/90 in the rear. I used Valvoline 80/90 Durablend and have not had any problems, with NO additional modifiers (2008 TRD Sport). You can probably buy a tube of Friction Modifiers to add, or drain and refill to see. Go with 80/90 in the rear.
  10. Dec 7, 2009 at 10:08 AM
    brian
    brian Another Traitor
    Elizabeth City, NC
    2017 F-250 Powerstroke
    idiot reply, misread something.
  11. Dec 7, 2009 at 10:12 AM
    USNROBERTS
    USNROBERTS Well-Known Member
    Jacksonville, FL
    06 PRERUNNER SR5 TRD SPORT
    Did you ensure you filled it full? Did you overfill?
    If no engine lights are coming on it I'd like to think its nothing major. Idle at 1k is not normal but you have to let the engine warm up good before you know for sure. Im at almost 90k now and Ive found that when first warming up the engine it is loud compared to other vehicles. But i think its because it breaks the silence of the morning ect.
