Need to borrow a spanner wrench please!!
Discussion in 'North West' started by YFZ450MOE, Jun 12, 2012.
  1. Jun 12, 2012 at 3:16 PM
    YFZ450MOE
    YFZ450MOE [OP] When you blow off steam you get an eyepatch
    Moe
    Auburn, WA / Roseburg, OR
    09 white DCSB TRD (it's getting there)
    Icon Extended Travel 2.5" Coil Overs All-Pro U-Bolt Flip Kit Bilstien Rear Shocks Fabtech Add-a-Leaf Icon Upper Control Arms All-Pro Rear Bumper w/ Wrap Arounds & Hitch with custom LED plate light BHLM and Morimoto III D2S retrofit Satoshi Grill 2 Hella Black Magics behind Grill Bestop Supertop BAMF sliders
    So I threw on some icon shocks and uca's then my new tires. I had the tires on my old taco set at about 2.5-3" of lift and the icons come preloaded at 2" without a spanner. So I was wondering if a very nice person local to the Seattle/auburn area could help me out and let me borrow a wrench so I can drive my truck. The tires rub way to much and I can't hardly turn! I would only need it for a day and you can be there while I do it or I can return to your house when done. I'll even Pay a rental fee for your generosity!
    Thanks for reading
    Moe
  2. Jun 13, 2012 at 9:44 AM
    korslite
    korslite Well-Known Member
    Justin
    Bellingham, WA
    DCLB Sport
    FOX 2.5 RR's, TC UCAs, TC Spindle Gussets, Allpro Expedition leaf pack, Fox 2.O RR w/ Comp adjusters, 17" ATX Artillery, BFG AT 285's, de-scooped, custom sliders, custom bedrack, Brute Force Fab bumpers, Smittybilt XRC8 winch, ARB locked Rear diff
    I would recommend buying a screwdriver with the appropriate diameter shaft on it (#3 phillips for FOX CO's) and cutting the end off to substitute for a spanner. This has worked great for me and i actually prefer it over a spanner wrench because it gives you a lot more leverage and gets your hand out away from the UCA and coilover and everything else in the way. Just my .02, hope it helps...
  3. Jun 13, 2012 at 9:47 AM
    korslite
    Justin
    Bellingham, WA
    DCLB Sport
    Stolen from elsewhere on TW...
  4. Jun 13, 2012 at 9:50 AM
    chadderkdawg
    chadderkdawg Don't ask questions you don't want the answer to..
    Des Moines, Iowa
    09 FX4 F150
    Or you could just use a 1/4 inch punch, or whatever size it needs. 1/4 inch punch worked for my Walker Evans'
  5. Jun 13, 2012 at 3:07 PM
    YFZ450MOE
    Moe
    Dam good thinking sir! I actually ended up using a small deep well socket that fit really good then put an extension on it. Thanks for the input tho. Another great idea
  6. Jun 13, 2012 at 3:50 PM
    korslite
    Justin
    Bellingham, WA
    DCLB Sport
    I can't take credit for the idea thats for sure, thank you Google and TW back when i put CO's on my truck! :D
