Need to buy a Spare
Discussion in 'Wheels & Tires' started by StaticFilter, Jan 10, 2012.
  1. Jan 10, 2012 at 3:26 PM
    StaticFilter
    StaticFilter [OP] Well-Known Member
    Cedar Hills, UT
    2008 Blue FJ Cruiser
    Lifted, N-Fab steps, Roof rack light bar, Grill guard, Volant Snorkel (not installed ye)
    I need to get a spare for my truck, I don't know anything about my current 15" wheels (backspacing or width) Do I need this info to match up a spare? Or can I grab any matching lugged 15" rim/wheel with a 33" tire and be GTG?
  2. Jan 10, 2012 at 4:51 PM
    KPT
    KPT sees what you did there.
    09 Prerunner
    You'll want backspacing of 4.5 or less. 4.5" is your stock backspacing, and since you are running a 33 you are likely wider than stock.
  3. Jan 10, 2012 at 4:57 PM
    hetkind
    hetkind Well-Known Member
    Howard
    Johnson City
    2011 SR5 Access Cab, white with Leer Cap
    bilstein set at 1.75, Racho 5000 rear with 4 leaf kit, floor mats, high lift jack, pull hook in hitch, bed rail corner braces, severe duty brake pads and devil horns on the grill....
    Just swing by your local tire shop and tell them you want a spare, rim and tire to fit. They will measure what you have and provide suggestions.
    Or, just go to a junkyard...they should be able to match you a rim up, and perhaps a tire also.
    Howard
  4. Jan 10, 2012 at 8:57 PM
    StaticFilter
    Cedar Hills, UT
    Thanks guys, I guess going to a shop would be the easy route, and they probably wouldn't even charge me anything for the info eh?
    I don't want anything new or fancy, just need a reliable spare with some tread left for a "just in case"
  5. Jan 10, 2012 at 10:17 PM
    StaticFilter
    Cedar Hills, UT
    Oh, and I don't suppose the 16x7 or 17x8.5 wheels i already have sitting around would work since my wheels are 15s...? What would happen if i had a different sized wheel for my spare but the same size tire? (3x) 33x12.5R15 and (1x) 33x12.5R16 or R17 for spare
  6. Jan 11, 2012 at 5:59 AM
    KPT
    09 Prerunner
    It would make no difference, as long as you keep the overall diamter of the tire the same. I have 18" rims and a 16" spare.
  7. Jan 12, 2012 at 8:23 PM
    StaticFilter
    Cedar Hills, UT
    So running 33x12.50R15, which of these will be my better option?
    16" wheel is 7" wide
    255/85R16 = 33x10.04R16
    or
    17" wheel is 9" wide
    305/65R17 = 33x12.01R17
  8. Jan 13, 2012 at 5:51 AM
    KPT
    09 Prerunner
    Whichever you prefer.
