Need to change my battery
Discussion in '2nd Gen. Tacomas (2005-2015)' started by reznor, Dec 18, 2014.
  1. Dec 18, 2014 at 5:45 AM
    reznor
    reznor [OP] Well-Known Member
    Hi guys,
    I need to change my battery on my 2010 Tacoma (v6).
    What are the minimal specs af amps required for the truck?
    And what do you suggest for the number of amps requireds on cold crank start.
    I live in Quebec, so we have tough Winters :)
    Thanks.
  2. Dec 18, 2014 at 5:56 AM
    357sig
    357sig Donut king
    dough boy
    donut shop
    Gold digger
    Go to all the stores and find the one with the most cold cranking amps. Done.
  3. Dec 18, 2014 at 7:04 AM
    dilligaff82
    dilligaff82 Well-Known Member
    New Hampshire
    2014 TRD Off Road DCSB
    When my OEM battery fails (assuming I still have the truck by then) I'll be replacing it with Interstate. I've always been impressed by how well they hold up to heavy use, abuse, and neglect. I forked over the cash for an optima once and it was junk within 2 years.
    Now let the circle jerking begin....
  4. Dec 18, 2014 at 7:20 AM
    savedone
    savedone Well-Known Member
    Gerald
    Texas
    TRD off-road 6speed manual
    3 inch lift by dealer at purchase
    If the old Battery started your truck in the winter put the same amp hour back into it. ;)
  5. Dec 18, 2014 at 7:20 AM
    Crosis
    Crosis Tertiary adjunct to unimatrix 01
    Dunedin Fl
    09 Tacoma 4x4 TRD Off Road
    I have an Optima yellow top in my Corvette. The vette owners in the forums swear by those things. I had a red top and it shit the bed in 1 year. I am using the yellow top now but it stays on the tender so its tough to say if its really a good battery under normal use. I have my doubts. I definitely would not consider it for the harsh winters of Quebec. Think about a deep cycle battery.
  6. Dec 18, 2014 at 7:31 AM
    Sig45
    Sig45 Well-Known Member
    Mark
    Maine
  7. Dec 18, 2014 at 7:41 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    I would definitely not want a deep cycle battery for cold starts. Generally, deep cycle batteries don't have a lot of CCA. I had a yellow top also, and it did well enough for me, but unless you have higher electrical loads, there's no real benefit for running a deep cycle battery on a daily driver with normal electrical loads.
  8. Dec 18, 2014 at 7:48 AM
    33yrsoftoys
    33yrsoftoys Over 40yrs now
    joel
    mid Michigan
    2021 dcsb off road 6 speed manual
    Bilstein 6112's 5th clip 1/4" spacer driver's side. Icon tubular UCA's with Delta joint, wheelers superbumps, ECGS bushing. Allpro standard leaf packs, 5160's, U bolt flip kit with wheelers super bump's, extended stainless steel brake lines, carrier bearing drop. Icon rebounds 17" with Nitto terra grappler G2's 285/70/17's.
    Hey OP, whatever you decide on an battery, make sure you run an external battery power source to your truck so your truck doesn't loose electrical power while your changing the battery. If you don't, it will reset the ecu back to factory settings. It takes many cold starts and driving for the ecu to (get used to you) again. Mpg's will suffer, in my experience.:)
  9. Dec 18, 2014 at 7:59 AM
    127.0.0.1 AKA ::1
    /etc/hosts
    2013 NBM AC 4.0 4x4 Auto OR
    two words
    block heater
  10. Dec 18, 2014 at 8:43 AM
    LUSETACO
    LUSETACO Here for the Taco Pron
    Dennis
    South Central Pee A
    2005 PIMP MOBILE
    Yes
    Sears Diehard Platinum.
  11. Dec 18, 2014 at 9:54 AM
    dilligaff82
    New Hampshire
    The red top is the one that crapped out on me too.
  12. Dec 18, 2014 at 10:29 AM
    reznor
    I do have a memory saver with a 9v battery. Is that enough ?
  13. Dec 18, 2014 at 10:34 AM
    Mr Salty
    Mr Salty "Give up the good to go for the great"
    Hermmy
    SoCal (Bro Capital of the world)
    White SR5 Pre-runner
    Lots of chrome
    Got mine at Costco
  14. Dec 18, 2014 at 5:58 PM
    33yrsoftoys
    joel
    mid Michigan
    Hey OP, is doesn't take much to keep the ecu (set?). Most places you would buy batteries will do this at no charge. That's what I would do.
    As far as the ecu reset and mpg's are concerned, a block heater won't help. I did it in warm weather and still had a mpg loss. It does come back though, as I said, it takes time. Toyota's have an ambient air sensor, that's one reason, among many, that contributes to poor mpg's in the Tacoma's in cold weather. But,,, that's another story!!!;)
  15. Dec 18, 2014 at 6:47 PM
    savedone
    Gerald
    Texas
  16. Dec 18, 2014 at 6:49 PM
    reznor
    Got a new battery tonight. But I got another issue. My bracket won't fit on it. I mean, the battery cover is a little cabered. The result : The bracket doesn't fit perfectly wich make the front stem a little bit to short to fix it on the bracket properly ?
    Is this possible to buy new bracke with stem? Or just finding a longer stem (even if the bracket doesn't fit perfectly on the battery cover) Other?
  17. Dec 18, 2014 at 6:57 PM
    33yrsoftoys
    joel
    mid Michigan
    Hey Gerald, your on a right track. The fact is the Tacoma's ecu reacts ( very richly;)) to cold ambient temps. That's why, across this site and others, the frustration with cold weather mpg's. If you watch, mpg (fussing), lessens in warm months, for the most part. It is in the ECU's setup. That's why I said the winter (bra):), is on the right track.;)
  18. Dec 20, 2014 at 12:51 PM
    Shadetree
    Shadetree Well-Known Member
    BiLL
    Bozeman, Montana
    2011 Access Cab 4x2
    Locking Tailgate & Gas Cap and extra bed D-rings
    580 CCA minimum. If the cigarette lighter socket is alway on, I use nine-volt "memory saver" whenever I change a battery.
  19. Dec 20, 2014 at 1:01 PM
    Juggernaut
    Juggernaut Captain
    Sacramento
    25 TRD OffRoad DCSB
    Winter gas also contains less energy, so you go less miles on a gallon.;)
    And I'll also throw in my vote for the Costco battery.
  20. Dec 20, 2014 at 1:04 PM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    I'm leaning toward the Odyssey PC-1500 with the adapter that fits it to the Group 27 tray
    All the Canadian 6 lugs have the tow package and the Group 27F battery
