Need to change out original spark plugs
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Medic4x4, Jan 8, 2020.
  1. Jan 8, 2020 at 2:21 PM
    Medic4x4
    Medic4x4 [OP] Member
    2012 Silver Tacoma 4x4 TRD
    ARE brand Fiberglass shell
    I have a 2012 4x4 Tacoma with 4.0 L 6 cyl. engine, and 73K miles. Current Spark plugs are original, but I plan to replace them myself. Dealer quoted me $227 to replace them. Please provide advice on the best recommended replacement spark plugs for my truck. The dealer parts department recommended plugs that were the OEM standard type at $3.98 each with a service life of 30K miles. Should I stick to the original OEM plugs?
    Thanks in advance for your help.
  2. Jan 8, 2020 at 2:31 PM
    rnish
    rnish Well-Known Member
    Tacoma 2nd gen
    Yes I went with stock Denso’s.
  3. Jan 8, 2020 at 2:33 PM
    IL Capo
    IL Capo Well-Known Member
    Sidney BC Canada
    You might get varying answers to your question about sparkplug choice....With that being said I went with the OEM plugs from the dealer given they meet manufacture's specifications and the price was unbelievable and unbeatable. You might want to change out the PCV valve when you're at it....its easy to do when you change out the plugs.
    Check out some of the other forums here at TW on the suggested way to tackle this project...have fun and enjoy.
  4. Jan 8, 2020 at 2:33 PM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    Toyota OEM denso plugs /thread
  5. Jan 8, 2020 at 2:34 PM
    Sig45
    Sig45 Well-Known Member
    Mark
    Maine
    OEM
  6. Jan 8, 2020 at 2:36 PM
    WoodyWagon
    WoodyWagon WoodyWagon
    Langhorne, Pennsylvania
    2009 TRD OffRoad Access Cab
    You drove 73K with OEM spark plugs. What makes you think you cannot go at least 50K on the OEM standard type for 4 bucks apiece? Spend the $16 and do it yourself. Easy.
  7. Jan 8, 2020 at 2:37 PM
    WoodyWagon
    I meant $24
  8. Jan 8, 2020 at 2:40 PM
    SByota
    SByota Active Member
    I went with Denso #3421 iridium long life. If I remember they were mostly all gapped perfectly out of the box. May have had to adjust one of them, this was 2 years ago though so not 100% sure.
  9. Jan 8, 2020 at 2:47 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
  10. Jan 8, 2020 at 2:53 PM
    Rick's 2012
    Rick's 2012 Well-Known Member
    Rick
    Costa Rica
    2012 Double Cab 4x4 Grey with leather
    Stock
    I went with OEM Denso's !!!!
  11. Jan 8, 2020 at 3:10 PM
    08TacoTrD
    08TacoTrD Well-Known Member
    08 TRD Offroad
  12. Jan 8, 2020 at 3:59 PM
    TexasWhiteIce
    TexasWhiteIce Well-Known Member
    Texas
    2022 White DCLB SR5 - Blackout
    70k is about right for spark plug change. 30k is overkill. Stick with what the parts department sells. It’s cheap enough.
  13. Jan 8, 2020 at 11:08 PM
    Waasheem
    Waasheem
    2007 xrunner
    I used oem densos.
    Look for a thread titled spark plugs anti seize something something. Seems everyone has their own right way to do it. Torque to 13 ft lb. Use anti seize. Don’t use anti seize. Tighten 1/4 turn after the washer contacts.
    I like to center AND gap the new plugs to the closer end of the spec. Sometimes the hook isn’t centered, a wrench and pliers to slightly twist it gets it centered. Put anti seize on them, if the head is aluminum definitely don’t skip this step. Put them in tight without a torque wrench. Never had issues doing it like that except if the guy before me didn’t use anti seize. But doing a helicoil repair on a spark plug hole isn’t too difficult. Trying to find a helicoil kit when you need the vehicle to get to work tomorrow can suck.
    There’s a video that explains exactly step by step how to change your plugs. Getting at one on the driver side that’s buried, the video definitely helped.
  14. Jan 9, 2020 at 3:19 AM
    Wattapunk
    Wattapunk Stay lifted my friends !
    Uncle K
    TX
    2005 DCLB 4WD
    Like others have stated, go with Denso's. Little more involve than a simple Honda accord level but still easy to do. Follow link posted by 08TacoTRD above.
  15. Jan 9, 2020 at 3:43 AM
    Blue92
    Blue92 Well-Known Member
    Daniel
    North Carolina
    2018 Sport
    Oem. But you dont have to buy them through the dealer. The part numbers for NGK and denso plugs should be listed in the back of your owners manual. Just buy em at Napa or wherever and save a few bucks.
  16. Jan 9, 2020 at 5:19 AM
    wags
    wags Well-Known Member
    Walleye Capital of the World, Ohio
    2012 2.7L 5-Speed Manual SR5 4x4
    OEM Denso.
  17. Jan 9, 2020 at 6:13 AM
    WebberLander
    WebberLander Well-Known Member
    Mark
    Colorado
    2011 SR5 4x4
    Overlanding Rig
    OEM Denso/NGK.
    As others have stated, don't buy them through a dealer as you'll pay their markup price. I was lucky a few years back and found a member on here selling a whole case (several spark plug changes worth) for a great deal.
  18. Jan 9, 2020 at 6:42 AM
    Armed in Utah
    Armed in Utah Well-Known Member
    Utah's High Desert.......
    2003 Lexus LX 470
    why......if I heard this guy right.....he went 700K miles on original plugs
  19. Jan 9, 2020 at 6:43 AM
    EdgemanVA
    EdgemanVA Well-Known Member
    Virginia Beach
    2008 X-Runner
    Several
    Or a even better option is to get the Toyota part number, then plug that into a search on Amazon. It's very likely you'll end up buying from a Toyota dealer, and a much cheaper price than what you'll pay if you walk up to the parts counter.
