Need to haul more
Discussion in '1st Gen. Tacomas (1995-2004)' started by Razorbil, Jan 6, 2010.
  1. Jan 6, 2010 at 6:16 PM
    Razorbil
    Razorbil [OP] Member
    1998 Toyota Base 2.4 liter
    I have a 1998 Taco, Base, 2.4 liter. I need to haul firewood (in the bed, not in a trailer). I have recently found that that the OEM shocks are not adequate for heavy loads. Does anyone have any ideas on increasing my hauling capabilities? Coil-over shocks or leaf spring helpers? I have searched for coil-overs and have had zero luck.
    Thanks for the help.
  2. Jan 6, 2010 at 6:19 PM
    Brunes
    Brunes abides.
    Rotorhead
    Get a fullsize truck or a trailer....Adding stuff to the suspension doesn't mean that it can handle more weight.
    My guess is your full load of firewood was at or above the max payload for your rig...
  3. Jan 7, 2010 at 3:59 AM
    Razorbil
    Thanks for the info. I might have to do just that; switch to a trailer instead of relying on the truck bed.
  4. Jan 7, 2010 at 5:14 AM
    Afwrestler1986
    Afwrestler1986 Well-Known Member
    Johnstown, NY
    01 trd 4X4 ex cab manual
    Gray wire, Some lights in the bed area, and some character marks throughout.
  5. Jan 7, 2010 at 5:19 AM
    Brunes
    Brunes abides.
    Rotorhead
    And a stronger axle, and upgraded brakes, and a reinforced drive train. You can't just add a little bit of stuff and then go over the max cargo capacity on a regular basis. It sounded like the OP is using this to move wood regularly (like a daily job or regular side gig).
    Trailer is the way to go- TONS more capacity.
  6. Jan 7, 2010 at 5:37 AM
    Afwrestler1986
    Johnstown, NY
    I took it as he needed to haul a fair amount of weight, but not too often.
    If you are going to do this a lot, then yes, absolutely get a trailer. And if it is a lot of weight you will want to have brake helpers.
  7. Jan 7, 2010 at 5:59 AM
    yotarob2005
    yotarob2005 Kiss My IFS
    Rob
    Bryan , Tx
    05 D-cab trd sport long bed
    Front Bilstien 5100's Set @ 1.75", rear 5100's & TSB springs, Flowmaster, TRD seat covers, Toyota All weather floor mats, 265/70-17 Michelin LTX AT2's, some Debadgeding, BHLM, led bed lights, 886 back up lights, fog lights anytime mod, Extra d-rings, Toyota bed mat, sockmoney TRD decals, Kenwood 890DNX, Firestone ride-rite air bags, 2 car seats.
    I would just recomend hauling several smaller loads instead of 1 big load.
  8. Jan 7, 2010 at 12:13 PM
    Razorbil
    Yep, this is long term, often hauling, kinda job.
  9. Jan 7, 2010 at 12:38 PM
    Brunes
    Brunes abides.
    Rotorhead
    Yeah man...Keep your eye on craigslist and pick up a trailer that needs a little TLC for cheap.
    You'll be far more effective as a hauler and you'll be safer.
