Need to move 3 sleds
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 09toyotacoma, Dec 9, 2010.
  1. Dec 9, 2010 at 8:38 AM
    09toyotacoma
    09toyotacoma [OP] Active Member
    NY
    09 4cyl 5spd 4x4 access cab
    me and 2 friends want to head north and go snowmobiling. I have one problem though, 3 sleds, 1 truck, 1 2 sled trailer. Does anyone know if i put one in the bed if i will be able to still pull the trailer? I know the sleds tend to hang off quite a bit. Any help is appreciated
  2. Dec 9, 2010 at 8:43 AM
    09toyotacoma
    NY
    i forgot to mention i have a 6 foot bed
  3. Dec 9, 2010 at 8:45 AM
    wiscdave
    wiscdave Lets Do It!
    Northern Wisconsin
    Tundra Rock Warrior
    Past ride - 3" OME 885s&Shocks/ TSB 1.5AAL/ AX184 Rims 285 Firestone destination ATs/ 2 Shallow mount P310s in Supercrew Box - Punch 601s, Beefed up Hunter Brush guard, Tint, Fog light mod, AFE Drop in, AC and Fog light mods, scangauge
    yeah you should be fine if you clear the trailer on tight corners with the tailgate down, if not tail gate up and track sits on that. Does it have a salt shield or touge jack..watch for that other wise no prob
  4. Dec 9, 2010 at 8:45 AM
    Di Trut
    Di Trut Well-Known Member
    Just close the tailgate and have the ass of the sled stick up in the air. Then the sled hanging off the back shouldn't interfere with the sled trailer.
    Plus this way the sled is better secured, and better for your tailgate too.
  5. Dec 9, 2010 at 8:46 AM
    98tacoma27
    Ben
    Not Beech Creek
    Will the tailgate be down? Depending on the type/build of trailer, the trialer jack handle may hit the tailgate when turning.
  6. Dec 9, 2010 at 9:28 AM
    motoxer311
    motoxer311 Well-Known Member
    Jacksonville, FL
    Take the tailgate off, no need for it to be on with a sled in the back.. I use to mess my tailgate up every time I would put the sled in the back or take it out.. The ramp I used wasn't the best though..
  7. Dec 9, 2010 at 9:35 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    x2. If you need a little extra length you can put a piece of plywood in the bed and use a block of wood to step it down so it's supported by the bumper. If it clears with the tailgate down, great but make sure you check it really well, if you corner tight or if the jack hits the tailgate it causes a lot of damage in a hurry.
  8. Dec 9, 2010 at 10:04 AM
    Di Trut
    If you take the tailgate off though, how are you supposed to keep your gear in the bed of the truck?
    best scenario is to travel with the tailgate up. I've done it many times, with and without a trailer. Never a problem.
  9. Dec 9, 2010 at 10:13 AM
    Pugga
    Massachusetts
    Same way as with the tailgate down... bungee cord and tie down straps. You should secure your stuff even with the taligate up.
  10. Dec 9, 2010 at 10:27 AM
    Di Trut
    not how i would do it, but thats fine.
    why not have the tailgate too though? sled is better secured with it on, and it definitely won't get eaten by your trailer.
  11. Dec 9, 2010 at 10:33 AM
    Pugga
    Massachusetts
    Completely depends on the trailer. Read my whole post, I said if it clears then fine but some trailers will hit the tailgate if you crank it over tight in a turn or the jack handles can hit the tailgate if you hit an incline. You can't make the blanket statement that all trailers are fine with the tailgate down just because yours works.
  12. Dec 9, 2010 at 10:37 AM
    Di Trut
    you should read mine closer, i suggested putting the tailgate UP. so the tailgate is definitely out of the way, and the ass of the sled will be farther away from the trailer than if it was down.
    Plus your gear is safer in the back, and the sled is better secured.
  13. Dec 9, 2010 at 10:43 AM
    Simon's Mom
    Judy or Jude :)
    NEK Island Pond VT
    24 Tundra Trd Sport former 13 TRD OR
    Stock for now
    Its definately doable! Tailgate up.
    Where are you going?
    Make sure to come back with pics! We have a snowmobiling thread. :woot:
    Our season starts next week.
  14. Dec 9, 2010 at 11:02 AM
    Pugga
    Massachusetts
    Gotcha, I thought you were talking about traveling with the tailgate down and the sled hanging off the back. My bad, you're method would work well. :thumbsup:
