Need to replace AC belt
Discussion in '1st Gen. Tacomas (1995-2004)' started by ywen, Jan 19, 2010.
  1. Jan 19, 2010 at 12:57 PM
    ywen
    ywen [OP] Well-Known Member
    Belt makes chirpy noise when at idle.. sprayed some belt dressing and the noise immediately went away.
    At this point, it's either a loose belt or need a new belt.
    How difficult is either to do? Should I try to tighten it a bit?
    How much would it cost to get the belt replaced at a shop?
    EDIT: I have teh 3.4L
  2. Jan 19, 2010 at 1:08 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    What engine do you have?
  3. Jan 19, 2010 at 1:10 PM
    mixaro
    mixaro Well-Known Member
    maine
    02 tacoma ext cab, 2011 trail edition 4 runner, 2013 tx baja dcsb
    02 ext cab cat-back exhaust, k&n replacement filter, 5100 billy's, hellcreek 1.5" rear spring packs, 882 OME coils, Toytec 2" AAl, stainless brake lines, Light Racing UCA, 1" diff drop, BPV bracket, 4" deck plate mod, 886 fog light backup light mod, tom woods one piece drive shaft, spider trax 1.25 spacer.
    replacing and tightening the belt are both pretty easy. the determing factor on either tightening or replacing is how many miles are on your belt now. if it's a bit of miles might as well change it, but if you're going to do that you should probably change the other belt too. if i can remember right there are tensioners on the ac pump and the power steering pump. when i did it i think i paid $30 for both belts and it took me maybe 30 minutes to change them both
  4. Jan 19, 2010 at 1:15 PM
    Afwrestler1986
    Afwrestler1986 Well-Known Member
    Johnstown, NY
    01 trd 4X4 ex cab manual
    Gray wire, Some lights in the bed area, and some character marks throughout.
    If you have the V6 it can go pretty quickly. I can change all three belts in about 30 minutes or so. It is best to take the airbox out to reach the power steering pump tensioner. the AC belt is super simple, just loosen the face nut on the idler pulley and then loosen the bolt just under the pulley. And the alternator belt is easy as well. Loosen the top most bolt on the alternator, the nut on the tensioner assembly, and then loosen the tensioner bolt.
  5. Jan 19, 2010 at 1:26 PM
    ywen
    When checking belt tension or replacing belt, how are you guys determing the tension after you put on the new belt? Do I really need one of those $100+ belt tension measuring device that's mentioned in the service manual?
  6. Jan 19, 2010 at 4:55 PM
    mixaro
    maine
    i don't have one i've used one but personally i think that they are a waste of money. i usually get the belts in and using my thumb i push the belt down so i get roughly 1/2" tops of play on them.
  7. Jan 19, 2010 at 5:00 PM
    Afwrestler1986
    Johnstown, NY
    Yes, no more than 1/2" of play. Basically you will be able to know when you have tension enough. You don't need that fancy tool crap. (For this job anyways)
  8. Jan 19, 2010 at 7:35 PM
    ywen
    But the amount of play depends on what part of the open span you are pushing.. the larger the span, the more play there is...
    So are you guys pushing the top part of the belt, right behind the fan?
    Also, is there a DIY writeup for belt changing on the 3400? I couldn't find it.. ThX!
  9. Jan 20, 2010 at 4:42 AM
    Afwrestler1986
    Johnstown, NY
    From the longest span on each belt. Like I said, you will know. You want it tight, but not torqued down. If there is i write-up I don't know whare it is.
    Once you get the airbox out of there you can get at everything a lot better. And you are probably going to have to remove the skidplate.(mine is gone so I don't remember for sure). The power steering pump has one nut to loosen and then you do the tensioner bold. The alternator has one nut and one bolt to loosen before you can release the tension with the tensioner bolt. And the AC has one nut and then you loosen the bolt and the whole pully will raise and release the tension. Just Don't put the power steering belt onto the alternator because you will get all the way to the PS pump and realize you screwed up and have to do it all over again. Upside is that you will be able to do it with your eyes closed next time.
