Need to siphon gas out of my 2015 Tacoma to run generator down here in Florida. I have a hand pump.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Power63, Oct 11, 2024.
  1. Oct 11, 2024 at 10:15 AM
    Power63
    Power63 [OP] Member
    Anything I need to know beforehand?
    HondaGM likes this.
  2. Oct 11, 2024 at 10:23 AM
    50Buck
    50Buck Living rent free Timmy the Tool's head
    2025 Tundra Crew Max
    There are anti-siphon measures on all modern vehicles. You may have to drop the tank to be able to get a clear shot at the fuel.
    Pure guessing on my part. Someone more knowledgeable may have better info.
    That aside, I hope you and your loved ones are safe.
    spitdog, HondaGM, Dm93 and 1 other person like this.
  3. Oct 11, 2024 at 10:29 AM
    SH10151
    SH10151 Farang
    SF Bay Area
    2022 SR AC UP 4x4
    You would have to drop the tank.
    50Buck and HondaGM like this.
  4. Oct 11, 2024 at 10:34 AM
    spitdog
    spitdog Well-Known Member
    2015 Access Cab V6 4x4 SR5 MGM
    Like others have said. There’s a check valve in the tube. It’s there to prevent fuel from sloshing out in a rollover or such. But I have read you might me able to sneak a skinny vinyl tube down.
  5. Oct 11, 2024 at 10:36 AM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    Yea, unlikely you will be able to get a hose down the filler.
    Easiest way to get gas out probably is gona be to unhook the fuel feed line under the hood (careful as there may be residual pressure on it), connect a hose to the line from the tank, jump pins 3 & 5 of the C/OPN relay, and turn the key on to run the pump.
  6. Oct 11, 2024 at 11:02 AM
    Musubi3
    Musubi3 Well-Known Member
    Big Island
    2014 Tacoma DC 4x4 TRD Off Road, Supercharged
    Similar to Dm93's post above, you can check out this thread:
    https://www.tacomaworld.com/threads/draining-fuel-from-tank.778962/
    It will at least show you where the fuel lines are since they're in a similar location in a 6 cyl.
    I tried using an inline hand pump, which did work, but very slow. Too slow for me, so I hooked up my gas transfer pump and it became hands free.
  7. Oct 11, 2024 at 11:25 AM
    RLMoody
    RLMoody Well-Known Member
    2017 Toyota Tacoma SR
    Let others chime in before you do this but my brother who lives near Asheville NC and lost power for 5 days disconnected his fuel line on the carburetor on his 83 Trans Am and cranked the engine. The submersible fuel pump pumped the gas he needed into a gas can he had. He was running his campers small generator to power the refrigerator in the house. I wasn't there to see this but he said it beat the hell out of his other options. Before anyone asks the fuel injection set up is history on his car. He converted it to a 4 barrel carb set up. All the gas stations were closed with no electricity to operate the pumps.
    Can this be done with fuel injection? I see that mentioned above.
  8. Oct 11, 2024 at 11:31 AM
    RLMoody
    Don't smoke while doing anything like that. My brother in laws buddy stuck his face in the carburetor of the car they were priming and trying to start. Forgot about the cigarette in his mouth. His eyebrows and hair grew back.
    Steves104x4 likes this.
  9. Oct 11, 2024 at 11:36 AM
    SH10151
    SH10151 Farang
    SF Bay Area
    2022 SR AC UP 4x4
    Just keep in mind the amount of fuel the fuel pump is designed to deliver to the engine is microscopic compared to the amount of fuel he wants to get out of the tank.
  10. Oct 11, 2024 at 11:45 AM
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    They pump fast enough (1-2 gpm) to empty the tank pretty quick.
    If I have the ability to easily run the pump that's how I drain them at work all the time when I have to drop the tank.
    Steves104x4 and SH10151[QUOTED] like this.
  11. Oct 11, 2024 at 11:46 AM
    spitdog
  12. Oct 11, 2024 at 11:54 AM
    Sandman614
    Tim
    Garner, NC/Boone, NC
    '06 SR5 Off Road
    Ask your local tweaker?
  13. Oct 11, 2024 at 12:13 PM
    SH10151
    SH10151 Farang
    SF Bay Area
    2022 SR AC UP 4x4
    You’re still gonna be there for at least half an hour. I remember troubleshooting the fuel pump on my 80 series and it’s kind of a trickle. If that’s your only option though, it’s not the worst thing.
  14. Oct 11, 2024 at 1:43 PM
    TacoTuesday1
    FL
    If people put locking gas caps to stop siphoning on these trucks then it should be siphonable.
    the amount of new cars I have had to drain fuel at work for repair is many
    Using a pocket screwdriver. To depress the “anti” thing. To get my hose back out. Where the official tool uses a hose.
    joeyv141 likes this.
  15. Oct 11, 2024 at 1:57 PM
    joeyv141
    joeyv141 Well-Known Member
    New Jersey
    08 DCLB 4x4 V6 TRD Sport
    You can get around the anti siphon flap, you'll need small fuel hose for like a generator, mower, scooter to get to the gas though so it'll be slow going to get a gallon but once its flowing your good to go.
  16. Oct 11, 2024 at 5:02 PM
    ridefreak
    ridefreak Well-Known Member
    NM
    2006 DCSB TRD
    minor tweaks
    You'd be surprised how quick it will come out. When it's running the majority of fuel being pumped out of the tank is being shunted back to the tank through the pressure relief valve, stick the hose in a can with no backpressure and a 40psi pump will move some liquid.
    SH10151[QUOTED] and koditten like this.
  17. Oct 11, 2024 at 5:18 PM
    ABA180
    ABA180 It burns when I pee....
    East Bridgewater MA
    Pioneer CD, Megaloud/JBL amps, Rockford/Polk speakers.
    Oh yikes, I remember that setup..the Cross-Fire injection
