Need to upgrade brakes and rotors that wont warp
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TheBlackPearl, May 22, 2011.
  1. May 22, 2011 at 1:33 AM
    TheBlackPearl
    TheBlackPearl [OP] Well-Known Member
    Orange County
    '06 Double Cab Long Bed TRD Sport 4x4
    Hi all. I just had to replace my second set of rotors and brakes within 40k miles. Now they are warped again. I have heavier 33" tires and 18" rims. Any recommendations on a better rotor and brake pad set up that can handle the heavier weight? I've done a search and came across a bunch of people talking about Power Slot rotors but I'm not sure which one I need to get. Any idea on the part number? Any advice and help would be much appreciated.
  2. May 22, 2011 at 7:03 AM
    bendawg62
    bendawg62 Active Member
    Alberta
    2010 Tacoma TRD / 2013 Tacoma TRD
  3. May 22, 2011 at 7:24 AM
    ice.xiv
    ice.xiv Member
    06 TRD Access Cab 4x4 6Spd
    Autoanything.com has them. PWR-126.44129SL and PWR-126.44129SR. I had the same problem with my truck and installed Power Slot discs with Hawk pads, world of difference.
  4. May 22, 2011 at 8:10 AM
    kwelhand
    kwelhand Well-Known Member
  5. May 22, 2011 at 4:22 PM
    TheBlackPearl
    Orange County
    Okay... I am on Autoanything and they have two kinds of rotors... One for $123.00 called Power Slot Slotted Rotors and the other one is called Power Slot Cryo Rotors. I'm assuming I don't need the Cryo treated ones since I'm not doing any major racing.
    Also what type of Hawk pads are recommended?
  6. May 22, 2011 at 4:28 PM
    allmotorrex
    allmotorrex Grove St. Fab
    Gideon
    Memphis 901
    08 SR5 4wd 2.7
    NWF crawlbox, 5.29s, rear Detriot, front Harrop, 37" SXIIs, 17x9" KMC Grenade Crawl beadlocks, Dirt King 3.5" LT kit with King shocks, Fox 12" smooth body RR, BAMF shock kit, AP 3" springs, ext. brake lines, custom 1 piece driveshaft with .135 wall tubeing, GSF front rock crawling bumper, GSF rear bumper, Relentless Fab ifs skid, BAMF k/o sliders, X2O 10K comp. winch, TP glass fenders, OKled 20"bar, EBS dimpled/slotted rotors, EBS green pads, custom K&N CAI, LCE headers, FM Super 44 w/h turn down, URD MAF, Spec clutch, LCE heavy flywheel, URD short shifter, TMPer M1 Abrams shift knob, Amsoil oil, Cobra 75wxst w/h 4' firestix, Grillcraft, FXR TRS, T1 eyelids, custom ADV Monster 60 lights, bed lights, speedo light mod, Glow Shift volt/oil pres gauges, Glow shift 2g column pod, Optima yellow tops dual battery setup w/h IBS system, Pioneer DEH-P7200HD head unit, Pioneer 600W 4ch & 350w 2ch amps for doors and sub, Wet Oakle covers
    i got EBS dimpled and slotted rotors along with EBS green brake pads and they have done me awesome so far. Got about 30k on them and they still feel like the day i put them on
  7. May 22, 2011 at 4:43 PM
    Oceanrunner
    Oceanrunner Well-Known Member
    X2 on the EBS Slotted and dimpled. But I prefer Hawk LTS pads. I had both on my Dodge Ram 1500 Hemi Sport quad cab and always towed 30' boat. They never warped and have great performance. I will use the combo on my new Toyota TRD Sport... but I only have 600 miles on it!
  8. May 22, 2011 at 4:54 PM
    TheBlackPearl
    Orange County
    Is it EBS or EBC???? I couldn't find anything for EBS.
  9. May 22, 2011 at 5:09 PM
    berry79
    berry79 Well-Known Member
    Homestead, FL
    08 DBL Cab LB
    I'm pretty sure they ment ebc, especialy when they refeted to the "green" pads
  10. May 22, 2011 at 5:13 PM
    TheBlackPearl
    Orange County
    Okay so what would be better?
    Power Slot Rotors with Hawk LTS pads
    or
    EBC SLOTTED DIMPLED with Hawk LTS pads?
  11. May 22, 2011 at 5:47 PM
    allmotorrex
    Gideon
    Memphis 901
    08 SR5 4wd 2.7
    yeah EBC, my bad
  12. May 22, 2011 at 6:29 PM
    ice.xiv
    ice.xiv Member
    EBC is good stuff, I use their products on all my dirt bikes. I use Power Slot and Hawk on my racecar. Either one is a great choice, just use whatever is cheaper and you'll be set.
  13. May 22, 2011 at 9:07 PM
    WilsonTheDog
    WilsonTheDog Kylie's dad
    Eric
    Myrtle Beach SC
    07 Prerunner SR5 DC/SB V6
    Magnaflow 12576 muffler & chrome tip, Westin step bars, 27% tint, Pop N Lock, AFE ProdryS, bed mat, Husky liners, D-rings added, Access Literider tonneau, Pioneer 4-ways all around, GY Wrangler Duratracs 265/75/16, 5100's @ 1.75", 1.5" AAL
    I had Powerslot and Hawk on my Altima and I will be using them on the Tacoma shortly. Personal preference but you can't go wrong with EBC, Hawk, or Powerslot.
  14. May 22, 2011 at 11:02 PM
    TheBlackPearl
    Orange County
    If I go with the powerslot rotors, should I invest in the cryo treated ones or is that overkill? I do 40% street driving, 55% highway, and less than 5% off road.
  15. May 22, 2011 at 11:23 PM
    1TUFFTRD
    1TUFFTRD WTF
    out and about building powerlines
    06 AC with a skewp
    06 With a Skewp.
    Subbed ... my rotors are warped bad!
  16. May 23, 2011 at 3:09 AM
    ChompsterTacoma
    ChompsterTacoma Well-Known Member
    Chompster
    Fresno,Ca
    TRD offroad 4x4
    Bone Stock
    My rotor is warped too. Only 15,000 miles.
  17. May 23, 2011 at 8:02 AM
    TheBlackPearl
    Orange County
    Yea I consistently have this problem. When I first bought my truck used, they warped and squeeked within the first 4 months. I figured maybe the original owner never serviced his brakes. So I replaced the pads and resurfaced the rotors. 4 months later, after some mudding/offroading and rainy season, and downhill mountain driving, the rotors warped again. So I swapped out the rotors with some OEM ones along with new brake pads. Then after a few close calls on the freeway and a few situations where I had to come to an abrupt stop, the rotors warped again in 3 months. Maybe this is my fault but my buddy with a 2010 tacoma is even worse on the brakes than I am and his are perfectly fine.
    I'm leaning towards the EBC Sport Rotors that are slotted and dimpled w/ Hawk LTS pads. Or should I go with EBC Green pads?
  18. May 23, 2011 at 8:18 AM
    rob1
    rob1 Well-Known Member
    Robert
    South Texas
    Indigo Blue DblCab 4X4 Long Bed TRD Sport SR5
    Tail gate mod, locking gas cap, locking spare tire, rear spring tsb,Weathertech Digital fit's
    Subscibed for future reference...:cool:
  19. May 23, 2011 at 8:21 AM
    mjp2
    Milton Juevo Portimous II
    NJ
    Current: '21 Bronco Badlands. Previous: '06 TRD Access Cab, v6, 6-speed
    Call Edwin at RaceShopper.com and order a set of SP Performance slotted rotors and Hawk pads.
  20. May 23, 2011 at 8:27 AM
    mjohn617
    mjohn617 Well-Known Member
    Petaluma, CA
    05 DC TRD sprt silver
    Haha...not doing it...can't make me!
    I had this issue after an 85 lb rim and tire setup. The stock wheels were ~60lbs. I went with basic rotors and soft pads, havent had a problem since. The softer pads wear a little faster but they work great.
