Need to upgrade brakes and rotors that wont warp
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TheBlackPearl, May 22, 2011.
  1. May 24, 2011 at 9:45 PM
    #41
    TheBlackPearl
    TheBlackPearl [OP] Well-Known Member
    Orange County
    '06 Double Cab Long Bed TRD Sport 4x4
    Lol... I don't drive like a racer boy. This truck is too slow for that.... especially with the heavier wheels/tires. I don't have road rage either and actually drive like a grandpa. There are a few times when I have to press the brakes harder to avoid running red lights. However, I always notice that the problem starts when I drive during a rainy day or drive downhill too long where I have to slow down by pressing the brakes.
    I am actually going to bring it to another brake shop this time. I'm starting to think maybe it's the brake shop that I take it to. They replaced my brakes all 3 times and I've had problems all three times.
  2. Jan 21, 2012 at 11:13 AM
    #42
    jjw1
    jjw1 Well-Known Member
    Jesse
    Citrus County Florida
    2011 Super White DCSB TRD OR PreRunner
    Weather Tech Floor Liners, Truxedo Bed Cover, OEM Silver Step Bars, Debadged, Colormatched Satoshi, Wet Okoles, OEM Roof Rack, Bed Mat, Locking Gas Cap, and removed Mud Flaps
    Sub'd
    I think my rotors might be warped. When I'm on the highway and go to push the brakes my steering wheel shakes. Now, right before my truck completely stops, the brakes squeak. Also, I find the brakes to be very sensitive to water. I cant wash the wheels without the brakes making an awful noise.
  3. Jan 21, 2012 at 11:45 AM
    #43
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
  4. Nov 1, 2014 at 1:57 PM
    #44
    Overkill07
    Overkill07 Tacoitis
    Warren
    Texas
    14 TRD O/R DC MGM
    A few audio upgrades, tinted windows, remote start because it f'n hot in Texas! 6in Fabtech DB lift, 17x9 Fuel Trophy wheels, 315/70/17 Duratracs,BAMF 80in sliders w/kickout, Prinsu cab rack w/30in Heretic light bar, custom bedside decals, custom hi-lift jack brackets, US Offroad front bumper w/winch, bed rack with RTT, CB, Short wave base station, Ultra gauge, color matched grille surround, an ungodly amount of recover gear, ARB fridge, hood struts, RotoPax, traction pads.
    This has been the most helpful thread yet on TW for brake upgrades. So I am resurrecting this to share for others as this is a continuois topic that has not been covered enough with acurate info. I will update with my experance. Since the install of my 6in lift and running 35's on 17's my stopping distance SUCKS!. It is to the point where I will not let my wife drive the truck in worries that she will not be able to stop in time when she needs to.
  5. Oct 19, 2015 at 8:15 AM
    #45
    User Name01
    User Name01 Little boy from FairyTale Land
    Bolbi Stroganovsky
    Wherever the next wind project is
    TRD Sport Barcelona Red Metallic Dbl Cab 4x4
    i was thinking about new rotors, just last night....i ran 0-60 test....and the whole truck shook when I applied the brakes
  6. Oct 20, 2015 at 4:05 AM
    #46
    Overkill07
    Overkill07 Tacoitis
    Warren
    Texas
    14 TRD O/R DC MGM
    Sounds like your rotors may be warped. If they are not bad, then they could be machined. If not, then it's time for an upgrade. I will upgrade mine when they wear out. It seems that I've just gotten use to the increased distance needed for stopping.
  7. Oct 12, 2016 at 10:48 AM
    #47
    jp05
    jp05 Well-Known Member
    Juan
    TN 931
    2016 Tacoma SR, DCSB, 4x4, Leer Top.
    good information
  8. Oct 12, 2016 at 11:38 AM
    #48
    Tex-Tac
    Tex-Tac Well-Known Member
    TEXAS
    2008 Tacoma V6 PreRunner SR5 Extended Double Cab Desert Sand Mica
    Installed Overhead Compass and Temperature Display along with outside temperature sensor and wiring; LED lights reverse backup; LED license plate lights; Added GTA Bluetooth Audio kit to stock radio for iphone audio; Spare tire steel braided air hose extension connection to rear bumper; Installed new headlights along with new bulbs PIAA H4 XTreme and for fog lights PIAA H10 XTreme bulbs. Installed new hood with "hood-scoop". Installed Predator Side Steps. Replaced front chrome grill with customized color matched (Desert Sand Mica) grill with added TOYOTA lettering (also in matched color), installed and secured tailgate anti-theft devices. Also installed a new external TPMS monitor for all 4 tires.
  9. Oct 12, 2016 at 12:14 PM
    #49
    Crosis
    Crosis Tertiary adjunct to unimatrix 01
    Dunedin Fl
    09 Tacoma 4x4 TRD Off Road
    I must be super easy on my truck. I have 70k on it and have the original rotors with no warping.
  10. Oct 12, 2016 at 5:34 PM
    #50
    dwaltdtx
    dwaltdtx Well-Known Member
    David
    DFW, TX
    108K miles with original rotors. I am about to upgrade due to added weight and the fact that I tow quite a bit. I will probably go with ebc, but it's good to see several people having luck with cheaper options
  11. Oct 12, 2016 at 5:38 PM
    #51
    FreidTaco
    FreidTaco boost
    jeff
    Panhandle of Wyoming
    06 Tacoma TRD OffRoad SR5
    URD Stage 3 SC. 35" duratracs LT
    stop braking so hard. good grief. learn to slow down sooner and more gradual. Use your engine to help slow you down. I just replaced my front pads from the factory OEM ones at 92k miles(and still had life left on them) I am also on 35s fyi.
  12. Oct 12, 2016 at 5:58 PM
    #52
    gearcruncher
    Canadain bumper technician
    There was mention of using the emergency brakes with auto and manual transmissions and I totally agree .
    Use them every time you park
    Its one of the best things you can do to keep your truck rolling to a stop smoothly and parking smoothly for many miles to come .
    1 - Keeps your rear brakes adjusted properly so when you need to come to a stop quickly you are using all 4 brakes rather than just the two up front
    2- When coming to a stop and preparing to park , hit the ebrake which unloads the energy or weight of the truck off of the transmission parking pawl .
    Your brakes are going to last longer and you are going to produce less metal to metal wear inside the transmission.
    Here is a pic of your parking pawl . That tiny gear and locking assembly with that tiny steel pin are assigned the task of holding your 4000 pound truck from rolling . Add some bigger tires and a heavy bumper and you are asking for grief .
    I have replaced many of these .
