Need wheels to fit my new tires
Discussion in 'Wheels & Tires' started by BMOC, May 21, 2011.
  1. May 21, 2011 at 6:18 PM
    BMOC
    BMOC [OP] Well-Known Member
    Paden
    Phoenix, AZ
    I have 4 new General Grabber Red letter tires 285/75/16
    So, i'm looking for 16 inch rims
    problem is, the style rim i want consists of shaving brake calipers i've learned. Mickey Thompson Classic II or Procomp 7069
    my question is; is there any rims with that same design that will run my General grabbers on my truck while letting me stay away from modifying the caliper?
  2. May 22, 2011 at 12:59 AM
    mikesdoublecab
    mikesdoublecab LT Chase Truck
    Mohawk Mike
    Glendale, CA
    01 Tacoma DoubleCab V6 Prerunner
    Engage Offroad long travel front and rear with some fat tires.
    really? who told you that you would need to shave the calipers?
    folks have been running MT Classics for years on tacomas...
    if it was a retailer who told you this information, it may be off... from what i understand, if your truck came stock with 16s, you should be ok...
    if it came with 17s, then it would be the circumference of the caliper that may not clear the 16s, in which case, you would need to step up to 17s...
  3. May 22, 2011 at 1:50 AM
    BMOC
    Paden
    Phoenix, AZ
    Detective_dan is the user who had the issue with the pro comps actually, and i searched a thread earlier where somebody mentions the same process while using the mickey thompsons. maybe the guy's info was off on the MT classics, but detective dan definitely has a thread up about it.
    here's the thread mentioning the MT classics not fitting
    http://www.tacomaworld.com/forum/wheels-tires/87119-mickey-thompson-classic-ii.html
    /e just read some of the post's, only that one user had the caliper issue for the MT classics, hope i won't haha, i'll try and find a pair to test fit them before i purchase em'
  4. May 22, 2011 at 3:46 AM
    Casey31
    Casey31 Well-Known Member
    Casey
    Saltillo, Mississippi
    2013 Silver Streak Mica Double Cab 4WD
    2.5" in lift upfront from the dealership, 1.5" AAL in the rear, Aries Bull Bar painted Black, Badges painted Matte Gray, 17" Pacer Type 164b wheels
    I have been wondering the same thing about both of these wheels. I am looking at both of them in 17s. I do not want to have to shave the calipers.
  5. May 22, 2011 at 6:05 AM
    thanhnc
    thanhnc New Member
    Thanh
    orange county
    Tacoma 4x4
    tacoma 2010 4x4 dbl cab just with 3" lift I need tire size to fit with stock rim
    17 x 8 without modify for clearance
    Please help
  6. May 22, 2011 at 9:43 AM
    BMOC
    Paden
    Phoenix, AZ
    265/70/17 tire if you don't want to modify.
  7. May 22, 2011 at 9:46 AM
    BMOC
    Paden
    Phoenix, AZ
    you should be fine with 17 inch rims
  8. May 22, 2011 at 10:01 AM
    Casey31
    Casey
    I appreciate the help! Thanks.
