Need your opinion on this damn pop
Discussion in 'Suspension' started by 05tacoSPORT, Sep 16, 2010.
  1. Sep 16, 2010 at 3:31 PM
    05tacoSPORT
    05tacoSPORT [OP] Well-Known Member
    Tennessee
    TRD SPORT
    Geared and Locked
  2. Sep 16, 2010 at 3:41 PM
    meckleystephen
    meckleystephen My Taco is Bi-Winning!!!!!!!!
    Stephen
    York, PA
    2013 Toyota Tacoma Off Road
    3 Inch Toytec lift,Blacked out badges
    Dont know what the noise could be but that is a pretty sweet view you got there.hope you figure out what is making that noise.
  3. Sep 16, 2010 at 3:52 PM
    05tacoSPORT
    Tennessee
    TRD SPORT
    Geared and Locked
    This pop is really pissing me off. I took the truck by toyota to check the CV's and the said they are fine. Then he drove the truck and said that my skid plate was moving from frame flex "BS" i took the skid off and it still pops.
  4. Sep 16, 2010 at 3:55 PM
    05tacoSPORT
    Tennessee
    TRD SPORT
    Geared and Locked
    At 3:50 on the vid is how it sounds off road. pop pop pop click pop click REALLY
  5. Sep 16, 2010 at 3:56 PM
    ratm3245
    ratm3245 Well-Known Member
    SW. Illinois
    2010 Black Sand Pearl 4X4 DC/SB TRD Sport
    TRD Cat-Back, Weathertech Mats, Nfab light bar, PIAA 520 ATP Drivers, PIAA 520 Fogs, Weathertech Vent/Visors, Blendmount Escort Radar Detector, Kenwood DDX516 HU w/Bluetooth, Kenwood Kna-G610 Hideaway Garmin GPS Navigation System, Alpine S-Series in the doors, JL Stealthbox, JL J2 500.1 Amp, Alpine MRP-F300 Amp, Pro Comp 7098 17X8, 265/70R17 Duratracs, UWS Lowpro Tool Box, K&N 63 Series Intake, 50% Tint in front, Bajarack, AllPro Sliders
    Uca hitting the coil? And mind you this is a very uneducated guess!
  6. Sep 16, 2010 at 3:58 PM
    meckleystephen
    Stephen
    York, PA
    Yea I really dont have any idea what it would be, but then again I am no mechanic. The only place that I have ever heard a noise similar to that was on a Jeep Cherokee one of my buddies had it did the same thing but his came from the rear. That was only because his shock mount had completley rusted away. I hope you figure it out though, that would annoy the hell out of me.
  7. Sep 16, 2010 at 4:01 PM
    gmac
    gmac Member
    Geoffrey
    nova scotia
    tacoma TRD sport
    its your front bumper extension
  8. Sep 16, 2010 at 4:34 PM
    05tacoSPORT
    Tennessee
    TRD SPORT
    Geared and Locked
  9. Sep 16, 2010 at 4:36 PM
    05tacoSPORT
    Tennessee
    TRD SPORT
    Geared and Locked
    what is that?
  10. Sep 16, 2010 at 4:38 PM
    05tacoSPORT
    Tennessee
    TRD SPORT
    Geared and Locked
    Nope not hitting coil Maybe stock OEM billy is maxing out making a pop at full ext.
  11. Sep 16, 2010 at 4:41 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    How long ago did the poping start? Did you do anything to the truck before this happened?
  12. Sep 16, 2010 at 4:47 PM
    05tacoSPORT
    Tennessee
    TRD SPORT
    Geared and Locked
    I didnt notice this until shortly after my lift. OME 884 with top plate spacer with stock shocks Diff drop and TC UCA. 2k after the install just a guess I have 8k on the lift now.. And im ready to upgrade to ICON ext. travel coilover / will this help
  13. Sep 16, 2010 at 4:57 PM
    crf69
    crf69 scraping my emblems off my plasti-dip
    Ohio
    06 TRD OR BSP cab'n 1/2
    ummm yeah
    looks to me that the bottom seat for the coil is crooked....but i think that is normal
  14. Sep 16, 2010 at 5:10 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    You may want to check the torque on all the bolts that were disturbed when installing the lift.
  15. Sep 16, 2010 at 5:39 PM
    justin14200
    justin14200 frequent reader
    justin
    baton rouge
    2010 prerunner sr5 bsp
    stock
    it might be the strut mount. try torquing them down a bit more. i noticed the ppping noise is mostly with the strut compressing or extendinig with the wheel turned. try to torque down all your suspesions bolts. make sure the spring was compressed in the correct place on the mount. grease all your fittings. test drive for a day r so and see if it helps any or if it fixes it
  16. Sep 16, 2010 at 5:41 PM
    05tacoSPORT
    Tennessee
    TRD SPORT
    Geared and Locked
    OK do you by chance have the toque #'s It seems to pop on both sides. After one day with the lift i did check all bolts but i will torque friday after work Thanks chris
  17. Sep 16, 2010 at 5:43 PM
    05tacoSPORT
    Tennessee
    TRD SPORT
    Geared and Locked
    Yup does seem to come from the strut thanks for the opinion
  18. Sep 16, 2010 at 5:48 PM
    justin14200
    justin
    baton rouge
    stock
    tighten the upper srut mount bolts tightly?
  19. Sep 16, 2010 at 6:05 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    For the uniball, where it meets the spindle, tighten to 100#'s. Same with the UCA bolt to the frame. The 3 top nuts on the shock/spring get 47#'s, lower shock mount gets 61#'s, Tie rods get 67#'s, LCA's get 118#'s (near the lower ball joint).
  20. Sep 16, 2010 at 6:10 PM
    4WD
    4WD cRaZy oLdmAn
    Doug
    Lakeside, Ca / Gardnerville, Nevada
    2004 DC TRD 4x
    Grey wire MOD, deck plate, diff breather MOD, 2nd gen. OME 883# on Tundra 5100's, OMD custom 3" leafsprings, rear shock relocation, Ivan Stewart TRD rims w/285/75/16's, '02 bumper MOD, Famous Fabrications sliders , LED interior/exterior lights, bed bar, Custom tube bumper, Old school KC day lighters,Red Ring 8" HID flood, Kenwood vhf 2M.. umm some other shit I'm forgetting right now
    Damn dude could be a couple of things, like mentioned go over your install & re check for tightness & maybe its just me but your drive line & susp. components sound really dry, it does sound like something kinda slapping intermittently on something else....:notsure:
    You still have anti sway bar on it ?
    I thought I saw some more than normal movement in bottom shock mount
    coulda sworn I saw nut slowly spinning .....:eek::eek:
