Needle Bearing Failure With Lift (How Many)
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Harvo, Apr 17, 2017.
Have you experienced front end vides or needle bearing failure after lifting your truck?
  1. Yes
    263 vote(s)
    40.2%
  2. No
    268 vote(s)
    41.0%
  3. I installed the bushing when I installed the lift
    123 vote(s)
    18.8%
  1. Apr 18, 2017 at 10:36 AM
    blownoutsundays
    blownoutsundays Member
    Doug
    Yeah, I'm with ya. I just find it hard to believe that the heat due to rotation doesn't correct the vibration once you start driving around as does outside temperature. I'm willing to bet the heat due to rotation is >40 degrees. There must be something else. Perhaps viscosity of gear oil?
  2. Apr 18, 2017 at 10:39 AM
    smitty99
    smitty99 I also bought a 4Runner
    Scottsdale
    16 TRDORDCSB 4x4 A/T (loaded w/ JBL)
    6112s/5160s & 3-leaf AAL;ubolt flip kit;Superbumps
    It's an intermittent problem that comes and goes with temp, speed, and likely other factors (i.e. road surface) playing a role. We're talking about thousandths of an inch of play but at certain RPMs causing an almost harmonic vibration/sound that you can feel through the steering wheel, pedals, and floorboard. There is no doubt however, the ECGS bushing completely fixes it and in some ways I feel the truck is smoother than before even when it was STOCK. No brainer.
    remgu2000 likes this.
  3. Apr 18, 2017 at 10:39 AM
    BlkTaco47
    BlkTaco47 Unhinged
    2018 TRD PRO Midnight Black Metallic
    how tough is it to replace the ecgs bushing? pricey to get it done?
  4. Apr 18, 2017 at 10:43 AM
    smitty99
    Scottsdale
    It takes about 2 to 3 hours of labor if you pay a shop to do it. Some have got it done for $180 and others I've seen $300 range.
    For parts: if you need the removal tool it's $60. Otherwise some threads on here people are selling, loaning or renting them out for less. Then you're waiting on availability and such....
    -$60 for the bushing
    -$20 for new axle seal (dumb not to buy one because it's cheap and you'll likely tear up the stock one upon removal)
    -$20 for 2 qts of 85w-140 Lucas Gear Oil
    If you do it yourself it could take 3 to 4 hours. You have to have a tie rod puller (rent one), pull the cv axle out of the diff, and you have to refill the diff with fluid (1.6 quarts of 85w-140 Lucas Heavy Gear Oil based on ECGS recommendations). Also recommended to have some sort of bearing driver to help get the bushing seated flush and straight.....
    Labor also involves tearing down the drivers side suspension obviously to get access and to pull the axle so this is why many recommend doing it while you do your lift. Otherwise you're backtracking and tearing up track to get it right.
    There are write ups on how to do it. See an example here of a pretty good write up: https://www.tacomaworld.com/threads...-and-adventures.362772/page-171#post-14019469
    With just parts you're looking at anywhere from $140 to $180. Now add labor.
    Price it out here: http://eastcoastgearsupply.com/i-8536125-toyota-8-clamshell-bushing-eliminates-needle-bearing.html
    Read their FAQ and install instructions on that ECGS link. See if you think you can do yourself.
    EDIT: BTW repair shops aren't huge fans of people coming in with a self-diagnosis (shocking I know) So be prepared to hunt around for a shop that will be willing to perform the job, putting on customer-supplied parts, with a customer-provided diagnosis.... particularly on a brand new still-under-warranty vehicle. It will help if you walk in with the install procedure from ECGS printed out, and parts in hand. Any shop that can replace a CV axle should technically be able to complete the job within a couple of hours.
  5. Apr 18, 2017 at 10:46 AM
    blownoutsundays
    Doug
    Oh yeah, no arguing that. I'm looking forward to the smooth ride once I stop being so lazy lol. Just allowing my mind to wander a bit. I commute with the truck (same drive every day) and notice outside temperature alone affecting vibration. In my case, ~65 degrees seems to be the point where vibration is undetectable. I'm curious how many people that live in warmer locations are the ones who don't experience vibration.
  6. Apr 18, 2017 at 10:48 AM
    smitty99
    Scottsdale
    I live in Phoenix and it's been 60s in the morning and mid to high 80s in the day. It was vibrating mostly in the AM or when truck was cold, but certainly would kick up at times during the peak heat of the day. I just fixed it not even 2 weeks ago
  7. Apr 18, 2017 at 11:01 AM
    MadRiverTaco
    MadRiverTaco Join TW, they said. It's free, they said.
    Brenden
    Waterbury, VT
    2012 Black DCSB TRD OR "Caroline"
    King 2.5 Ext. w/ Compression Adjusters (Front & Rear), Dakars w/ D29XL, TC UCA's & LCA's, ARE CX, 17" SEMA Pro's, 265/70/17 Falken Wildpeaks, BORA spacers, Rigid Side shooter ditch lights, ATHF bedside reinforcements, OME carrier bearing drop bracket, extended rear brake lines, Northstar 27F battery, Yakima Jetsream crossbars, OEM roof rack, OEM skid plate, TRD Pro grill, URD TCAI, 5.7L Throttle Body, BensonX bedside tool mounts, fire extinguisher bedside mount, AMP research bed step, Redline Tuning hood struts, ECGS needle bearing mod, CV Boot slide mod, Differential breather mod, U-Bolt Flip Kit w/ Timbren Bumpstops, A-pillar RAM mount w/ cell phone holder, ProFX tow mirrors with turn signals and heat, "Raptor" lights, DEPO taillights, motorized Pop n' Lock
    I really regret not doing this when installing my lift last week. The vibes are happening between 40 - 45 mph and started immediately after the lift. I love the lift, hate the vibes. To those getting ready to do a lift, include this in your parts list. Yes it's a higher up front cost, but you'll be saving time (and money if doing yourself) by not having to go back and do it afterwards
  8. Apr 18, 2017 at 11:02 AM
    smitty99
    Scottsdale
    Yes I put this into my write-up for the 6112/5160 lift as something to "seriously consider"
    I think it should be a requirement for anyone wanting to lift.
  9. Apr 18, 2017 at 11:05 AM
    MadRiverTaco
    Brenden
    Waterbury, VT
    I agree Smitty. This issue should be made a sticky in the suspension forum and included in the lift guide threads if it's not already...
    EDIT: does this happen on 1st gens?
  10. Apr 18, 2017 at 11:20 AM
    Metallikatz3
    Metallikatz3 Well-Known Member
    SLC, UT
    2017 DCLB OR
    Always in process
    Bearing is making noises on my truck at 6k miles without a lift. Have the bushing already which will be installed when I lift.
    Also had the needle bearing fail on a 2005 Tacoma and 2008 Tundra without lifts on them as well
    smitty99 likes this.
  11. Apr 18, 2017 at 11:22 AM
    MetrickMetal
    MetrickMetal Praise the Lowered
    Scott
    Yerington NV
    2017 Super White SR5 Access Cab / 4WD, AT / TP
    See my sig for mods
    I plan on leveling out the front of my SR5 soon, and I'm going to do the bushing / seal replacement while I have it torn apart.
    So if anyone has one of the EGCS needle bearing pullers and knows how to accurately measure things, could you please give me the dimensions of the threaded needle bearing puller plate, the LWH dimensions of the cross bar and the thread diameter and length of the threaded rod, which from the picture looks to be ½-13 thd, as I want to make my own puller.
    If anyone has the puller, but isn’t capable of accurately measuring the puller parts, I would gladly pay the shipping and return postage for mailing me the puller so that I can measure the parts.
    I’m also going to machine up a piloted bushing and seal driver out of aluminum, which I have done many times before over the years for repair jobs.
  12. Apr 18, 2017 at 12:07 PM
    Harvo
    Harvo [OP] Hanging On !!!
    17' TRD Offroad DCSB
    SpiderTrax, RCI Sliders, Warn bumper, Smittybuilt winch, Ridge Grapplers...
    Just curious. It's the vibration more of a buzzy frequency through the steering wheel or is it a really obvious vibe like when au joint starts going bad?
  13. Apr 18, 2017 at 12:20 PM
    Midknight
    Midknight Well-Known Member
    Western Canada
    2018 TRD Off-Road
    2016 TRD OR
    Lifted 2000 km ago, no vibration. Lift is 2"
  14. Apr 18, 2017 at 12:34 PM
    smitty99
    Scottsdale
    Hard to describe sounds and feels but its "whirring" vibration you feel in pedals floorboard and steering wheel, kind of a rhythmic "waaaaa waaaaa waaaa" it is not deafeningly loud. It's almost like somebody slapped heavy Mud Terrains on the truck.
    TacoTrooper and silvertxtaco like this.
  15. Apr 18, 2017 at 12:38 PM
    #35
    TACOVRD
    TACOVRD I Identify As A Prius
    TW Addict
    AZ/WA
    2019 T4R ORP - Formerly 2013 DCSB OR Spruce Mica
    Workin' on it....
    Good info.
  16. Apr 18, 2017 at 1:01 PM
    #36
    elduder
    elduder Well-Known Member
    Van WA
    2019 Voodoo Blue Tundra TRD Pro
    Apparently yes, buddies 1st gen has the same issue. His truck is stock, but had 130K on it.
  17. Apr 18, 2017 at 1:04 PM
    #37
    smitty99
    Scottsdale
    Yes this affects all generations as well as other Toyota platforms (FJ and 4Runner I believe too) you can validate that on the ECGS website, they have plenty of information on it.
    Here's a 7.5" clamshell for T100s, older pickups, and 4runners: http://eastcoastgearsupply.com/i-14472912-toyota-7-5-clamshell-bushingeliminates-needle-bearing.html
    They sell several different clamshells for a variety of Toyota applications.
    http://eastcoastgearsupply.com/c-1025774-toyota-clamshell-bushings.html
    MadRiverTaco[QUOTED] likes this.
  18. Apr 18, 2017 at 2:49 PM
    #38
    Hiluxski
    Hiluxski Well-Known Member
    Ventura California
    2022 Lime green TRD Pro
    2017 with 600 miles 1 3/4" Lift . Vibrations began immediately. Bushing on order
  19. Apr 18, 2017 at 3:06 PM
    #39
    Diablo169
    Diablo169 ROKRAPR
    Max
    Santa Cruz, CA
    99’ Bro-Coma’s Revenge 3RZ 345k+
    Stock
    This should have been a sticky back in 95.5 on the CEO of Toyota's desk.
    Or at the very least in the welcome letter from tcBob when you join the site.
    "Welcome to Tacoma world, yes 265's will fit, and yes if you touch your suspension your shit will vibrate."
  20. Apr 18, 2017 at 4:43 PM
    #40
    Jasn
    Jasn Well-Known Member
    Kentucky
    2016 TRD Sport
    2016 TRD Sport. 11000 miles. 1/2" lift (over stock) on the front mainly to get the height back that I lost with weight from a winch and steel skid plate. Vibrated immediately. About to do the bushing.
    Diablo169 and smitty99 like this.
