Needle Bearing Failure With Lift (How Many)
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Harvo, Apr 17, 2017.
Have you experienced front end vides or needle bearing failure after lifting your truck?
  1. Yes
    263 vote(s)
    40.2%
  2. No
    268 vote(s)
    41.0%
  3. I installed the bushing when I installed the lift
    123 vote(s)
    18.8%
  1. Apr 30, 2017 at 5:08 AM
    #61
    Harvo
    Harvo [OP] Hanging On !!!
    17' TRD Offroad DCSB
    SpiderTrax, RCI Sliders, Warn bumper, Smittybuilt winch, Ridge Grapplers...
    From all that I have read... you should be covered under warranty, especially is the dealership installed the lift. Damage occurs while it is vibrating. It tears up the bearing and could wear the contact point on the CV or I imagine the "race" in the clamshell. Is it possible that you were feeling a tire issue all along? I would make sure the dealership has your complaint on record and the date you reported it in case it or (when) it becomes more of an issue later. If they do fix it eventually... it will just be with the same part that failed and not the ultimate remedy (the bushing) most likely.
  2. Apr 30, 2017 at 5:23 AM
    #62
    spazerboy
    spazerboy Well-Known Member
    2016 MGM DCSB OR 4X4
    Mine's a TRD Off Road, and I developed the vibes shortly after installing my lift. Icon stage 4 with tubular UCA, coilovers almost maxed out. I have almost everything to do the bushing, so I'll be doing it next weekend.
  3. Apr 30, 2017 at 6:16 AM
    #63
    Green Mountain Skunk
    Green Mountain Skunk Well-Known Member
    2017 Barcelona Red TRD OR
    I guess anything is possible, but, the symptoms described here in this thread and another couldn't have been more exact to what I was experiencing.
    My description of the issue and complaint should definitely be on record. It's in the printout of services completed.
  4. Apr 30, 2017 at 6:25 AM
    #64
    stevotivo12
    stevotivo12 Well-Known Member
    Stephen
    2016 Silver Tacoma TRD Sport MT
    Front hellwig sway bar,All pro sway bar end links, Fox 2.5 Resi Coilovers and Shocks, Fox 2.5 Hydraulic Bumpstops, Budbuilt Traction bar, Total Chaos UCAs w/ heim joints, Icon AAL, AFE Power Intake with dynamic scoop, URD spec U, URD short shifter, Flossy weighted shift knob, michelin tires, black badges, black tailgate letters, black grill with custom Diaz Fab Devil horn yota logo, retrofit/morimoto HID conversion, red interior LED lights, Pioneer head unit, kenwood excelon door speakers, 2 10" pioneer subs,
    Mines a TRD sport and I developed the vibe immediately after a lift and vibes went away after ECGS clamshell bushing.
    spencer2423 likes this.
  5. May 1, 2017 at 8:26 AM
    #65
    nailersniper
    nailersniper Well-Known Member
    2017 Limited double cab
    One of my "know it all buddies" told me this: If I take out the needle bearing and replace it with the ECGS bushing, the warranty is voided because I disturbed the stock axle mechanics? I don't understand this stuff. Does anyone have an opinion on that statement?
  6. May 1, 2017 at 8:33 AM
    #66
    Camel89
    Camel89 Well-Known Member
    Houston, TX
    2016 TRD OR 4x4
    I got vibes between 30 and 45 the same day I lifted it. OME 888 with nitrochargers ~ 2.6" of lift in front.
  7. May 1, 2017 at 9:58 AM
    #67
    Jasn
    Jasn Well-Known Member
    Kentucky
    2016 TRD Sport
    That's at the discretion of the dealer. It's certainly possible and likely though, yes.
    smitty99 likes this.
  8. May 1, 2017 at 12:25 PM
    #68
    stevotivo12
    Stephen
    If you think it will be a problem order a new needle bearing and just say it's been doing the weird vibes all along
    nailersniper likes this.
  9. May 28, 2017 at 8:43 AM
    #69
    BlackTacosMatter92
    BlackTacosMatter92 Well-Known Member
    Jay
    2017 DCLB Tacoma
    King Suspension SPC UCA's Dakar Medium Leaf Packs Nitto Ridge Grapplers 255/75/16 VTX Vipers 16x8 (-12) Mobtown CMC plates Mobtown Sliders Smittybilt X20 10k Synthetic Factor 55 Fairlead & Flatlink MBRP Off Camber Fabrications Front Bumper MBRP Black PowderCoat Exhaust RX350 Projectors TRD Pro tail lights Truxedo Lo Pro QT Tonneau RCI Bed Rack Total Chaos Bed Stiffeners ARB CKMA12 CustomCarGrills Grille Line-X'd Grille 20% Window Tint (Front/Back) 75% Windshield 5% Visor Debadged
    Front Bilstein 5100's set at 1.55". Running a 275/65/18 on a 18x9 (-12) Have had installed since October and haven't had any vibrations or anything like that. Ha you guys are starting to scare me with this threado_O
  10. May 28, 2017 at 9:37 AM
    #70
    Diablo169
    Diablo169 ROKRAPR
    Max
    Santa Cruz, CA
    99’ Bro-Coma’s Revenge 3RZ 345k+
    Stock
    They have to prove the bushing caused whatever ever part in question to fail. Not sure what part in the front end you're worrying about breaking.
    Dealer voiding warranty wasn't a concern when I installed mine.
  11. May 28, 2017 at 9:38 AM
    #71
    stevotivo12
    Stephen
    I had my dealer install my busing to avoid running into this problem, but I have an excellent relationship with my Yota dealership so they kinda hooked me up on that one- I also brought them the slide bearing puller set as well as bearing driver to help with uninstall/reinstall, which they said they wouldn't have taken the job otherwise since they would have had to pull the whole front diff out to swap the bearing if the ECGS tools didn't work.
    Diablo169[QUOTED] likes this.
  12. May 28, 2017 at 11:02 AM
    #72
    PNWTacoma
    PNWTacoma Well-Known Member
    Paul
    PDX 3rd party OV Tuner
    2025 TRD Pro | Mudbath // 2017 Offroad DCLB OG
    PNW Adventures & PNW Tuning
    2017 TRD OR DCLB - installed OME nitrochargers with OME 888 coils and a Deaver AAL for the rear. Between 2.75" And 2" all around I've not experienced and vibrations yet. Truck has 2.5k miles and had the lift on for about 1000 miles so far. Hopefully, it stays this way.
  13. May 30, 2017 at 6:36 AM
    #73
    spencer2423
    spencer2423 Well-Known Member
    2016 TRD Sport
    Im getting the vibes at 35-40mph after my lift. improved after alignment of course, but still there a little. Interesting tho: switch to 4 Hi and it goes away of course, and when back to 2WD its gone for a while. its only been 2 days and has done this each day. Obviously i should try the ECGS bushing, but give me yalls thoughts on this... My lift called for spacers on the diff drop. easy enough to remove, so should i try that and see if theres a difference? I imagine the spacers for the diff drop is there for a reason (make it easier on the CVs?)
  14. May 30, 2017 at 6:44 AM
    #74
    Toynado
    Toynado Well-Known Member
    SF Bay Area
    2016 TRD OR DCSB Quicksand
    EXTERIOR: Toytec Boss 2.0 Dakar CS047R Leaf Springs Tailpipe chopped Pelfreybilt Front full hoop front bumper w/ Pelfrey fairlead Pelfreybilt Rear standard bumper Pelfreybilt Aluminum IFS, Mid, Rear (exhaust reroute) & Gas tank skids Pelfreybilt Fuseplate w/ 12 circuit fuse block All-Pro Apex Sliders ProComp 7036 17"x9" -6 offset BFG 275/70R/17 KO2's Warn VR10000-S winch Baja Designs S8 light bar & Squadron sports amber pods in front bumper Baja Designs S2 flush pods in rear bumper Baja Designs Squadron Pro amber pods on Caliraised ditch light brackets @rrentrop reflective black tailgate inserts RSI LED's for regular & high beams Prinsu Cabrac Custom Tradesman Truck Top by Access Manufacturing w/ Powertank 8"propane tank mount & Yakima tracks on the roof INTERIOR: Warrior Products door sill protectors Husky Weather Beater floor mats front & rear Coverking arid multicam seat covers in the front Midland 75-822 CB w/ 4' Firestick antenna on C4 Fabrication tailgate mount Consolevault Hondo Garage iPhone mount
    I had slight vibes with my ToyTec Boss lift with their AAL then swapped out to Dakar leafs w/out the carrier bearing drop and no shims and it's smoother. I had ordered the ECGS and have it sitting here but may wait to install it now.
  15. May 30, 2017 at 6:46 AM
    #75
    spencer2423
    2016 TRD Sport
    Harvo, im in TN also. Thinking about asking Toyota Knoxville this week about them doing the bushing job. Wondering if you have done anything yet and if you were successful?
  16. May 30, 2017 at 8:46 AM
    #76
    smitty99
    smitty99 I also bought a 4Runner
    Scottsdale
    16 TRDORDCSB 4x4 A/T (loaded w/ JBL)
    6112s/5160s & 3-leaf AAL;ubolt flip kit;Superbumps
    If you have the vibes the only thing that might fix is going back to stock height. However what I've seen is once you lift, it goes to this angle which causes the needle bearing to fail, so once it's failed it should be replaced with another needle bearing at a minimum (even if removing lift) or you should apply the bushing to fix the vibes and maintain lift. If you replace the needle bearing with another needle bearing, you're going to run into the same problem inevitably --just a matter of time and miles.
    Again, if the vibes are happening it is because the bearing failed. This inherently should tell you that you need to replace the part that has failed or risk chewing up the CV Axle shaft....your choice.
  17. May 30, 2017 at 9:00 AM
    #77
    spencer2423
    2016 TRD Sport
    Wel I don't see why I wouldn't replace with the bushing... I was really just curious about the diff drop. I knew the needle bearing/lift was the culprit here.... I've already inquired with my local dealer to see if they would operate if I supplied the bushing.
  18. May 30, 2017 at 1:01 PM
    #78
    Harvo
    I'm in Chattanooga (Cleveland actually) and I'm going to ask the Toyota Dealership where I bought it. I just haven't yet. They install lifts in their shop so hopefully they have heard of the bushing and ideally will install them if asked. Tom's 4x4 is the shop I asked first.
  19. May 30, 2017 at 2:05 PM
    #79
    Ecrub
    Ecrub Well-Known Member
    Eric
    Brea, Ca
    2016 DCSB TRD OR 4x4
    Great info. Looking to lift my 2016 and will definitely be getting an ECGS bushing installed at the same time.
  20. May 30, 2017 at 2:10 PM
    #80
    DRJ1014
    DRJ1014 Well-Known Member
    CA
    Spacer lift on my truck and no vibes, going on 20k miles since it was spaced.
