Needle bearing issues on 3rd gens
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Grmstir, Feb 8, 2018.
  1. Feb 8, 2018 at 7:13 PM
    Grmstir
    Grmstir [OP] Member
    2016 Quicksand Tacoma TRD Off-road
    Fox 2.0 Performance Series Shocks, Headstrong AAL, Borla Exhaust, S&B intake, TRD Pro grill, led lights, clazzio seat covers, trd pro shit knob, APX Rims, Nitto G2 Tires, CaliRaised LED light bar. Tuffskinz interior
    I’ve seen a couple posts, but is the needle bearing issue on almost all third gens that have been lifted ? I’m looking to do around a 2.25in lift in the front and 1.5inch lift in the rear. Wondering if I’d need the ECGs bushing as well because of this.
  2. Feb 8, 2018 at 7:57 PM
    Grmstir
    Grmstir [OP] Member
    Damn that sucks you don’t really know if you need it or not till you’ve done it. I wonder what Toyota does when they lift it from dealerships.
  3. Feb 8, 2018 at 8:11 PM
    cruxx
    cruxx Well-Known Member
    Huy
    2017 TRD Sport
    Will it be covered under warranty since lift voids certain parts of the suspension warranty?
  4. Feb 8, 2018 at 8:13 PM
    Bishop84
    Bishop84 Well-Known Member
    We do ECGS on 2.5+ inch lifts. Customers complain otherwise.
  5. Feb 8, 2018 at 8:22 PM
    eldedo
    eldedo voted most likely eaten by a bear
    Mojave Desert
    '16 DCSBOR 4X4
    2888/5100/Dakars 285's/Camburgs
    if you do the lift then do the diff bearing.
    Grmstir[OP] likes this.
  6. Feb 8, 2018 at 8:41 PM
    Grmstir
    Grmstir [OP] Member
    I might just call the dealership tomorrow and ask what they do when they lift theirs. They usually have at least one lifted Tacoma on the lot. Can’t imagine they’d sell them knowing this is an issue in lifted Tacoma’s. But then again who knows. I just don’t wanna void my warranty if I don’t have too since I have the extended verified pre-owned warranty or whatever
  7. Feb 8, 2018 at 9:12 PM
    eldedo
    Mojave Desert
    '16 DCSBOR 4X4
    you won't "blanket" void the warrenty, Moss-Magnussen Act. They would have to prove the failure was a result of the lift.
    AKGSD and Grmstir[OP] like this.
  8. Jun 29, 2020 at 10:42 PM
    Shawn5091
    Shawn5091 Member
    Shawn
    2020 Tacoma
    Still an issue on 2020 models?
  9. Jun 29, 2020 at 10:56 PM
    jmauvais
    jmauvais Received 2 votes in a poll one time.
    NorCal
    2018 TRD OR 4x4 DCSB
    ...stuff
    All tacomas 2005+
    Lt. Dangle likes this.
  10. Jun 29, 2020 at 11:59 PM
    bulalo
    bulalo Well-Known Member
    SoCAL Inland Empire
    2017 trd offroad 4wd LB
    KDMax pro 9.0
    You guys better read this. This “Magnussen Act “ people are referring is actually a paper tiger . Useless if you go to court unless you can afford not to drive your taco for months or even years and it gets expensive quick. https://www.tacomaworld.com/threads/ffs-lets-all-stop-referencing-the-magnussen-moss-act.609911/ An eye opener .
    Lt. Dangle and jmauvais like this.
  11. Jun 30, 2020 at 5:50 AM
    zoo truck
    zoo truck Well-Known Member
    2020 quicksand sr5 tacoma
    None
    Sounds very similar what my brother went through with a subaru back in the 90's that cost him over $15k with his original lawyer quitting. He eventually got some satisfaction, but in the end he felt a total loser.
    bulalo[QUOTED] likes this.
  12. Jun 30, 2020 at 6:26 AM
    TurdTaco64
    TurdTaco64 Well-Known Member
    Brandon
    Fort Collins
    2019 Cement TRDOR 6MT
    Warranty issues aside you will most likely need it. If I were you I'd do it as a bit of insurance. If you're having a shop do the lift then definitely have them do it while they're doing the rest of the lift since they'll be halfway in there already. If you do it yourself it's up to you if you wanna do it at the same time or wait and see what happens. This is what I did and ended up having a local shop do the bearing a couple weeks after I did my lift. And it won't kill your whole warranty as there's not many parts that would go bad because of the bushing. Unless by some odd twist of date it grenades and sends shrapnel all in the diff I suppose.
