Neons on door switch?
Discussion in 'Lighting' started by darkturtleninja, Sep 2, 2009.
  1. Sep 2, 2009 at 3:21 PM
    darkturtleninja
    darkturtleninja [OP] 9th level dungeon master
    Illinois
    95 2.7 3rz turd
    cold air intake, body lift, suspension lift.
    so ive had a couple white 48" neon tubes for awhile now an i was thinking about using them to light up the ground when i open my doors... that way i wont step in cat shit anymore...lol.. anyways i was wondering what the best way to do it is....
    is the switch a 12v positive or is it something else?
  2. Sep 4, 2009 at 4:21 AM
    Viet2100
    Viet2100 Well-Known Member
    Viet
    South Florida
    2016 Prius 4T
    I am not sure if your truck's dome light comes on when you unlock your truck, but you can hook them up to that if they do.
  3. Sep 4, 2009 at 6:42 AM
    98tacoma27
    Ben
    Not Beech Creek
    It's something else. The courtesy switches ground the ciruit from the integration relay (sinking ciruit). I haven't been able to locate a diagram for the 95.5-97 taco but the previous and post years indicate the system hasn't changed. If you want to power the neon's when the door is open, you will have to use the dome light or a seperate switch and relay circuit. IMHO
  4. Sep 4, 2009 at 7:17 AM
    SC4333
    SC4333 Well-Known Member
    Grant
    FL
    SOLD - 2016 TRD Off-Road 4x4 DCSB
    +1
    I would use the dome light as a low amperage signal to switch your relay that powers your lights.
