new 2010 4x4 torque converter lock up at idle and other weird sounds
Discussion in '2nd Gen. Tacomas (2005-2015)' started by mugenrios2k, Dec 19, 2009.
  1. Dec 19, 2009 at 10:36 AM
    mugenrios2k
    mugenrios2k [OP] Active Member
    Brand new with 2.1miles right off the boat
    2010
    4x4
    TRD sport
    Tow ( tranny cooler)
    now with 800miles
    This is my first 4x4 truck and I am loving it however there are some interesting things happening that I am not sure are normal.
    1) squeaking/purge sound right front ???
    After the truck has been sitting for a while ( cooled down and usually over night)
    When I back up and then proceed forward there is a weird sound that comes from the front passenger side of the truck.
    Best way to describe it is it sounds like a CV boot squeaking against its self or maybe some type of purge ( possible charcoal canister)
    It only does this once and happens as soon as I touch the throttle.
    if I let it idle forward it it still makes the sound just takes a little longer to here it.
    2) torque converter locking up at idel
    In 2 wheel mode ( have not tried to see if this happens in the other modes but assume it will)
    After coming to a complete stop the RPMs will stabilize around 550-600 and all is smooth and normal.
    After about 20sec the rpm will climb slightly up to 700 and you can feel the truck surge forward against the breaks, rear end squat and the truck vibrate due it cavitation withing the now locked up torque converter.
    After approx 10 secs of this the RPMS will drop back down and the torque converter will stop its cavitation and you feel the truck smooth back out.
    Now
    some times this repeats a couple more times sometimes it does not.
    It does not always happen every time I come to a stop
    Some time it takes longer for the truck to do this some times it is instant.
    I have been unable to figure out what exact conditions cause this and what conditions do not.
    I hate interment problems they are so hard to diagnose.
    What is the community thoughts opinions.
  2. Dec 19, 2009 at 10:55 AM
    Fortech
    Fortech Well-Known Member
    CANADA
    2005 Toyota Tacoma TRD OR
    Bilstein 5100's, rear TSB, Firestone bags
    If I were to offer suggestions, your first issue sounds like the ABS calibrating itself. Your second issue sounds like the AT downshifting to 1st gear, which it doesn't do right away when stopped.
  3. Dec 19, 2009 at 10:56 AM
    alx_alx_69
    alx_alx_69 Well-Known Member
    Alex
    Hope Mills, North Carolina
    Somewhere in the manual it says after a few hours of sitting it will purge something and make some noises, I got a 2010 and I remember reading that somewhere.check it out
  4. Dec 19, 2009 at 10:58 AM
    HondaGM
    HondaGM CallSign Monke
    James
    South-Pole, Alabama
    2023 access cab V6
    ^^i agree ,its the abs priming,and downshift at long stops.my 09 4x4 dc does the same thing..............ROLL TIDE ROLL:yay:
  5. Dec 19, 2009 at 11:03 AM
    Asgard
    Asgard Well-Known Member
    06 PreRunner DC SR5 w/LSD
    Normal
  6. Dec 19, 2009 at 1:36 PM
    mugenrios2k
    thanks guys.:)
    And I went to auburn so war eagle
    but a big ROLL TIDE
    SEC teams are the best in the nation
  7. Dec 19, 2009 at 1:38 PM
    JKD
    JKD Well-Known Member
    You bought it off a boat? I think I found your problem. :D
  8. Dec 19, 2009 at 6:13 PM
    mugenrios2k
    AC is not on
    :D its to cold for that....
    If the truck is in N it still cycles the rpms up in the same fashion.
    In P it stays at a consent and steady RPM
  9. Dec 19, 2009 at 6:23 PM
    Fortech
    CANADA
    The AC compressor cycles with the windshield defroster setting as well to provide moisture free air - regardless of the AC button position or the position of the heat knob.
  10. Dec 19, 2009 at 6:27 PM
    Isthatahemi
    Isthatahemi Well-Known Member
    TRD OFF ROAD
    BFG AT's, Weathertechs, Hoppy's brake controller.
    The torque converter is like a clutch, it is not locking up, or your truck would stall instantly. You really have no idea what you are saying. Do you even know what the word cavitation means? Your torque converter is not locking up or cavitating!
    1.The first sound is probably the evap purge valve.
    2.The second thing is probably your A/C compressor cycling. If you have the defrost on, it will cycle. (your owners manual tells you this if you read it)
    3. Get a clue.
  11. Dec 19, 2009 at 6:38 PM
    Isthatahemi
    TRD OFF ROAD
    It does not shift to neutral at any speed unless you move the shifter!! The torque converter locks as the truck decelerates and uses the vehicle momentum to keep the engine running without injecting fuel.
  12. Dec 19, 2009 at 6:39 PM
    350TacoZilla
    350TacoZilla Well-Known Member
    Hancock MD
    1997 3RZ 5spd 4x4 Reg Cab
    2.7L 3RZ,K&N filter, 4" deck plate mod,flowmaster 40 series,3" suspension lift, hybrid 52"chevy/toyota rear springs.
    wow bad day at office and need someone to take it out on? The guy has a few good questions for someone who just bought the truck. take a pill and settle down
  13. Dec 19, 2009 at 7:11 PM
    mick478
    mick478 He is The STig
    Bott
    Stockton, CACA
    2011 White TRD Sport, 4x4 doublemint cab
    Ome 885 coils Ome n9000 front shocks Ome n182 rear shocks K&n drop in filter Duratracs Kenwood kac 90210d Kicker 12" Alpine 800 watt 4 channel Pioneer 430w 6x9 Firestone ride rite air springs
    hahahahahaha, im still on the floor laughing!
    :D
    whats better is that it took hella posts for someone to point it out!!!
    love it!
  14. Dec 19, 2009 at 7:19 PM
    Asgard
    :confused:
  15. Dec 19, 2009 at 9:12 PM
    mugenrios2k
    yes i do know what Cavitation means. I am a mechanical engineer.
    Cavitation in the true scene happens when:
    The formation and collapse of vapor bubbles in a working fluid aka the tyranny fluid when the static pressure is below the vapor pressure of fluid. This cavitation causes an acoustical profile then can be measured using a near filed acoustic mic or by directly coupling a vibration intrrement to the case of the tyranny in this case.
    Usually this type of instrumenting is focused on high frequency noise because it is much easer to detect and measure then low frequency which are more "felt" then heard....
    Most peopel use the tearm Cavitation to refer to the physical manifestation (AKA the vibration) to discuss Cavitation rather then the actual fluid dynamics and fluid mechanism that cause the physical effect.
    Do I need to go on:p:D
    TO insult someones intelligence on a forum is just a waist of time.
    the person you insult my even be a PHD and an expert in his or her field.
    OK back on topic
    My locking up I mean that there is sufficient fluid flow from the stator/pump to the rotor to start coupling the input torque to the output shaft.
    However since the breaks are in gauged the output shat is incapable of turning. AKA there is a stall condition.
    Therefor the hi pressure of the fluid flow flows backward ( as apparent by the Cavitation/vibration and frequency ) transmited throught the housing and into the motor back throught the motor mounts and then eventualy being felt by the operator.
    And I do not have the the AC on or the truck in Defrost mode. The heater is not even on. Its in vent mode and fan speed is off.
    O and go read the 2010 manual ( you can turn of the AC when in defrost mode) on the 2010.:D
  16. Dec 19, 2009 at 9:26 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    It can also lock when accelerating, or maintaning a set speed/throttle position.
  17. Dec 20, 2009 at 8:13 AM
    350TacoZilla
    Hancock MD
    well here is my input on the eradic idle, I have been in probably 20 tacomas from 95.5 up to 07 or so and every single one with a auto trans does that.. feel like someone bumped you sitting at light, not sure why they do it but my gfs dad has one with over 200K on the auto trans no issues to report and it still does it to this day
  18. Dec 20, 2009 at 7:25 PM
    Isthatahemi
    TRD OFF ROAD
    And I'm a rocket scientist. I've never heard of cavitation being substituted for vibration, it's just an incorrect use of the word, and makes your original post confusing. Oscillation or vibration is not only simpler, it is correct. The torque converter is not cavitating by your own definition.
    A waist hunh?
    intrrement?
    tyranny?
    It's on by default, that was my point.
    This is entirely pointless.... a mechanical engineer is asking why his torque converter is locking up and ....... oh whatever, you're the engineer.
    And pressure does not backflow in a torque converter, it goes static.
    And the torque converter is connected to the input, not output shaft....
    Whatever, you're the engineer......The vibration is from the engine, not the torque converter, or the "tyranny"
    And the "breaks" are not "in gauged".....
  19. Dec 20, 2009 at 10:53 PM
    mugenrios2k
    posting while drunk is never a good idea lol
    I all ready have my answer its normal and nothing to be concerned about.
  20. Dec 21, 2009 at 4:44 PM
    Isthatahemi
    TRD OFF ROAD
    already....
