New 2010 OR DC 4x4 issues
Discussion in '2nd Gen. Tacomas (2005-2015)' started by biborado, Dec 23, 2009.
  1. Dec 23, 2009 at 4:41 PM
    biborado
    biborado [OP] Well-Known Member
    Stephen
    San Diego, CA
    2010 TRD Off-Road 4x4
    So i got a white DC TRD Off-Road 4x4 with the JBL package and i noticed a few things with the truck.
    One, the little net thing that goes inside the center console/arm rest and the one behind the rear passenger side seat back are missing. Dealer said "oh...only some tacomas come with them" wtf? I thought i was getting the top of the line tacoma with all the options? Does that sound right? Or do they all come with them. Also, what other items may i be missing that they failed to supply me?
    The other issue was with the brakes. I didn't realize that the OR 4x4 comes with a different brake master cylinder/booster setup and i was complaining the entire test drive that the brakes felt very hard and perhaps there was air in the lines or something. They didn't have another one like that on the lot to compare to, but they assured me that it was fine. I looked under the hood and found out why the pedal felt different with a quick glance at the master cylinder, however i found that the brake fluid cap looked like it had leaked and there was a little fluid collecting on the resevoir. I test drove another one like mine at another dealer and the brakes felt similar, but is that hard pedal feel normal? I have no idea how any brake fluid could have leaked out, but its full, so i guessss i can't complain. Anyways, the brakes require more effort to get the car to stop than i'm used to with the standard vaccuum systems, just curious if thats normal? If i push down hard enough and keep my foot on it with constant pressure, the car does come to a hault pretty quickly. I may go in with my truck and just compare with another one side by side when they get one in.
  2. Dec 23, 2009 at 4:43 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Welcome to TW.
    I think the corgo nets are taken by some dealers. Mine came with them. Brakes sound normal.
  3. Dec 23, 2009 at 4:47 PM
    grdnrxr
    grdnrxr Well-Known Member
    Back in Hawaii
    TRD Sport Prerunner
    Mine had no nets or floormats.......
  4. Dec 23, 2009 at 4:56 PM
    braggman7
    braggman7 Well-Known Member
    GA
    '23 Trail Edition
    I got the one behind the seat but not in the console... never knew there was supposed to be one in the console.
  5. Dec 23, 2009 at 5:03 PM
    comatosed
    comatosed Well-Known Member
    Central Florida
    Silver TRD Sport
    TRD roof rack, Roof Basket, Weather Tech liners, Wet Okole seat covers, bed mat, AFE Pro Dry Filter, Eclipse AVN726E dvd/nav, kicker door speakers, 8" kicker sub & amp, fox 2.0 coil overs, moab 2.0 front bumper, Full CBI Skid Set, CBI Offroad rear Bumper, CBI Sliders, BFG AT KO 2, Leer Topper setup for camping. Other mods-full synthetic, carbon filter, de-badged, center console lock.
    I thought the brakes felt a little soft on my sport honestly. I don't have a single net in my truck.
  6. Dec 23, 2009 at 5:06 PM
    dexterdog
    dexterdog My pee parts itch
    Oly WA
    2012 F150
    My nets were in the storage compartment under the rear seat.
  7. Dec 23, 2009 at 5:06 PM
    biborado
    Stephen
    San Diego, CA
    Ya I can feel the pump coming on and off to charge the accumulator. It will take some time to get used to, but i'm glad that its not an issue, but rather just how they come. I was worried at first that i got one with brake issues before i even got it out of the lot!
    I think i'm going to go back to the dealer and ask them to get me the two nets. Its the least they can do for chipping the hood where it meets the grill. It must have happened during them washing it is what i'm thinking because i looked over the entire vehicle prior to them washing it and it was flawless. Any other items i should ask for that should have already been "Standard equipment"? I did get these two connectors that are in the glove box which look like they are some sort of bypass for the backup camera.
  8. Dec 23, 2009 at 5:11 PM
    Incognito
    Incognito No better friend, no worse enemy
    VA
    2012 Pyrite AC TRD OR
    Spacer lift, bumper stickers, ejector seat, etc.
    My brakes feel soft in the Tacoma at first, but by now I've gotten used to them... Nothing to worry about.
  9. Dec 23, 2009 at 5:24 PM
    OffroadToy
    OffroadToy old, forgetful, and decomposing
    Icon Stage 8, ECGS Bushing, Timbren bump stops, Crown braided/extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Sherpa Grand Teton/Crows nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights
    Mine came with the cargo nets and a flashlight holder for the storage area behind the rear seat. The tow package included a 7-pin adapter and wiring harness for trailer brakes. Make sure you have the 4 tie downs that fit into the rail around the bed.
  10. Dec 23, 2009 at 5:32 PM
    weidjd
    weidjd Well-Known Member
    '10 DC TRD OR 4x
    Saw COs/RR,TSB + 1.5AAl, LR UCAs
    Just got an '10 OR 4x today. I will have to go look at the nets and holders. The brakes are mine are also harsh, very touchy. Will get used them.
  11. Dec 23, 2009 at 5:35 PM
    biborado
    Stephen
    San Diego, CA
    I got the flashlight holder, and the 4 tie downs. I guess i will have to go back and check the rear seat for the other parts. I guess thats what the connectors in my glove box are. Its an adapter of some sort with directions in japanese mostly. I was really excited to drive the thing outta there that i didnt really bother to chekck and see what it was. :)
  12. Dec 23, 2009 at 5:35 PM
    TRICOMA
    TRICOMA Tacoma with the TRI package
    Tri
    Carlsbad, CA
    2010 Tacoma DC SB 4x4 TRD Off Road
    King Off-Road Shock Coilover 2.5 with Resi in the front. King Off-Road Shocks 2.5 with Resi's for the rears, Rear Spring TSB, KMC XD Enduros 16x8, Black Vinyl Fenders, Bed compartment locks, Cobra 19 DX IV with Lil Wil mag mount antenna, CoverKing Seat covers front and rear, Built Right UCAs, Aluminess Expedition Bumper, GY Wrangler MT/R with Kevlar 265/75-16, Custom hybrid style rock sliders.
    I asked my dealer to find me the net and they got it for me. Just ask your salesman...if they are cool enough they should find it somehow. I think they jack them though. I got both nets.
  13. Dec 23, 2009 at 5:38 PM
    outlawtacoma
    outlawtacoma Well-Known Member
    W. TN
    2018 T4RTRDOR
    i feel ripped off, I didnt get the net behind the back seat. sigh
  14. Dec 23, 2009 at 6:08 PM
    weidjd
    '10 DC TRD OR 4x
    No nets. Got the tie downs and FL holder.
  15. Dec 23, 2009 at 6:17 PM
    Dane-Taco
    Dane-Taco Well-Known Member
    Justus
    Wasilla, AK
    '10 Doublecab 4x4 TRD Off-Road
    Bilstein 5100s set at 0, OME 886 coils, Camburg Ball-Joint UCAs, 295/70/17 Nitto Trail Grapplers on 17x9 Moto Metal 957s, 2" Tuff Country AALs, SX8000 Gas Shocks (Rear), Homemade Satoshi Grill, Redline Hood Struts, Locker Anytime Mod, Map Light Mod, Diff Breather Mod, Fog Lights Anytime Mod, Extra Bed D-Rings, Sock's Badges and Decals, PIAA 520's, Illuminated 4x4 Switch Mod
    This is where mine were at. I didn't know I was supposed to get any nets, but i found mine tucked away beneath the jack.
  16. Dec 23, 2009 at 6:48 PM
    Krazie Sj
    Krazie Sj Resident Jackass
    Power Serge
    LV-426 (Acheron)
    07 TRD Off Road 4x4
    Borla Catback Exhaust, Snorkel, 33s on either 16's or 18's, ARB Bumper, All Pro LT w/Walker Evan Shocks front and back, All Pro expedition leaf pack, 10,000lb Superwinch, Intake Manifold Spacer, Bed Rack with ARB RTT, Rotopack and Hi Lift mounted, Husky Liner mats and an air freshener from 1995.
    Ditto.
  17. Dec 24, 2009 at 5:47 AM
    Canadian Max
    Canadian Max Yamaha
    In the Garage
    2010 TRD 4X4
    2010 TRD Sport 4 door Speedway Blue 4" Nerf Bars Vent visors Weathertechs Mats Hella 500 HID Mod Bull Bar Devil Horns Eclipse AVN 726E Energy Speakers
    X2
  18. Dec 24, 2009 at 6:03 AM
    swise
    swise TRIFECTA!!!
    ohio
    08 4x4 dbl cab, TRD offroad
    Thats an adaptor for the trailer harness.
  19. Dec 24, 2009 at 6:07 AM
    swise
    swise TRIFECTA!!!
    ohio
    hahahahaha ... I laugh because I had a huge problem accepting this damn tick at first. Drove me nuts. There are things you can do to make it much less noticeable, and mine is fairly quiet now. If I lean my head out the window and listen, sometimes I can still hear it while driving down the street.
  20. Dec 24, 2009 at 6:07 AM
    Canadian Max
    Canadian Max Yamaha
    In the Garage
    2010 TRD 4X4
    The salesman said it was a plug for the wiring to the Back up camera when the tailgate is removed ;)
