New 2012 relay noise under dash
Discussion in '2nd Gen. Tacomas (2005-2015)' started by nikker, Mar 18, 2012.
  1. Mar 18, 2012 at 9:41 PM
    nikker
    nikker [OP] Member
    Hey everyone just got a new dbl cab trd off road. I have had it three weeks and today it started making a noise under the dash like a relay click but it only happens after i first put it in drive and start to take off. It never did it before and am curious what it is. Any suggestions or help is appreciated!
  2. Mar 18, 2012 at 9:47 PM
    TrdSurgie
    TrdSurgie revised
    Oahu
    Mine doesn't click for ABS self check. It does make a hydralic sound tho.
  3. Mar 18, 2012 at 11:41 PM
    nikker
    nikker [OP] Member
    I guess thats what it may be. I just thought it was weird because it just started doing it but i know for sure that the sound is coming from right by my feet (right above pedals) and only happens after the truck is first started and after about 10 feet of driving forward after i put it in drive....
  4. Mar 18, 2012 at 11:43 PM
    TrdSurgie
    TrdSurgie revised
    Oahu
    Yup thats the ABS
  5. Dec 5, 2012 at 5:33 PM
    jaredpa28
    jaredpa28 Well-Known Member
    jared
    longmont, colorado
    2010 TRD Sport 4 Door Longbed
    1.Weathertec front and rear 2.Front windows tinted to match. (23%)? 3. Rear TSB 4. TOYTEC coil overs up front and Bilstein 5100's front and rear. 5. Sway bar relocate 6.Front diff drop kit 7. Skid plate drop kit 8.Light Racing UCA's 9. 265/70/17 Cooper Discoverer STT 10. backup camera mod. 11. wildernest 12. "yellow wire" mod
    Does anyone have an update or fix for this. Mine just started doin this. I dont think its the ABS self check because it will do it when i'm going down the road, put it in neutral, and turn the key off.
  6. Dec 5, 2012 at 5:41 PM
    SOSHeloPilot
    SOSHeloPilot My 1st Muscle Car
    U.S.A.
    2023 RAV4 XLE Premium
    Missing My Last Tacoma --- Had 11 Toyota trucks in the past and many other Toyota cars too.
    . . . Sub'd
  7. Dec 5, 2012 at 5:47 PM
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
    Normal. When you shut the engine off, you de-energize the relay, hence the sound. :p
  8. Dec 5, 2012 at 6:31 PM
    TrdSurgie
    TrdSurgie revised
    Oahu
    I assume you afe trying to save gas by turning it off and coasting?
  9. Dec 5, 2012 at 8:53 PM
    GoHuskers
    GoHuskers Well-Known Member
    Nebraska
    2012 White DCLB TRD Sport
    Yes, abs check. No worry. Happened the same on my former 2011 camry.
  10. Dec 5, 2012 at 9:07 PM
    Gincoma
    Gincoma Special Edition Member
    Salt Lake City UT
    RIPieces 2005 Tacoma, adios 2011 :'(
    Factory Monster Truck Package with reverse gear.
    Its normal happened on all 3 of my tacomas....I wouldn't lose sleep cause of it.
  11. Dec 6, 2012 at 12:34 PM
    jaredpa28
    jared
    longmont, colorado
    I turned it off to see if the noise was coming from something that required electricity. (I.E. a relay)
  12. Dec 6, 2012 at 12:36 PM
    jaredpa28
    jared
    longmont, colorado
    Went out today and pushed back and forth on the front driverside fender and heard the noise. I now think its something loose under the hood. Gonna investigate further this weeked.
  13. Dec 6, 2012 at 2:00 PM
    TrdSurgie
    TrdSurgie revised
    Oahu
    My fender to make alittle noise when i push on them. Poor factory fit.
