New 3.4L 1st gen double cab
Discussion in '1st Gen. Tacomas (1995-2004)' started by Jbull37, Feb 26, 2015.
  1. Feb 26, 2015 at 9:24 PM
    Jbull37
    Jbull37 [OP] New Member
    Tampa,FL
    02 PreRunner 2wd
    Hey guys, just got this baby! All ready added Bridgestone all terrain to it as well as plasti dipped the fenders in black! Trying to decide on what type of lift? I'm new at this so not too sure, I don't mind spending the money and I've noticed a lot of the posts have talked about the bitling 5100 lifts. I don't really need to go off roading but id like to sit a little higher than my preRunner stock is allowing. Which kit should I buy? I don't want any cheap spacer, so I need to by the coil over?' And do I also need to buy new struts and shocks? Any advice would be helpful! Thanks!
  2. Feb 26, 2015 at 10:05 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
