New 4x4 Tacoma Has Vibration When Braking
Discussion in '3rd Gen. Tacomas (2016-2023)' started by gwreynolds, Jul 14, 2018.
  1. Oct 14, 2020 at 7:51 AM
    #661
    JimmyoNY
    JimmyoNY Active Member
    Jim
    2019 Tacoma
    Why would you do that? I've been living with this issue for a year and a half. The dealer has "fixed it" by replacing the front brakes, then the rear. Each time it seemed better, but over time the vibration would return. I recently cleaned and lubed the rear brakes and retorqued the wheels. It seemed better for a while and now it's coming back.
  2. Oct 14, 2020 at 8:28 AM
    #662
    zoo truck
    zoo truck Well-Known Member
    2020 quicksand sr5 tacoma
    None
    Imo, its not the brakes. Appears to be in the torque converter.
  3. Oct 14, 2020 at 8:35 AM
    #663
    rlx02
    rlx02 ¯\_(ツ)_/¯
    Western WA
    2017 Inferno DCSB TRD OR 4x4
    Does anyone have this issue with just noise and not vibration? I get a bad squealing noise that goes with the rotation, but no vibration. Definitely coming from my right rear drum...I popped off the cover and everything looks fine in there, just a bit dusty.
  4. Oct 14, 2020 at 8:46 AM
    #664
    JimmyoNY
    Jim
    2019 Tacoma
    "Squealing" can just be dirt or grease on the shoes and drums. Which you can clean with brake clean and a clean rag. Sometimes shoes can get a glaze on them from overheating. You can sand them a little to clean them up. Also, from my experience, people often overlook that drum brakes have contact points where the shoes ride on the backplate that need lubrication.
  5. Oct 14, 2020 at 8:49 AM
    #665
    rlx02
    rlx02 ¯\_(ツ)_/¯
    Western WA
    I cleaned up the drum with brake cleaner before I put it all back together. It makes the noise even when my foot is off the brake...i'll try to upload a vid later.
  6. Oct 14, 2020 at 12:41 PM
    #666
    CaptainBart45
    CaptainBart45 Well-Known Member
    Bart
    2017 Tacoma Sport 4x4
    Work in progress...
    Well, don't actually slam the brakes on, but stopping in reverse should adjust the brake shoes. Back up slow and use the parking brake to stop a few times. Just make sure of what is behind you of course. As the late Mitch Hedberg said "I drove 10 miles with the emergency brake on. That don't say much for me, however, it says less for the emergency brake."
    verynearlypure and RickyBobby757 like this.
  7. Oct 29, 2020 at 6:57 PM
    #667
    Jessrin
    Jessrin Oh, okay...
    Jesse
    Upper Michigan
    24 Tacoma Double Cab TRD Off Road 4X4
    Stock
    I’m going to make all you guys really go mad.... put 400 to 500 pounds in the box. Then test drive. Keeping close attention to the shudder while braking. Yup! It’s not there. It’s gone. Smooth.
    cheers! :)
    turbosnail likes this.
  8. Nov 16, 2020 at 10:46 AM
    #668
    2019TacoFDE
    2019TacoFDE Active Member
    BC
    2019 DCLB OR in FDE
    Some of us knew this already. As little as 200lb at the rear of the bed completely eliminates the 25-15mph washboard shudder in my truck.
  9. Nov 16, 2020 at 10:55 AM
    #669
    2019TacoFDE
    BC
    2019 DCLB OR in FDE
    UPDATE:
    Toyota FINALLY admitted to me that they know this is an issue, but can't fix it because it is to some degree, inherent in the design. Field Technician and Service Manager are on record as "observing the exact driving characteristics customer described and experienced previously. No repair recommended at this time as characteristic also noted in new model 2021 on dealer lot." basically:
    3k mi - 30-15mph shudder. weight in bed eliminates it. vibe is worse with dive on decel- driveline angle related?
    7k mi - vibe is way worse, both rear axles and drums replaced by toyota - vibes gone
    11k mi - vibe is back, toyota "cant feel it"
    12.5k miles - f*ck em, I swap 5100's for stock 4600's up front, set to 1.1" lift - vibes almost totally gone.
    12.5-18k - vibes are very slowly getting more noticeable
    19k mi - i make a point to get a toyota field tech in my truck, and after 1 month and 3 dealer visits, I finally have the "yup, this shit aint right- but it aint wrong enough for us to fix again, yet. If it gets worse, regardless of your warranty status, bring it in and we will goodwill any repairs related to vibration/axles/drums/driveline. We have no concerns about the 5100's or Spidertax adapters relating to the issue." Whew.
    So, shit happens. Toyota knows this is happening but isnt swapping axles until its bad.
    From my experience, the ~25-15mph shake is reduced by weight in bed and/or lifting the front of the truck. 1.1" wasnt quite enough for mine, may go to 1.55 or throw some 1/4 spacers in there and see how she feels.
    Tacman19 likes this.
  10. Nov 16, 2020 at 11:32 AM
    #670
    BillsSR5
    BillsSR5 Looking out for #1
    bill
    2014 SR5
  11. Dec 29, 2020 at 2:43 AM
    #671
    Sworks99
    Sworks99 Well-Known Member
    Tony
    2021 Lunar Rock Tacoma TRD Pro
    Precision LED lights all around, Pedal Commander, Total Chaos bed Stiffners, Retrax Pro XR, Caliraised LED control panel. Raptor lights from Caliraised.
    Damn reading 32 pages of this thread is bumming me out. I just got a 2021 TRD PRO and have the shaking during highway speeds. started noticing it right away at mile 5 but thought maybe it was normal for tacos. I had a friend of mine test ride mine since he has a 2020 offroad and he said nope mine does not do that and I drove his truck he was right it is not normal. I read up on how to bed the pads and tried that but it is not working. I made an appointment at the dealership. Will keep this thread updated.
    Jessrin likes this.
  12. Dec 29, 2020 at 2:57 AM
    #672
    DTaco18
    DTaco18 Well-Known Member
    2025 TRD SPORT DCSB 8AT CSM
    New TSB from a different thread...
    07tacomaVT likes this.
  13. Dec 29, 2020 at 7:22 AM
    #673
    07tacomaVT
    07tacomaVT Well-Known Member
    18 TRD Sport 4x4
    @DTaco18 thank you for that info. I just scheduled to have my 18 TRD Sport looked at.
  14. Dec 29, 2020 at 7:34 AM
    #674
    badkids
    badkids Well-Known Member
    ‘83 Hilux with a 2JZ
    Nice, only for autos. So manual owners can get shit that this tsb doesn’t cover them. Ha.
  15. Dec 29, 2020 at 10:29 PM
    #675
    The_vue's
    The_vue's Well-Known Member
    18 cement
    Anyone confirm fixed on this new tsb? Doing my recall and I have a list of tsb to be done
  16. Dec 30, 2020 at 3:01 AM
    #676
    DTaco18
  17. Feb 10, 2022 at 2:01 PM
    #677
    Jenpurcell8
    Jenpurcell8 New Member
    2022 red sr Tacoma
    I just purchased a 2022 SR Tacoma with a factory installed lift. The truck shakes when stopping. I notice it more when stopping from higher speeds. It has 1800 miles on it and I’m taking it to the dealer on Saturday. Has anyone found a fix for this issue? Thank you in advance for your help!!
  18. Feb 10, 2022 at 2:17 PM
    #678
    AZPhys13
    AZPhys13 Well-Known Member
    2021 TRD OR DCLB - MGM
    Only really notice vibration when lightly braking right around 40-45mph. It's so consistent that I will be stopping for a light, feel the truck start to shake, look at the speedometer and see the needle passing through the 40-40 range.
    Seems to be getting worse over time.
  19. Feb 10, 2022 at 2:21 PM
    #679
    Genypig
    Genypig Well-Known Member
    Yev
    2018 Tacoma TRD OR
    I made a post sometime in 2019 where I described my experience with the vibrations. Long story short, my drum brakes were completely replaced. Warped drum enclosures caused the vibration/jumpy feeling when braking.
    Initially, Toyota had tried other things but this is what ultimately fixed the problem. About 30K miles later, no issues. Hope that helps.
    nl_tacoma and bldegle2 like this.
  20. Feb 11, 2022 at 5:18 AM
    #680
    nl_tacoma
    nl_tacoma Well-Known Member
    Newfoundland
    2018 Tacoma TRD Sport DCLB
    Same experience as Genypig on my 2018 TRD Sport. Within first 20K km if I remember correctly.
    First service appt, dealer machined a front rotor. Brough back and then they replaced both rear drums. 10K km later they replaced brake drums again. 2 years later, and another 50k KM, it's been fine. Service guy said it wasn't a common issue. Parts guy laughed when I asked him if he's been going through brake drums. He confirmed that and said it's almost like Toyota had a bad batch of drums.
    You'd think Toyota would have that sorted by now.
    Shades_Of_Red likes this.
