New 8.75" rear axle in non-trd?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Sep1911, Jun 20, 2016.
  1. Sep 16, 2019 at 1:32 PM
    #41
    TireFire
    TireFire Superunknown Member
    Olympic Peninsula
    On paper yes but there’s no telling your axle is goin to break. If I were you I’d use it and upgrade if and when things break.
    FYI, if you get one of those coveted TRD E-locker axles you’ll likely save a LOT of money over the expense of open axle plus ARB.
    With the ARB you will also need an air compressor that will need 12v or just wire 12v to the elocker instead. Just something to ponder. I always prefer the route that needs less parts so there’s less that can fail
  2. Sep 16, 2019 at 1:50 PM
    #42
    B.Peak
    B.Peak Well-Known Member
    Brian
    SWFL
    '19 Tacoma TRD Sport 4X4
    '19 Tacoma TRD Sport 4X4, Premium and Technology Packages OME-888 Coils w/ OME-90021-P Nitrocharger Sport Shocks- softer valving ToyTec .5" Top Spacer OME-EL095R-P Rear Leaf Pack w/ OME-60091-P Nitrocharger Sport Shocks Eibach 1" Lift Block OME Upper Control Arms OME Driveshaft Carrier Bearing Drop Kit ToyTec 1" Diff Drop ECGS Clamshell Bushing 18X9 Enkei RPT-1, 0 Offset on LT305/65R18 TOYO Open Country M/T 2020 OEM Limited Grill 2020 OEM Limited Fog Light Bezels MESO Stage 1 Total Tail Light Kit All Interior and Exterior lights replaced with Diode Dynamics LEDs TRD Cat Back Exhaust Passenger Door Smart Key Mod
    But from what I read, nobody has been able to wire the OEM e-locker to a non OR. Is that what you are saying to do?
    GreyBaldTaco and tonered like this.
  3. Sep 16, 2019 at 1:54 PM
    #43
    TireFire
    Olympic Peninsula
    Yes that is what I’m saying. Check out this thread:
    https://www.tacomaworld.com/threads/2017-e-locker.585669/page-5
    Guy did it very meticulously so you don’t have to blaze trail.
    Probably could do it simpler with just a relay and a switch also.
    shakerhood likes this.
  4. Sep 16, 2019 at 2:06 PM
    #44
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    I was following that thread a bit until it got complex with controllers trying to mimic the OEM signals. Did the whole thing simplify down to a single resistor? I don't see much jumping out between the processor design then just pics of a resistor.
    GreyBaldTaco likes this.
  5. Sep 16, 2019 at 2:30 PM
    #45
    Grossomotto
    Grossomotto Complete 3rd Member
    39.9526° N, 75.1652° W
    2017 4WDV6LB6MT
    Air lines are easy. The only place it would leak internally is the Oring which can be replaced. Keep PSI at or below 100 and nonLSD fluid. I’ve read where the LSD additive compromises the rubber rings.
  6. Sep 16, 2019 at 2:37 PM
    #46
    anthony250f
    anthony250f Well-Known Member
    Anthony
    San Diego, CA
    2008 dcsb trd offroad 4wd
    Not easy to replace the o-ring on an arb
    TireFire likes this.
  7. Sep 17, 2019 at 3:23 PM
    #47
    Sep1911
    Sep1911 [OP] Well-Known Member
    2016 Taco
    The OEM method was for reliable and consistent engagement and disengagement according to the patent.. realistically giving it 12v will work there might just be times where it will take longer to engage and disengage
    tonered[QUOTED] likes this.
  8. Sep 17, 2019 at 4:01 PM
    #48
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Sweet! With coming to a full stop and waiting with 4Lo, waiting on a locker would be no big deal.
    Ideas!
  9. Oct 17, 2019 at 4:24 PM
    #49
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    There are no 2 wheel drive MT's in the 3rd Gen.
    tonered likes this.
  10. Oct 17, 2019 at 4:27 PM
    #50
    TireFire
    Olympic Peninsula
    Waaaaat? So the TRD sport can’t get a manual?
  11. Oct 17, 2019 at 4:38 PM
    #51
    shakerhood
    Southern Ohio
    You can get a Sport Manual, but only in 4x4, Sport 4x2 are all AT.
    tonered likes this.
  12. Oct 17, 2019 at 5:35 PM
    #52
    TireFire
    Olympic Peninsula
    o_O
    4x4 isn’t that TRD off-road or SR5 it no locker is needed
  13. Oct 17, 2019 at 5:52 PM
    #53
    Jeff Lange
    Jeff Lange Well-Known Member
    Calgary, Canada
    '86 AE86, '05 NCP13, '11 GSE21
    Just read through this thread and wanted to add a couple thoughts.
    1. Yes, all manuals have the 8.8” diff, and yes, all manuals are 4WD.
    2. The 8.8” rear ends do not share the same axles. The 8.0” axles are still the same though (2005-2020).
    3. The e-locker in the 2016+ 8.8” axle is probably the easiest to wire up factory e-locker from Toyota ever. It literally just needs power and ground to lock unlike most other factory lockers which have position switches and controllers. Yes there is some logic in the factory setup to determine when it will let you lock up, but if we’re talking about retrofitting a locker, wiring up the 8.8” e-locker is easier than any aftermarket locker on the market I am aware of.
    8.8” axles are available with 3.91:1 ratio with locker (TRD OR/Pro AT) and 4.30:1 with (TRD OR/Pro MT) or without locker (L4 and V6 MT)
    Jeff
    tonered, TireFire and shakerhood like this.
  14. Oct 18, 2019 at 8:05 AM
    #54
    TireFire
    Olympic Peninsula
    Good summary. Harrop locker is just as easy because it’s also just an electro magnet but not yet available for the 8.75 axle but I have it in my 8.4
  15. Oct 18, 2019 at 8:10 AM
    #55
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    That bit is interesting, and now that you say it, it has been there all along.
    shakerhood[QUOTED] likes this.
  16. Oct 18, 2019 at 8:13 AM
    #56
    TireFire
    Olympic Peninsula
    It’s dumb. TRD sport should be 2wd MT
  17. Oct 18, 2019 at 8:14 AM
    #57
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    I'm a bit confused about that post (I have no room to talk though :D ). 4x4 Sports are pretty common. Seeing 2wd around here is rare though.
    Also, no MT SR5s these days and no SR MTs after 2017.
  18. Oct 18, 2019 at 8:16 AM
    #58
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Sorry, but no. Xrunner, sure. The Sport is the only way to get a LB MT. If there was an OR LB MT, I would have gone that route though.
    Edslittleworld likes this.
  19. Oct 18, 2019 at 8:19 AM
    #59
    TireFire
    Olympic Peninsula
    Damn, shitty options for third gens.
  20. Oct 18, 2019 at 8:21 AM
    #60
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    That is the truth. For an MT, you have to grab what it available. I was happy that I had three LB MTs to choose from when looking.
    It was harder looking for a used 2nd Gen LB 4x4 MT. The few that I could find at the time were either SR or Sport.
