New Accessory Belt TSB
Discussion in '3rd Gen. Tacomas (2016-2023)' started by tonered, Dec 2, 2020.
  1. Dec 4, 2020 at 9:00 AM
    tonered
    tonered [OP] bartheloni
    tony
    Lynnwood, WA
    1/4 of the time to search out a TSB and sprint to the parts counter?
  2. Dec 4, 2020 at 9:00 AM
    5nahalf
    5nahalf I build dumb things
    Erik
    Minnesota
    2018 Inferno Longbed
    Time units are based on 100 times units to the hour. so .2 is around 12 minutes yes.
  3. Dec 4, 2020 at 9:06 AM
    dilbert
    dilbert AI Member
    PNW
    2019 DCLB TRD Off-Road
    The radio software update TSB gives them .3 (18 minutes). I think is strange that they get paid less for replacing the belt than for updating radio software.
    ktbell444 and tonered[OP] like this.
  4. Dec 4, 2020 at 9:10 AM
    tonered
    tony
    Lynnwood, WA
    And, that H/U FW update is pretty damn long also.
    If we're comparing, the WOs that I have seen for TSB tune flashes are 0.4hrs. That is a 10min or less process.
    dilbert[QUOTED] likes this.
  5. Dec 4, 2020 at 9:14 AM
    dilbert
    dilbert AI Member
    PNW
    My tactrix cable gets delivered today (a day early) - I'm guessing the TSB tune flash will take me at least 30 minutes since I'm paranoid and will be double checking everything.
    :fingerscrossed::pccoffee:
    tonered[QUOTED][OP] likes this.
  6. Dec 4, 2020 at 9:19 AM
    tonered
    tony
    Lynnwood, WA
    That is a very reasonable expectation. I was in those shoes when I did the 04B13 flash with a borrowed adapter.
    If you're SUPER paranoid, I found that my jump pack in non-boost mode (just hooked to the battery and turned On) did a great job of keeping the volts up for the entire flash.
    There is a TSB with just flashing instructions attached to the ECU Update 1st Post that talks about that.
    One small, good thing is that TS will not launch the process if the volts are under a certain threshold. I can't remember exactly. Something around 11.0 or 11.5?
  7. Dec 4, 2020 at 1:19 PM
    gmtech
    gmtech Well-Known Member
    quad cities illinois
    2016 trd or. 2024 trd OR iforcemaxx!!
    Stock AF
    ok 12 minutes.. im not familar with those other things. being toyota talk and i do GM.
    you must understand though. we are only paid on what we do. so that job paying .2 includes getting the vehicle. going to parts counter and waiting for part.... .... geting part. installing on vehicle... doing free inspection.... and pulling car/truck out. lots of stuff happens during the day and just cause the job is easy and u may have app. doesnt mean it gets worked on first ..
  8. Dec 4, 2020 at 3:54 PM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    Yeah EricTheCarGuy had several videos ranting about dealership life... I just had a question specifically about the time codes in the TSB. As I understand, warranty work pays shit across all the brands. At least with Toyotas, a greater portion is out-of-warranty work compared to GMs (and European brands).
  9. Dec 4, 2020 at 4:45 PM
    mattleg
    mattleg Well-Known Member
    Kansas
    2020 OR DCSB AT 4WD
    To help with these VIN codes:
    10th digit is model year, K is a 2019 model year, L is for 2020
    11th digit is the build plant, X is Texas built, M is Baja
    mbarbay and ktbell444[QUOTED] like this.
  10. Mar 4, 2021 at 6:36 PM
    Swartzy165
    Swartzy165 Well-Known Member
    Nashville, TN
    2023 CM Tundra // 2020 MGM ORP T4R
    I took off an air dam once
    Awkward moment when my belts started chirping and i had them replaced under this TSB :anonymous:
    davidstacoma and tonered[OP] like this.
