New aftermarket hu, but less bass??
Discussion in 'Audio & Video' started by blacksandtaco, May 21, 2009.
  1. May 21, 2009 at 3:02 PM
    blacksandtaco
    blacksandtaco [OP] Well-Known Member
    Tyler
    Kansas
    07 Access TRD Sport 4X4
    Viper remote start/alarm, Kenwood Excelon DNX 9140 in -dash Nav and DVD, Anzo black headlight, FoldaCover tonneau cover, BedRug carpeted truck bed, Pop-A-Lock electric tailgate lock, Level 8 MK6 (16x8), Toyo Open Country AT2 (LT265/75R16), Fold-A-Cover Tonneau, Bilstein 5100s front, Rear Leaf Suspension TSB, AVS in-channel front window vents, AVS Aeroskin hood protector,
    So I'm sure you all have seen my many posts/threads and I apologize if I'm becoming a nuisance. By now I'm sure you know that I just installed the new Kenwood DNX7140 in my 07 access cab. I installed nothing else, no new speakers, no amplifiers, just the head unit. I still have the factory 6x9's and tweeters in the front doors and the 6.5's in the access doors. I have noticed a considerable reduction in the bass output from the kenwood when compared to the factory head unit. Has anyone noticed this same issue? It seems like the 5 band graphic eq on the kenwood is far worse that the basic bass/treble function on the factory head unit. I don't think I hooked anything up incorrectly. All thoughts are appreciated.
  2. May 22, 2009 at 8:24 AM
    4x4Taco
    4x4Taco Well-Known Member
    Ontario
    07 TRD Off-Road 4X4
    You have to go into the menu and adjust the bass setup...I cant remember the menu to choose now. I have a seperate amp but the menu options on the DNX setup give you quite a bit of flexibility over just using the eq settings....there is a custom or user definded setting in which you can set all the ranges seperatly. You will need to do that to get your bass back.
  3. May 22, 2009 at 8:26 AM
    4x4Taco
    Ontario
    07 TRD Off-Road 4X4
    Also I found the factory speakers much louder on the DNX head unit. Esp.. if you remove all the bass and use a seperate amp/sub and use the factory speakers for mids and highs only so all the head unit power drives mid/high.
  4. May 22, 2009 at 10:00 AM
    blacksandtaco
    Tyler
    Kansas
    I've gone into the audio control setup and adjusted the bass boost to full and turned the bass extension on so it picks up lower frequencies. I've also gone in and set the high pass crossovers to produce 30hz and above and have a 6 db slope. I've tried everything and can't seem to figure it out. I didn't see anything in the menu specifically that allowed to adjust the bass by db however. I plan on upgrading to kenwood excelon mids, highs and subs with kenwood amps in the future but for time being it would be nice to have a little more like I was used to with the factory head unit. I appreciate your suggestion but I think I've just about tried everything to no avail. I'm wondering if maybe I got the wires mixed up when I connected the harnesses or if I should have connected wires that I didn't. I only left the brown mute, blue power antenna and blue and white power control wires unconnected.
    Can you be more specific about the custom/user defined settings to adjust them separately?
  5. May 22, 2009 at 10:22 AM
    m_yota
    m_yota Well-Known Member
    Paradise
    08 4x4 dbl cab
    K&N airfilter, HID conversion for headlights/fogs. Wet Okole Seat covers, Kove Aphex processor Kenwood comp 6.5" and 6.5"coaxial 5100 billy shocks 2.5", 1.5" fabtech AAL,Epicenter and MTX Sub, debadged, tinted, kenwood dnx812, black mesh grill, led ext/int.
    My wifes Highlander has the dnx512 and the bass is all there with the factory speakers. The speakers are pretty much crapping out in higher volumes. You just need some patience and just play with it. What kind of musics are you playing? :D
  6. May 22, 2009 at 10:26 AM
    4x4Taco
    Ontario
    07 TRD Off-Road 4X4
    I will have a look at my menu on the weekend as I cant for the life of me remember the tabs. Set it up a while ago and never touched it again.
  7. May 22, 2009 at 11:00 AM
    blacksandtaco
    Tyler
    Kansas
    Thanks again for your suggestions. I do have some bass, just not nearly as much as before and one would think that a $1,000 head unit would be able to produce the same if not more bass than a factory installed head unit. I could turn my bass setting to +3 (out of +5) and get tons more bass on the factory than maximizing everything on the kenwood. I usually listen to rock and hip hop, but the hip hop doesn't even pound like it used to.
    4X4 - I'm interested to hear what you have to say after looking at your setup over the weekend. I appreciate your feedback.
  8. May 24, 2009 at 8:53 AM
    bass mechanic
    bass mechanic Well-Known Member
    colorado springs, colorado
    2009 tacoma Access cab TRD offroad in black
    none
    ill bet you 100 bucks you have 1 of the front speakers wired backwards. the easist way to tell is to move the balance from left to right and if you have more bass with 1 speaker than with 2 your have one of them wired backwards or out of phase
  9. May 24, 2009 at 12:07 PM
    mikey05
    mikey05 Member
    05 DC Shortbed
    Too many to list
    Could also be due to the extra output from the new HU. At a lower volume you might produce more low end but as the volume increases distortion will so the increase in scale on the low end frequencies will seem as if you have lost bass. If that makes any sense.
  10. May 24, 2009 at 1:01 PM
    sooner07
    sooner07 1/2 man 1/2 amazing
    A A Ron
    DFW, Texas
    Debadged 2008 Rugged Trail
    Always working on the stereo, painted the front skid plate black to match the truck, debadged , toy tech ultimate lift kit, light racing UCAs, ARB bumper Looking into a supercharger and new exhaust.
    I'm not following you here.
    I'd lean towards the phasing issue. But also remember that the stock HU is tuned to produce more low end at low volumes and less at higher volumes. If you listen at a fairly low volume, it may be that the stock HU was producing a less balanced sound than the new HU.
  11. May 24, 2009 at 3:21 PM
    blacksandtaco
    Tyler
    Kansas
    It makes sense that stock head units are tuned differently to produce more bass at lower volumes. I'm wondering if one of the plugs that used to connect to the stock head unit not being used on the kenwood has anything to do with it. I didn't see anything to attach it to from my Scosche wiring harness. I will check that plug and list the wire colors to see if anyone else has hooked it up differently. Right now it doesn't connect to anything. I will also check the wiring connections but I'm fairly certain they are right. If they are right I guess I'll just have to live with it until I get the subs in.
  12. May 24, 2009 at 4:12 PM
    mikey05
    mikey05 Member
    05 DC Shortbed
    Too many to list
    I have the dnx 7100 older version and I have tuned it but there is a little less bass. I put myself through college in a car audio shop in Texas and always saw a reduction in bass output when the hu's were changed. Stock speakers are tuned for a certain amount of power output. Not designed for the higher output of a replacement. I think IIRC the stock output is only around 12 claimed watts. New HU's typically are around 25. That is why you get increased volume but also more distortion at the higher end.
  13. May 24, 2009 at 5:05 PM
    sooner07
    A A Ron
    DFW, Texas
    Ok, odd question. Is your stock setup the JBL one with the funny looking sub in the back?
    I didn't see it mentioned anywhere, so just want to rule that out as a possibility.
  14. May 25, 2009 at 9:12 AM
    blacksandtaco
    Tyler
    Kansas
    As far as I know there is no JBL system. The window sticker from my original purchase said nothing about JBL and it is only a single disc cd player. The bass on the kenwood is a lot cleaner and doesn't distort, but it's also not near as loud as the stock and I dont' seem to notice as much of an increase when adjusting the different options one level at a time like on the stock. Before I could increase the bass from +1db to +2db and would notice a huge difference. Now increaseing from +3db to +7db on the 62 hz band from the EQ doesn'm seem to make any difference at all. I'm getting ready to yank out the deck to make sure the speakers are wired correctly. I'll take a look at the plug that is not being used and list the the number and color of wires to see what others have done with it.
  15. May 25, 2009 at 9:22 AM
    toyotacoma
    toyotacoma Member
    Fort Collins
    07 Prerunner SR5
    Kenwood Excelon X-592 Custom TRD Badges
    I have the same problem with my kenwood although it is a different model.
    It is louder but just not as much bass =[
  16. May 25, 2009 at 9:37 AM
    GoBlueFan
    GoBlueFan Well-Known Member
    Jon
    Bossier City, LA
    08 SR5 PreRunner
    Step bars, billet grill with custom TOYOTA, MB Quart RSI 216 components, Hifonics ZXi 4410, RAAMmat deadened doors/back wall/roof covered with ensolite , 24" Magnaflow muffler, hand polished stock exhaust tip, tinted, OEM TRD Bilstiens all around with 1/4" spacers up front to level it out. Sport wheels added.
    It sure sounds like it's out of phase....did you try adjusting the balance back and forth to see if the bass response increased yet? That is the easiest way to see.
    When it's wired out of phase, the lower freq's cancel each other out and don't seem as loud. So when you adjust the balance to one side, there is nothing canceling out and it sounds like an increase in bass response.
  17. May 25, 2009 at 2:10 PM
    blacksandtaco
    Tyler
    Kansas
    Pulled everything, checked all the connections and speakers are hooked up fine. Tested the balanace for phasing to see if noticeable bass when shifting from left to right and no difference. Also looked at the harness that wasn't being used. It has 3 wires. One red/white, one purple/white and one black/yellow. This harness was attached to the stock head unit but is not attached to the kenwood. I don't think this is an issue because I tested the stock head unit with it plugged and unplugged and no differences.
    Let me restate that there is "some" bass with the Kenwood unit. And by no means does it sound "bad". I just quesiton whether the internal amp on the Kenwood is as high quality as normal aftermarket head units. I also question whether the 5-band EQ is as efficient for bass output as the basic bass and treble settings of a stock head unit. I know it is supposed to be more customizable and better for fine tuning when you have multiple frequencies that you can adjust, but even with all the bands set to the highest level, still not as much bass. There are so many options for adjusting audio settings on this kenwood that I can't help but think that I just haven't found the right settings yet or that the internal amp doesn't produce the same bass as the stock. From what I understand, stock head units on newer vehicles are made to produce a lot of bass because they aren't able to power external amps and subs. Maybe Kenwood's internal amp is made to produce cleaner sound and signals while allowing for additional bass via an external amp.
    I'm truly baffled by this. Maybe I should just be happy with what I have, but I'm a perfectionist by nature and this aggravates me. Thanks to everyone for the advice and information.
  18. May 25, 2009 at 5:50 PM
    NMG
    NMG Well-Known Member
    Ottawa
    09 Double Cab TRD Sport
    Is it possible that the stock HU is biased towards a boomy presentation, with exaggerated bass tones (and maybe even gaps in the mids and highs), whereas the Kenwood is biased towards a more natural and balanced presentation?
    Sometimes just because something sounds like it has less bass, doesn't make it so. Perhaps what you are hearing is not less bass but MORE mids and highs to go along with the existing bass, thus making it appear like there is less because it isn't so pronounced (by lack of the other frequencies). You may just need time to adjust to the new sound.
    Just another thought.
  19. May 25, 2009 at 6:27 PM
    blacksandtaco
    Tyler
    Kansas
    NMG, I've often thought that same thing. Although I'm sure that's the answer to my issue, the pessimist in me isn't satisfied with that resolution :)
  20. May 25, 2009 at 6:50 PM
    NMG
    Ottawa
    Well there is only one solution . . . SUBS :D:D:D
