New Alcans installed this weekend with my RCD
Discussion in 'Suspension' started by sandjunkie, Jun 25, 2012.
  1. Jun 25, 2012 at 8:30 AM
    sandjunkie
    sandjunkie [OP] Well-Known Member
    Aaron
    OC
    I ordered custom Alcans which took about a month to get and about another month to get the time to do the install. I ordered them with 4 inches of lift and stock carrying capacity. They also included a torque spring to make sure the axle wrap went away. These things are soo buttery smooth. It's awesome. Vibration and Driveline thunks are non existent. Bumps in the road that were harsh and I could feel the bumpstops hitting on occasion are now taken with ease and no ill shuddering from the truck. All in all well worth the $600 investment. This is how the lift should have been done from the start.
    Stock Leafs with 4 inch Block
    Stock vs Alcan
    Alcan ready for U-bolts
    Alcan Springs
    Straight off the jack stands. It has settled to near perfectly level.
  2. Jun 25, 2012 at 8:31 AM
    memario1214
    memario1214 Hotshot Offroad Moderator Vendor
    Colton
    Missoula, MT
    SOLD - 05 Dub Cab TRD Sport 4x4, CURRENT - '21 Tundra MGM Limited
    A badass truck gets even more badass...
  3. Jun 25, 2012 at 12:32 PM
    sandjunkie
    Aaron
    OC
    Thanks Man:D
  4. Jun 25, 2012 at 12:36 PM
    medic2230
    Murph
    Bama! Roll Tide
    That looks awesome man!!!! I like those wheels!
  5. Jun 25, 2012 at 1:47 PM
    JTaco386
    JTaco386 Well-Known Member
    JT
    San Antonio, TX
    13 DCSB TRD Sport 4x4
    I want those!! I have to save up some $$. The lift, tires, wheels, and installation set me back.
  6. Jul 21, 2012 at 5:49 AM
    achojerr
    achojerr Active Member
    Jerid
    Boyce
    TSS 4X4
    I am going to order the kit and springs at the same time
    So two thumbs up?
  7. Jul 21, 2012 at 7:24 AM
    sandjunkie
    Aaron
    OC
    Good choice!;)
  8. Jul 21, 2012 at 4:59 PM
    achojerr
    Jerid
    Boyce
    TSS 4X4
    I looked on the Alcan website. Of course those are custom built springs. I was wondering exactly what did you tell them? You need springs that will work with the RCD lift or you told them how much lift you wanted from the springs?
    Do you think that the All Pro 3" lift springs would leave the truck sagging in the back?
    And one more question. I have seen your build and did you paint the red on the wheels or is that some type of bracket?
  9. Jul 22, 2012 at 12:18 AM
    sandjunkie
    Aaron
    OC
    Tell them the same as Coley. 4 inch lift and a torque spring.
    The All Pro 3 inch springs will have the back in about an inch too low. The All Pro expos will probably sit about right but will ride more stiff than the Alcans.
    The red inserts come with the wheels and are stuck on with 3m tape.
  10. Jan 6, 2013 at 10:10 PM
    flatfeet
    flatfeet Well-Known Member
    Rob
    Hilo
    09 TRD Sport 4x4 DBL CAB
    RCD 4.5 lift, 18x9 BFD, 305/60-18 Mickey Thompson ATZ's, projector HIDs, TRD exhaust, AFE intake, onboard air, led dash mod, train horns.
    Sick! I want those next.
  11. Aug 3, 2013 at 5:34 AM
    hellsbay
    hellsbay Well-Known Member
    SW Florida
    13 PreRunner TRD OR
    Are you towing anything with your truck, and how much is the tongue weight? When you say you ordered the leaf pack for the stock carrying capacity, what does that mean exactly? Are you saying that you told Alcan to make the springs able to handle a 6,500 lbs. load?
  12. Aug 3, 2013 at 10:08 AM
    Lumpskie
    Lumpskie Independent Thinker
    New Hampshire
    '96, 4x4, v6, manual hub
    Toytec 16" coilovers with Tundra Bilstein 5100s, Light Racing UCAs, Alcan Leafs with Orbit Eyes, 12" Bilstein 7100 short Bodies, ARB rear locker, 33x12.5 Duratracs, CBI sliders, Bushwacker fender flares, self made front bumper, M8000, Vision X 6.7" Hi/Lo Beam HIDs, full skids, Inchworm dual case setup - 15º clocking
    The way to order springs from Alcan is to call them. Bill will ask about your vehicle
    When you tell him you've got a taco, he pulls up the stock spring specs. Then you tell him you want to pull a 4000lb trailer with a tongue weight of xxx lbs. He puts that into his file and bulds a spring with a rate to match.
  13. Aug 3, 2013 at 7:15 PM
    sandjunkie
    Aaron
    OC
    I have a small enclosed motorcycle trailer that probably has a 200-300 lb tongue weight. When I put the trailer on and load the bed the suspension drops about an inch. It works perfect. I told Alcan to give me a stock setup/specs for carrying capacity with 4 inches of lift and a torque spring.
  14. Mar 25, 2014 at 12:43 AM
    areghas
    areghas Active Member
    Cannon AFB
    6in ProComp lift, 33" tires.
    did you have to get longer shackles or stick with stock?
