New audio: Advice for setup?
Discussion in 'Audio & Video' started by BrannigansLaw, Jul 24, 2015.
  1. Jul 24, 2015 at 12:04 AM
    BrannigansLaw
    BrannigansLaw [OP] Active Member
    Charles
    San Diego
    04 4x4 TRD
    I am looking to do a little audio upgrade, but not spend toooo much. Just wanted to see if this setup I have below is decent, if they all work together, if I need anything else, or any additional recommendations.
    Deck - 217 - JVC Double din (Want something under 300 with bluetooth and a screen for back up camera)
    http://www.amazon.com/dp/B00PVBZ8A0...=UTF8&colid=F1UZI22V4POL&coliid=IDQXWYR5TT6PG
    Speakers- 53 - RF 3 way (Looking to spend around 50 or less, was just thinking of doing front 2? Will 6x8 fit and hook up to above deck without any adapters or harnesses?)
    http://www.amazon.com/dp/B001P88U12...olid=F1UZI22V4POL&coliid=I39G9TA5BX7155&psc=1
    Insulation- ? - Looking at fatmat, dynamat etc not sure which
    Back up camera- 25 - (Always wanted one, anyone have any experience with this and if it connects to deck?
    http://www.amazon.com/dp/B0092YMZJY...olid=F1UZI22V4POL&coliid=I2S02SAAUOOVRV&psc=1
    Thank for any input!
  2. Jul 24, 2015 at 12:37 AM
    Vigo
    Vigo WFO
    On a rock in the pacific
    '12 4 door
    stuff...
    I can't contribute to reviewing the products themselves, but those speakers aren't ideal for that deck. They consume more power than the deck can provide, and should be used with an amplifier. They are 65watt RMS, and the deck can probably push 45-50 watts max.
    Rockford has a lower level line called prime, which is more suited to running off the deck.
  3. Jul 24, 2015 at 3:23 AM
    BrannigansLaw
    Charles
    San Diego
    04 4x4 TRD
    Cool, thats exactly the type of input i am looking for. Im an audio noob, so i dont really know what matches what. The deck says 22 rms and 50 peak. For the speakers, should i find a pair that are as close to 22 rms as possible as long as it doesnt exceed the decks peak number? What should i really be looking for and be careful not to exceed? The rf primes looks pretty good and are cheaper too, so thats a plus!
  4. Jul 24, 2015 at 7:19 AM
    keakar
    keakar Well-Known Member
    karl
    louisiana
    its been forever since I kept up with audio but I thought speakers were only rated for max watts they can handle and not the required watts to run them?
    as I understood it to work, those speakers would be fine but you just couldn't crank it as high as a higher wattage deck could push them. so lets say a 25 watt deck with 100 watt speakers would work fine but it only goes to about 1/4 of the volume the speakers could handle even though that's still enough to not hear yourself talking.
    IE - you are fine as long as the speakers are rated to handle more then the watts put out by the deck because its better to have a speaker that can handle more then the deck puts out so you don't max out or even over power and blow them
  5. Jul 24, 2015 at 8:24 AM
    devinzz1
    devinzz1 Well-Known Member
    devin
    lewisporte Newfoundland
    96 extended cab sr5
    cxracing turbo, fic6, methanol injection, 5100s/eibachs, skyjacker leafs, rear 5125s, no-slip rear locker, 35" grabber x3, magnaflow muffler, throttle body spacer, retrofit headlights, trans cooler, bed lined exterior, excessive stereo etc...
    youl want a 2 or 4 channel amp to run higher wattage speakers. Youl find that the speakers will barely get loud at all before the deck maxes its power and starts distorting.
  6. Jul 24, 2015 at 9:34 AM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    2002 XtraCab TRD 4x4 v6 Auto Trans With Lots of Mods ADS COs w/Compression Adjusters Camburg Uniball UCAs Whiteline Lower Control Arm Bushings Kartek 7" Limit Straps Plastics Guy Front Bumpstops Custom Alcan Springs +800 lbs +3" ADS 10" Stroke Triple Bypass w/Resi Rear Shocks Custom Rear Shock Relocate All-Pro U-bolt Flip w/Timbren Bumpstops 4.88 Nitro Gears ARB Front Locker ARB Twin Compressor Gunmetal 16x8 SCS Ray10s 255/85r16 Maxxis Bighorns Limited Edition (Relentless) Elite Front Bumper Smittybilt X2O 10K Winch Diode Dynamics SS3 Sport Selective Yellow Fog Lights in the Bumper Diode Dynamics SS3 Pro 4,000K Driving Lights on the Bumper Mini D2S Projectors XB35 Ballasts + 4500K Bulbs Badland Sliders FrankenFab Tire Carrier Swingout bumper w/kitchen BudBuilt Front & Bellypan Skids BAMF Rear Diff Skid Whynter 65 qt. Fridge/Freezer CVT Mt Bachelor RTT Badland Custom Bed Rack GM 140 amp alternator Dual Northstar 24F AGM batteries BlueSea 7622 ML-ACR Battery controller Peak DBI Dual Battery Voltage Monitor Doug Thorley Headers Magnaflow 18" Muffler w/upstream CAT delete 13WL Brake Calipers Braided Steel Brake Lines AFE Pro Dry S air filter ScanGauge II OBDII Scanner Kenwood TM-71A Dual Band Ham Radio Larson 70CM/2M Antenna Uniden 520xl CB radio 3' Firestik Adjustable tip antenna Pioneer DEH-P9400BH HU Alpine Amps & Type R components (F) and coaxials (R) Wet Okole Seat Covers Weathertech Digital Liners Deck Plate Mod 1" Diff Drop Carrier Bearing Drop
    A 5x7 is whats in there now. A 6x8 may work without an adapter plate, it'll depend on the positioning of the speaker's mounting holes.
    This VVV
    OP, if it was me, I'd just swap in the new deck first and use your existing speakers to start. Unless one of them is blown, the new deck will improve things quite a bit. You can then save your pennies for a decent speakers and an amp that will push them.
  7. Jul 24, 2015 at 5:26 PM
    mtucker
    mtucker Tacoma addict
    Escondido, CA.
    03 Prerunner DC
    Replaced chrome badges with Sockmonkey black badges, painted billet grill black, K&N cold air intake, my corner light turn signal circuit, Speedfreek traction bars, RAAMaudio BXT/Ensolite, Stereo: Kenwood KIV-701 USB/Bluetooth deck, 10" Pioneer shallow sub behind the rear seat, Infinity 6822cf 6x8 front and rear doors, Fosgate P400-2 (sub), US Acoustics USX-4065 (four main speakers)
    I used Raamaudio sound deadening material and was happy with it and the service I got from the owner (Rick) http://www.raamaudio.com/ It can definitely help with quieting the cabin noise and keeping metal from vibrating when you are bumping tunes although until you are running a subwoofer you probably won't be rattling metal too much.
    I have that exact TaoTronics license plate frame backup camera. I have used it with two different radios. It works well and I have never had problems with water getting into it (some of the cheaper cameras get bad reviews after people go through car washes). That JVC looks to have a standard composite RCA video input so it should work fine with the camera.
    New door speakers and an amplifier are probably the two things that make the most difference. You could always add an amplifier later if budget allows. I bought some Infinity 6x8 speakers for my doors that were labeled as "for 5x7" and 6x8" openings". I trimmed the stock mount a little bit to accommodate the larger magnet, but they went in without too much effort.
  8. Jul 24, 2015 at 7:39 PM
    Tonkkids
    Tonkkids 2001 Taco PreRunner V6
    Bubba
    Thomaston GA
    2001 Prerunner SR5 V6
    Got an '01 DC. Looking for good door speakers for it. Bought some from Crutchfield but not happy with 'em. I like a little bass for my country music (NOT rap). any sugs? Sorry for the snipe of this post.
  9. Jul 24, 2015 at 8:25 PM
    Digiratus
    Roaming the PNW
    The RedHead
    FWIW, I put in 5.25" Alpine componets
  10. Jul 24, 2015 at 8:41 PM
    KauaiBoy
    KauaiBoy Active Member
    2003 3.4L 4x4 Tacoma Xtra Cab
    K&n Intake, Toytec Bilstein Lift
    If you use 6x8's in the front you'll have to trim the speaker mount but it's pretty minor. Also an amp will not just make your speakers louder, it will make them sound cleaner and more full. That being said you will still love the sound of new speakers without the amp :thumbsup:
    Unless you get a small subwoofer or a 4 channel amp, it'll be hard to get some proper bass out of your door speakers in my experience. I had the same problem when I bought some alpine door speakers of crutchfield. The tech support told me that aftermarket door speakers often need a lot more power pushed to them to get the good sound that people expect. Running them off a headunit that only pushes 20w x 4 usually isn't enough. That's why your stock speakers probably had more bass than your new ones (at least mine did at first).
  11. Jul 25, 2015 at 10:28 PM
    mtucker
    Escondido, CA.
    03 Prerunner DC
    You may get more bass out of different/better door speakers, but the door access holes are large so at bass frequencies the holes will allow a lot of the front and rear sound waves to cancel. I sealed up my doors (not going for air tight seal, but making it hard for the front and rear speaker sound waves to combine). The mid bass came up quite a bit. You aren't going to get subwoofer bass from a 6x8, but the mid bass got much louder.
    Before:
    After:
    I used some metal flashing (thin roll of metal) to cover the holes and then added some sound deadening material over the entire inside of the door. These are my rear doors (doublecab), but the front speakers were very similar).
  12. Jul 26, 2015 at 1:23 PM
    BrannigansLaw
    Charles
    San Diego
    04 4x4 TRD
    Thanks for everyone's input. So far I've ended up getting that JVC deck and this back up camera instead (better FOV and doesn't ship from China, I don't want to wait haha)
    http://www.amazon.com/EC170-09-Wate...sim_422_4?ie=UTF8&refRID=1MGFD09E77YN3X496NQ0
    I think I'll have to hold off on the speakers for now and stick with the stockers, I just had to buy a 260 crankcase cover for my motorcycle :/
  13. Jul 28, 2015 at 4:07 PM
    rnish
    rnish Well-Known Member
    Maryland USA
    Tacoma 2nd gen
    Pro Suspension (Bilstein), OME Dakar (med), armor
    I would recommend a butyl sound deadener, stay away asphalt based. Butyl is more sticky. Holds better on overhead and vertical surfaces.
