New battery and alternator, still not charging properly
Discussion in '2nd Gen. Tacomas (2005-2015)' started by dbs1, Oct 14, 2020.
  1. Oct 14, 2020 at 10:29 AM
    dbs1
    dbs1 [OP] 2015 Dbl cab TRD Pro 4x4
    Dan
    2015 Dbl Cab TRD Pro 4x4
    SC w/urd pulley, afe cai, URD LT's, TRD cat back. 375hp. Custom logos, tonneau cover, westin bar with piaa lights, aero force gauges, custom front air dam, Westin step bars.
    Just put in new battery and alternator after leaving light on and truck not starting after prolonged charging.
    Autozone showed battery no good and alternator diodes not working in alternator so replaced both (alternator replacement with TRD sc is a PITA).
    Start up shows 13.8 volts. While traveling it drops to 13.2 volts. As an aside truck feels down on power.
    What should I look for?
  2. Oct 14, 2020 at 10:34 AM
    ryfox0276
    ryfox0276 Well-Known Member
    Montana
    2013 RC 4x4
    Are you positive the loss of power is due to electrical issues? The voltages you posted are normal.
    davidstacoma and 12TRDTacoma like this.
  3. Oct 14, 2020 at 10:37 AM
    Sandman614
    Tim
    Garner, NC/Boone, NC
    '06 SR5 Off Road
    A dyno?
    confirm, our charging systems are "smart systems". The voltages posted are normal, and will fluctuate based on load. If you need more voltage for say an AGM or lithium battery you will need a voltage booster, a whole thread on here for that.
  4. Oct 14, 2020 at 10:47 AM
    MagtechPA
    MagtechPA Thor
    Pittsburgh, PA
    The truck might feel down on power because the ECM is likely going through the lengthy relearning process after being wiped clean.
    It’s in the programming phase for air/fuel ratio, ignition timing, driver input, etc.
    This is normal if the battery is disconnected or replaced.
    12TRDTacoma likes this.
  5. Oct 14, 2020 at 11:26 AM
    steelcity2
    steelcity2 Well-Known Member
    Pittsburgh Pa
    2013 MGM DCSB TRD sport
    Bilsteins 5100's all 4 corners 1 inch rear spacer
    Belt tensioner?
  6. Oct 14, 2020 at 11:34 AM
    coopcooper
    coopcooper certified youtube mechanic
    alberta canada
    black on black on black 05 trd off road
    stickers and sticker accessory's
    Thats normal numbers so whats the issue?
  7. Oct 14, 2020 at 11:35 AM
    jimmy c
    jimmy c Well-Known Member
    jim
    Port St. Lucie Fl.
    2015 tacoma
    Hopefully you did not put a autozone alt. on it. If you did pay the money for the core charge and keep your old one for a spare. They dont normally have problems. Reman alts arent that good.
  8. Oct 14, 2020 at 11:37 AM
    jimmy c
    jim
    Port St. Lucie Fl.
    2015 tacoma
  9. Oct 14, 2020 at 11:40 AM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    They may not be bad, but they do fail. This sort of failure seems to be a little more commonplace on the newer 2nd gens, as it appears that Toyota cheaped out on quality parts utilization on the later models. Mine is currently bad and does not like heavy amperage draws at idle or while driving now. The issue is getting worse over time. I have to replace it, eventually. I'll probably do it soon.
  10. Oct 14, 2020 at 11:55 AM
    Sandman614
    Tim
    '06 SR5 Off Road
    https://www.tacomaworld.com/threads/2nd-gen-1grfe-alternator-rebuild-mud-cleanout.453757/
  11. Oct 14, 2020 at 12:07 PM
    gearcruncher
    Canadain bumper technician
  12. Oct 14, 2020 at 1:06 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    I appreciate the link, but this is not a diode issue, it is a voltage regulation issue. Besides, all the time invested into doing a rebuild on which is a 50/50 repair whether it will work or not is the equal to rebuilding an AC compressor. A rebuilt Denso unit is easily obtainable and for relatively cheap (about $170ish) so for the time and energy and questionable repairability results, I'd rather invest into a unit built by a legitimate brand.
  13. Oct 14, 2020 at 1:12 PM
    Sandman614
    Tim
    '06 SR5 Off Road
    OP specifically was told Diode went bad, that is exactly what I replaced in mine and it's still working great. For like $35 it's worth it to have a spare if his potential store brand one bites the dust.
  14. Oct 14, 2020 at 1:18 PM
    T-yoda
    T-yoda Well-Known Member
    Dave
    Eastern pa
    17 TRDORDCLB mgm
    265-75-16 BFG AT, firestone riderites
    Make sure you clean your throttle body to bring your idle back to normal
  15. Oct 14, 2020 at 1:21 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Were you having voltage drop issues under high electrical load as well?
    Of course like I said it's not a Vatozone or O'really brand alternator. It would be Denso, and I've always had fantastic success using them as far as repair rate/ comeback ratio is concerned.
  16. Oct 14, 2020 at 1:25 PM
    TireFire
    TireFire Superunknown Member
    Olympic Peninsula
    At the expense of a few ponies, I’m sure. The stock 130A alternator is properly sized unless you turn your truck into Hooverville
  17. Oct 14, 2020 at 2:24 PM
    dbs1
    Dan
    Thanks for all the replies!
    Though no big stereo system it does have a trd sc which has the intercooler pump cycling endlessly even when turned off as well as a collection of fg road lights that are used on high beam.
    Power loss was noticed prior to battery/voltage issues so I’m really not sure what’s causing that. The closest I can relate the problem to is a former 67 camaro with a plugged fuel filter that can’t get enough fuel. It may be the new 750hp ZL1 making everything feel slow but I don’t think so.
    Truck is in shop to check electrical and get a fuel system flush. Thanks!!
  18. Oct 14, 2020 at 2:28 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Yeah that definitely has got to be something else causing the power loss then because the nominal voltage it hangs at while on is not going to cause that.
  19. Oct 14, 2020 at 5:23 PM
    TireFire
    Olympic Peninsula
    Fuel system flush? o_O
  20. Oct 14, 2020 at 11:01 PM
    dbs1
    Dan
    Carbon deposit removal. Somewhat needed for a sc 4.0 with the pig rich TRD tune.
    As a side note...shop shows me a rather large plugged up, in line fuel filter I forgot I had installed with the high flow fuel pump. Exactly what it felt like. Feels better now!
