New battery suggestions
Discussion in '3rd Gen. Tacomas (2016-2023)' started by harrison20, Jun 20, 2021.
  1. Jun 20, 2021 at 1:02 PM
    OrangeRa1n
    OrangeRa1n Well-Known Member
    Houston Area
    TRD-Offroad 2021
    Interesting! It looks like an AGM may be in my future...
    It's also good to note that while a more expensive battery will yield you say ~ 7 years, and a cheaper battery will yield you 5, it might be better to just go cheaper. For example, an odyssey battery may cost $270 and a Walmart battery $100. That Odyssey battery is running $39 per year of use and the Walmart battery just $20 (heck, if the Walmart battery only lasts 2.5 years, you are still coming out on top).
    It really depends on your usage; are you using high loads (winch, speakers, etc.), are you storing the truck for large amounts of time, are you running the battery low frequently, etc. There isn't a universal battery that covers everyone's needs or budget. Not everyone needs a high-performance battery.
  2. Jun 20, 2021 at 3:20 PM
    SRBenjamin
    SRBenjamin Well-Known Member
    Benny
    True, but there's more to it. I've owned 3 Enersys batteries and I got 8,9 and 11 years from them. They all failed slowly, giving me lots of warning ahead of time.
    I got 9 years out of my last Deka battery, and found that brand to be the sweet spot for price/quality ratio.
    I got my current walmart AGM on sale for $130. so I thought what the heck, I'll give it a shot.
    My point is normal acid batteries can die with little to no warning. AGM's seem to die a slow death.
    Steves104x4 likes this.
  3. Jun 20, 2021 at 3:51 PM
    OrangeRa1n
    Houston Area
    TRD-Offroad 2021
    Those were just example numbers with no scientific meaning behind them, but I do agree Deka batteries have lasted me a good while. Weather conditions also matter, hot climates will degrade batteries faster than cold. The vehicle also matters, my F-150 would go through batteries every two years, regardless of brand. I had no idea Walmart carried AGM batteries, that's a good bit of information (and price)! I would assume that the more sealed nature of AGM results in longer lives since the average user will not refill the cells until it is too late; that and the vibration resistance of AGM batteries (another consideration).
  4. Jun 20, 2021 at 3:55 PM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    My Analzone AGM Gold is going on 6 years
    MGMDesertTaco likes this.
  5. Jun 20, 2021 at 4:15 PM
    SRBenjamin
    Benny
    Well, I'm not a scientist. Your viewing a forum, all your going to get is opinion. This is why folks look at forums.
    MannyS likes this.
  6. Jun 20, 2021 at 5:17 PM
    OrangeRa1n
    Houston Area
    TRD-Offroad 2021
    I meant that I made those numbers up as an example. I did not do any research into rather or not the more expensive battery would last 7 years or the cheaper 5. I was not talking about anything you mentioned, sorry for the confusion.
  7. Jun 20, 2021 at 5:34 PM
    ppham444
    ppham444 Well-Known Member
    Phuong
    Portland, OR
    2023 White TRD Off-Road doublecab
    This analzone battery you speak of. Does it come with lube? Asking for a friend.
  8. Jun 20, 2021 at 5:52 PM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    If you want to run a fridge full-time on extended trips, a 2nd battery is helpful. 2nd battery should be located on the passenger side or in the bed. Putting two batteries at the OEM location overloads the inner fender structure and could cause cracking. Go with Optima Red Top 35 because it weighs only 30 lb (OEM is ~50 lb).
    Advics AD0976, basically OEM pads but less expensive and comes with new shims (OEM pads don't come with shims at the dealer).
    OrangeRa1n likes this.
  9. Jun 20, 2021 at 6:50 PM
    SRBenjamin
    Benny
    Me too.:thumbsup:
  10. Jun 20, 2021 at 7:04 PM
    SD Quicksand
    SD Quicksand Well-Known Member
    Alex
    San Diego, CA.
    2017 Tacoma TRD Off Road 4x4 Access Cab Quicksand
    https://www.tacomaworld.com/threads/new-battery-questions.724681/
  11. Jun 20, 2021 at 8:57 PM
    Ronk44
    Ronk44 Well-Known Member
    Rockerville, SD
    2017 MGM Sport
    Leveled with Bilstein 5100 shocks, Falken Rubitrek AT 265/75 tires, Redline hood struts, R4T tailgate lock, Matt Gecko LED strips in bed and under hood, WeatherTech hood guard, OEM bed mat, Husky floor mats, Carhart seat covers, Grille replacement with Toyota letters, Sony AX6000 head unit, OTT lite/mild tune, and an occasional splash of fuel additive.
    Sams Club 3 Year Replacement. If you get 5 years on battery you are doing good. No need to spend more on something that is designed to be replaced. Toyota OEMs …. mine dead in year 4.
  12. Jun 21, 2021 at 2:36 AM
    jetspeed
    jetspeed Well-Known Member
    MD
    19 TRD Sport DCSB 4x4 Manual Taco
    Walmart. Longest lasting inexpensive battery.
  13. Jun 21, 2021 at 5:38 AM
    Sungod
    Sungod Well-Known Member
    St Augustine
    When people talk about upgrading a battery, the first question I ask is "why"? For the overwhelming vast majority of people a standard high quality lead acid battery made by Johnson Controls will give you years of quality service. Unless you add a substantial amount of demand like a winch, onboard air, 90s style bass thumping stereo, etc. You will never see the benefits of paying more for an AGM. While it might last longer, at the price you are not getting much of a benefit and you are not running the deep cycles that those batteries are designed for. Instead use that money for something that you actually benefit from.
  14. Jun 21, 2021 at 5:46 AM
    dagobert
    dagobert Well-Known Member
    Kirkland from Costco - can't beat the warranty. Pay once and battery for life.
  15. Jun 22, 2021 at 3:28 PM
    #35
    PilotguyPA28
    PilotguyPA28 Well-Known Member
    Trip
    2020 Metallic Gray Limited
    My OEM battery is only 9 months old as is my Tacoma. I have a dash cam (Garmin 65W) that is on all the time. If the truck sits for 3-4 days the battery will be dead. Dealer checked and the battery passes their test. Any suggestions on a battery that will last longer with the dash cam on?
  16. Jun 22, 2021 at 4:57 PM
    #36
    SRBenjamin
    Benny
    PilotguyPA28[QUOTED] likes this.
  17. Jun 22, 2021 at 5:21 PM
    #37
    Jimmmy1111
    Jimmmy1111 Active Member
    Jimmy
    2018 TRD Sport Blazing Blue Pearl
    Costco Interstate batteries
