New clutch
Discussion in '1st Gen. Tacomas (1995-2004)' started by sk8rjess, Apr 11, 2013.
  1. Apr 13, 2013 at 2:14 AM
    flatblack
    flatblack Well-Known Member
    CDA
    95.5 Tacoma 3.4 Manual
    I just got my clutch replaced with the Marlin Crawler 1,200lbs kit
    I also ordered the flywheel they sell on their site
    I am very happy with and would recommend the products themselves; but, I would also recommend buying from Marlin Crawler, because they have outstanding customer service
  2. Apr 13, 2013 at 4:02 AM
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    You need to find another machine shop.
  3. Apr 13, 2013 at 4:04 AM
    maineah
    Tim
    Maine
    4X4 SR5 V6 6spd
    Looks more like an oil filter change leak.
  4. Apr 14, 2013 at 12:38 PM
    sk8rjess
    sk8rjess [OP] IG: @whoishack
    Cody
    Nashville, TN
    02 4x4 sr5
    some duct tape and zip ties
    Nah, I know for sure that's not leaking.
    I'm still undecided on URD or marlin though.
  5. Apr 14, 2013 at 1:44 PM
    2000GTacoma
    2000GTacoma Well-Known Member
    Snow Hill NC
    00 Tacoma Ext. 3.4L SR5
    I have a marlin I am going to try to install next weekend if time permits.
  6. Apr 14, 2013 at 2:56 PM
    sk8rjess
    Cody
    Nashville, TN
    02 4x4 sr5
    i'm going to go with a marlin. it's a little cheaper and haven't heard anything negative about it.
  7. Apr 14, 2013 at 3:07 PM
    sk8rjess
    Cody
    Nashville, TN
    02 4x4 sr5
  8. Apr 14, 2013 at 7:47 PM
    TacoMX
    TacoMX TW's Official anti body-lift pundit
    Jonathan
    Deltona, Florida
  9. Apr 14, 2013 at 7:53 PM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    1990 Chevy Siveraydo
    if it's not too destroyed (cracked) they can turn it down a few thousandths to give you a fresh surface for the clutch disc.
  10. Apr 14, 2013 at 8:02 PM
    tomtom
    tomtom Well-Known Member
    The Desert SW
    2012 FJ
    Yup, understood. Can do that where the surface isn't scored too deep. Got it. But when you score it too deep because you drive your clutch like you got a full race team to service it, a machine shop can't save it. Like I said, you can't add material back.
    I wish I had pictures to show you. I am not kind to clutches.
  11. Apr 14, 2013 at 8:07 PM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    Haha very true. I drive like a grandpa so I've been able to resurface in the past.
  12. Apr 14, 2013 at 8:17 PM
    Conman117
    Conman117 AWESOME MEMBER
    Nathan
    BC, Canada
    98 Brap-coma
    Blue LED dash lights
    I did the opposite. I had to replace my rear main seal so I replaced the clutch while I was in there:p
    When/if you get the flywheel machined make sure you get the step-down around the edge. There's a little lip around the edge that needs to be there.
    I put in my marlin clutch mostly myself, it's not too bad.
  13. Apr 14, 2013 at 8:17 PM
    tomtom
    The Desert SW
    2012 FJ
    I've seriously started considering going to an automatic for my next vehicle.
  14. Apr 19, 2013 at 6:22 PM
    sk8rjess
    Cody
    Nashville, TN
    02 4x4 sr5
    I just got a new flywheel from marlin while I was at it and a new rear main. Everything came in today so that's what I'll be doing this weekend as well as adding a lift to an fj and fab up some tube doors for a 2nd gen. Hooray mod weekend!
  15. Apr 19, 2013 at 7:29 PM
    #35
    tomtom
    The Desert SW
    2012 FJ
  16. Apr 22, 2013 at 9:41 PM
    #36
    sk8rjess
    Cody
    Nashville, TN
    02 4x4 sr5
    Alright so for those of you who has done a clutch before.. Is there supposed to be a slight whine right when the clutch engages? I figured it was kinda breaking it in
  17. Apr 22, 2013 at 9:57 PM
    #37
    vtrguy
    vtrguy Well-Known Member
    Jarrod
    Chico
    '01 Taco TRD xCab SR5
    Deckplate, Full OME kit, Snugtop Camper, Camry ignition ring, TRD Catback
    I'm assuming you replaced the TOB?
  18. Apr 22, 2013 at 10:03 PM
    #38
    sk8rjess
    Cody
    Nashville, TN
    02 4x4 sr5
    Yep. Throwout, pilot, flywheel, clutch, rear main seal
  19. Apr 22, 2013 at 10:13 PM
    #39
    flatblack
    CDA
    My truck has 204k on it and whines like mad (louder than the engine)
    It goes silent when I disengage the clutch
    I was hoping it was a noisy pilot
    Replaced the entire clutch system (not cause of the whine, needed it anway)... still does it
    A Toyo-Tech told me, It's my Transmission Input Shaft Bearing or Counter Shaft Bearing
    He said:
    If you hear whine in all the gears but 4th (4th is direct), it's the Counter Shaft Bearing
    If you hear it in all gears (including neutral), it's the Input Shaft Bearing
    ...It goes silent when the clutch is disengaged, cause, of course, neither of those bearings are then spinning
    I would bet, like me, the whine is not a clutch issue, based on when you hear it, and the fact that it's brand-new;
    Sounds like a bearing might be getting worn in your 200k-Transmission
    Check this out:
    http://books.google.com/books?id=TsBde1ereuAC&pg=PA47&lpg=PA47&dq=transmission+input+shaft+bearing+noise&source=bl&ots=BtBvPEHb3k&sig=8956ZTsCexw4bfyS7b-QQubshFU&hl=en&sa=X&ei=Jxd2UavcBZHurAHR7oGwBw&ved=0CFcQ6AEwBQ#v=onepage&q=transmission%20input%20shaft%20bearing%20noise&f=false
  20. Apr 23, 2013 at 7:37 AM
    #40
    sk8rjess
    Cody
    Nashville, TN
    02 4x4 sr5
    let's hope it's not that. from what i've been reading and have been told its sounding like the throwout bearing.. maybe i somehow put it on wrong?
    it's such a pain and hassle to take the tranny out again though, i'll prob end up paying someone to do it.
