New coilovers-popping noises
Discussion in 'Suspension' started by nighthawk87, Jun 20, 2010.
  1. Jun 22, 2010 at 10:59 AM
    #41
    06stex
    06stex Well-Known Member
    Alex
    Corpus Christi, Texas 361
    06' TRD 6" Fabtech..limo tint
    6 inch Fabtech, Dirt Logic 2.5 coilovers, Light Racing UCAs 17x9 XD spy, 305 65 17 Extreme ATs, Limo all around, Kicker speakers,Kicker L5 10 inch sub, 400 watt kicker mono amp In dash Pioneer with Ipod cable, Flowmaster 50, bedmat, toolbox, K N Filter, cheapo seat covers, 6000k HIDs upfront, bhlm,DDM 5000K fogs, tailgate mod, and many more to come.
    Guys i have no sway bar and a 6 inch Fabtech and Fabtech Dirtlogic coilovers. I never had this infamous popping/ clunk sound either till after i installed the dirtlogics. I really think it is caused by the cycling of the shocks along with the metal sperichal bearings and the swivel upper mount. Oh and along with the front CVs making a noise and the caliper slap. Just my thoughts it comes and goes and truck drives fine and straight and solid. Krookz i think has experienced the same popping, i got used to it and 6 months later all is well. Just sucks that you invest 500 or in my case 1000 bucks and you all of a sudden get a new popping sound. Wish ya the best.
  2. Jun 22, 2010 at 11:04 AM
    #42
    nighthawk87
    nighthawk87 [OP] Well-Known Member
  3. Jun 22, 2010 at 8:40 PM
    #43
    nighthawk87
    Double checked clearance. Everything looks good.
    I don't know what to do anymore. Maybeni should take them out and go back to stock :(
  4. Jun 22, 2010 at 8:43 PM
    #44
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    I have the same Co's and they are silent. CO's dont make "Popping" sounds. It has to be something else....
  5. Jun 23, 2010 at 9:37 AM
    #45
    Coolidge
    Coolidge Well-Known Member
    So Cal, Ca
    2003 Pre Runner
    King coilovers frt +3". Bilstein 5100 shocks rear w/AAL, K&N FIPK, Magnablow exhaust, Billet grill, clear corner lights, Sony stereo, JBL, Sub etc.
    Is the shock nitro charge good?
  6. Jun 23, 2010 at 9:52 AM
    #46
    Amo-cat3
    Amo-cat3 Wizard Sleeve Master
    Maui, Hawaii
    07 TRD Blown dubcab
    TRD Supercharged 4.0 w/ 2.5" Quick change Pulley, UCON EMS, URD 7th injector, AFE Stage II intake, DT Longtubes, MBRP 2.5" dual exhaust w/ Vibrant Ultra resonator, URD Y-pipe w/ vibrant v-bands (Cat free), Walboro 255 fuel pump, SS Oil catch can, Aeroforce gauges, Icon CDC 2.5 coilover set at 3", 1.5" Wleelers Progressive aal, Light racing uca, 17x8.5 Fuel Anza 4.5" backspace/-6 mm offset, Kelly Safari a/t 265/70/17, scanguage 2, AMP electric steps, bed extender, Low-pro tonneau cover, 20% tinted windows/headlights/taillights, tacoma seat covers, Image dynamic sound system w/ Pinoneer avh3200 head, assrtd stickers................
    Install instructions for Donahoe, icon, and SAWS all say that when attatching the lower shock arm of the coilover the longer spacer on the eyelet should face forward of the truck to push the coils back away from sway bar.
  7. Jun 23, 2010 at 11:24 AM
    #47
    eight3one_offroad
    eight3one_offroad Honey your two French Fries short of a Happy Meal.
    Richard
    Santa Cruz, California
    TRD Sport 4x4 with a few things.
    Optima Red Top 34R, OME 885 / N140S + 5100 rear, TSB leaf pack, Camburg Ball Joint UCA, Wheelers Diff drop, AEM Brute Force Intake with filter wrap, Summit Super Turbo muffler, Llumar 5% tint, Pioneer single din head unit, PIAA 510 Ion Crystal Fogs in stock location, Sonar LED tails. Sway Bar removal. Charcoal filter delete. Stant 11509 Locking Gas Cap.
    I took mine off, so I guess now it doesn't matter :)
  8. Jun 23, 2010 at 1:04 PM
    #48
    nighthawk87
    Nitro charge should be good. They were new.
    I installed the spacers correctly.
    Geeze. Don't know what else to do.
  9. Jun 23, 2010 at 3:11 PM
    #49
    mnudo200827
    mnudo200827 Well-Known Member
    Michael
    Corona, CA
    2005 Tacoma Double Cab Prerunner
    Icon Coilovers, All-Pro UCA's, All Pro 3" Leaf Springs, Rear Fox Adjustable Shocks, Stainless Steel Brake lines, 17" KMC Addicts wrapped in 305/65/17 KM2's, Kenwood DDX 512 stereo, 2 12" Polk Audio MM1240 subs in custom enclosure, 4 component speakers, Wet Okole Seat Covers
    I have the same coilovers but mine dont pop, they just make a small squeak over speed bumps, probably the spring i am guessing, you might want to take them and get them charged, wouldlt hurt, they should be able to do them with them on the truck.
  10. Jun 23, 2010 at 4:54 PM
    #50
    Coolidge
    So Cal, Ca
    2003 Pre Runner
    ....Thats the only time Ive heard of CO's making 'popping' sound....when Nitro needs charge. Just hearsay tho. I really dont know?
  11. Jun 23, 2010 at 8:25 PM
    #51
    BrandonTorgerson
    BrandonTorgerson Well-Known Member
    Brandon
    Signal Hill, Ca
    09 Tacoma TRD Sport 4X4
    Ok so this caught my attention, I have 2.5 camburg sway-a-way COs and I have this poping sound to, and it's only at a full turn, with a bit of bumpiness. I checked it out and it's the sway bar hitting the bottom of the spring, as there are markings from contact, so I took off the sway bar and grinded out aliltle bit where I saw it was rubbing. It's not as bad, but it's still there at a full turn, it drives me crazy! Mabey there's in after market sway bar? What do you guys think?
  12. Jun 23, 2010 at 8:27 PM
    #52
    yosh2000
    yosh2000 Well-Known Member
    CO
    '17 Tundra CM 5.7
    ^ sway bar relocation brackets?...or remove it all together?....done.
  13. Jun 23, 2010 at 8:47 PM
    #53
    nighthawk87
    I'm gonna remove mine as I did see a small rub mark but it seems like there's enough room soni ignored it.
    If it fixes it then I'll be happy bit won't have a sway bar. I need my sway bar for towing don't I?
  14. Jun 23, 2010 at 8:57 PM
    #54
    BrandonTorgerson
    Brandon
    Signal Hill, Ca
    Yeah for towing... You might be alittle squarely with out it
  15. Jul 1, 2010 at 9:14 AM
    #55
    nighthawk87
    OK, later this afternoon I plan on removing the drivers side coilover and putting it back in. I am also going to play around with the ball joint.
    Question: After I break the spindle loose from the tapered bolt, what should I be looking for when moving the ball joint around in the spindle?
  16. Jul 1, 2010 at 2:07 PM
    #56
    Canadianboy
    Canadianboy Taco love in East Van
    James
    Vancouver, BC
    09 TRD Sport S/B 4x4 Auto in Mag Grey
    Icon Stage 3, Goodyear Duratracs and KMC Addicts!
    I thought I fixed the noise from my drivers side, but its still there. When ever I hit little bumps, I can hear a popping/loose kinda noise on the drivers side. Very annoying that I can't fix this darn issue!!!:mad:
    The only thing that I haven't check yet is if the shock is low on nitro. I'm not sure even how to go about this
  17. Jul 1, 2010 at 3:33 PM
    #57
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Check to see if it is loose. It should be snug.
    You cant "Check" the PSI in the CO's, you have to have them re charged.
  18. Jul 2, 2010 at 6:23 PM
    #58
    Canadianboy
    James
    Vancouver, BC
    Thanx Chris. Would there be any other symptoms if the nitro was low? Other then the annoying noise, it seems to drive good. No lean or roughness over bumps.
  19. Jul 2, 2010 at 6:25 PM
    #59
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    THe CO would feel "Flat"....Not feel good over bumps and such
  20. Jul 2, 2010 at 10:05 PM
    #60
    nvdeserted
    nvdeserted Well-Known Member
    Reno, NV
    2009 Tacoma TRD OR Access Cab
    Electric Dynolock tailgate, TrailGear Slides, , 285/75-16 Yoko Geolanders on Wheelers Type B, SAW 2.0 front and back, Camburg b/j UCA, 1.5" AAL, Ubolt flip, ARB bump.
    Those 2.5 Camburg/SAW c/os MUST have the swaybar relocate installed to function properly with the swaybar. They should have come with the relocate kit thing.
    Did you put that on?
