New CV axle won't spin 2011 taco
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Foresty4x4, Jul 24, 2022.
  1. Jul 24, 2022 at 10:43 AM
    Foresty4x4
    Foresty4x4 [OP] Member
    2011 gray Tacoma 4x4 base model
    Rear pod light, side tool box which is really handy.
    Hey y'all
    I've got a 2011 base 4x4
    Replaced passenger side CV several weeks ago, decided to do the driver side this weekend, as it had more play in it than I would like
    Got the new one in (One of the Duralast Gold I believe it is, from autozone, same as the new passenger side I just put in). New axle looks to be seated in all the way, same as the other side. The axle will spin backwards with some resistance, but smoothly enough. If I try to spin it forwards, it meets resistance, like it's catching on something, and I'd have to force it to move. The outside end is not in the spindle yet, and the truck is in 2WD, the other wheel spins freely when I jacked it up, so it's not either of those 2 things.
    Worried I messed up the needle bearings or something like that, only thing I can think of. Haven't taken the CV out to check yet cause I hate getting those things removed. Going to check right now though. Just curious if y'all had any other ideas of what it could be.
  2. Jul 24, 2022 at 12:22 PM
    Key-Rei
    Key-Rei Well-Known Member
    Key
    Florida
    Supposedly the C clip on the diff axle stub needs to be oriented correctly on insertion for it to go in all the way smoothly, I seriously doubt you damaged the needle bearing but you probably don't have your axle stub in all the way.
    Pull it out, inspect the bore align the C clip on the end and try again.
  3. Jul 24, 2022 at 12:27 PM
    Foresty4x4
    Could be I suppose. I put it in at roughly 12 oclock i think. Didn't think it would effect how it spins. Guess I'll find out.
  4. Jul 24, 2022 at 2:29 PM
    Goldwrench
    Goldwrench Well-Known Member
    2010 silver 4wd access taco
    Bought used and mild lift
    Retired auto mechanic here. We always ensured c clip gap was positioned to 6 o’clock position. And, I do this on my ‘10 Tacoma shafts too. Works better.
    Key-Rei likes this.
  5. Jul 24, 2022 at 3:15 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    I usually just shove mine in.
    Just get the CV just started into the diff. Then give it a good shove. The momentum of the CV is usually enough to get it seated. You’ll hear it “pop” in.
    As for clip position. I never worried about it to much. I put a coat of gear oil on it to help lube it. I don’t know if it actually helps, but it hasn’t hurt anything yet.
  6. Jul 24, 2022 at 8:08 PM
    Foresty4x4
    Ah, I was thinking it was suposed to be 12 oclock, guess I misremembered, could be part of it. Seems like it would still spin though. I put some gear oil on it before I installed it, figured it couldn't hurt as well. Anyways, didn't have any luck getting it back off before it got too hot out, so I'll try again tomorrow, check the needle bearings, and if it's good, try to reinstall with the clip facing 6
    Goldwrench likes this.
  7. Jul 25, 2022 at 5:08 AM
    Marc70
    Marc70 Well-Known Member
    Marc70
    Northern Ontario
    2012 TRD Sport 4.0L, 6MT
    2” lift, ARB front bumper, steel rear bumper, Trail Gear weld-on sliders, aFe cai, 2lo kit, air bag suspension, RA Motorsports AL skid plates
    Rob MacRuger likes this.
  8. Jul 25, 2022 at 6:46 PM
    Foresty4x4
    Interesing, would that zip tie trick work on the end that goes into the diff?
    Anyways if anyone is interested, finally got the the new axle back out, the needle bearings are messed up, at least one is in pieces, possible several, haven't dug that deep yet. Not sure if I put it in wrong or what. The c clip has a couple scrapes on it, and it seems like the angle is slightly off comared to the old axle's clip, so it's possible the clip was out of spec, and caused issues during install, don't know. But, time for new bearings and seal
    PRO TIP. The cable and swing hammer method for getting the cv axle out, is fantastic in my opinion. Theres some posts on this site that talk about it. Here's a link for a pic someone has, and a vid I watched too.
    https://www.tacomaworld.com/threads/2nd-gen-cv-axle-removal-tips-tricks-advice.318838/
    https://www.youtube.com/watch?v=NbLfjS3PL2c
    My two cents on it, I tried 3/32 and 1/8 inch cable, kept breaking on me, finally used 3/16 I think it was, about an 8ft section to make sure I'd have enough for getting the loops and still have room to swing the hammer.
    Anyways, thanks for the input y'all. Now, time to learn how to replace bearings, fun stuff.
  9. Jul 25, 2022 at 8:38 PM
    optifree
    optifree Well-Known Member
    Gary
    Pflugerville
    2010 AC TRD
    OME
    c clip down, gently tap the axle in with a rubber mallet.
    Goldwrench and Marc70 like this.
  10. Jul 26, 2022 at 2:16 PM
    deanosaurus
    deanosaurus Caveman
    Northeast Region
    09 TRD OR AC
    Since you blew your driver's side needle bearing might as well put an ECGS bushing in.
