New England B.S. Thread
Discussion in 'North East' started by mach1man001, Feb 16, 2012.
  1. May 20, 2013 at 3:29 AM
    64Wildcat
    64Wildcat Black Jeep of the family
    Denis
    New Hampshire
    2015 Rubicon
    Ya, nice trails,i really liked the last one!:cool: definately need skids to run it.
    Won't be doing that one for the cook out,but there are a lot of great trails that will be run!:D thanks John!
  2. May 20, 2013 at 3:34 AM
    Kirk1589
    Kirk1589 Well-Known Member
    Dave
    Sticks-RI
    03 SR5 Off-Road
    Pasti-Dip Grille, K&N drop-in, Magnaflow 14", Custom tail light mod, Fog light mod, diff vent mod, Alpine Components, Sequoia JBL radio
    Had a 3" on my ranger for 70k lots or trail riding no issues ever
  3. May 20, 2013 at 3:42 AM
    650H1
    650H1 Well-Known Member
    Michael
    VA
    2020 (Cement) TRD O/R
  4. May 20, 2013 at 3:45 AM
    BostonBilly
    BostonBilly Well-Known Member
    Easton
    2018 Jeep Wrangler JL Rubicon
    Morning all
  5. May 20, 2013 at 4:16 AM
    Pike Tacoma
    Pike Tacoma Well-Known Member
    Rhode Island
    2010 Double Cab Tacoma
    Morning...off to first day of internship with the state
  6. May 20, 2013 at 4:20 AM
    BostonBilly
    Easton
  7. May 20, 2013 at 4:39 AM
    Pike Tacoma
    Rhode Island
  8. May 20, 2013 at 4:41 AM
    johnnym
    johnnym Well-Known Member
    john
    NH
    87 4Runner Chevy 1500
    Sas 4.7tranfer case gears 5.29s Locked front/rear
    No problem .
    I looked into it and we missed 2 long trails one easy one moderate . Oh well I will make a better game plan for next time .
  9. May 20, 2013 at 5:44 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    PSUTaco85 ended up having his aftermarket plate bumpers made to accomodate the body lift.
    5100's for the 2nd Gens only have 4 settings, 0 (stock height), .85, 1.75 and 2.5. The more you preload, the stiffer the ride will be, especially if you have a TRD Off Road since they have progressive coils. I would suggest figuring out how much lift you want to gain and find a coil that will get you there. Let the coil do the lifting rather than preload the stock coil. It will result in a better ride in the end. OME coils are on the lower end of the scale as far as spring rate.
    All-Pro Expos will give you closer to 4" of lift unloaded, the standard All Pro pack will put you closer to 2.5 - 3", similar to the Dakars. If you go with the longer shocks, make sure you cycle your suspension to make sure you'll hit the bump stops before you bottom out the shock. That setup might require longer bumps.
  10. May 20, 2013 at 6:09 AM
    replica9000
    replica9000 Das ist no bueno
    Lake Chargoggagoggmanchauggagoggchaubunagungamaugg
    2019 T4R ORP
    I didn't know it was just the Off Road model that had the progressive springs. If I get the 5100's, I'm probably getting the 885 coils too. So the ride shouldn't be too stiff with those?
  11. May 20, 2013 at 6:13 AM
    Pugga
    Massachusetts
    The SR5 and TRD Sport models have the same coils and they're linear, the Off Road coils are progressive so when you preload them, they stiffen up in a hurry. With 885's, the ride should be nice. They are still stiffer than stock, but the 5100's will do a good job dampening the coils. OME 885's are only slightly stiffer than stock and still softer than Eibach coils (which need to be preloaded to get to 3" of lift).
  12. May 20, 2013 at 6:31 AM
    evanmb31
    evanmb31 Well-Known Member
    evan
    connecticut
    09 trd off road
    Satoshi'd grill. blacked out badges. aftermarket sound system. De-chromed and color matched. OME 885s + Dakars with 3rd leaf removed. LR UCAs. Scs stealth 6 with 285 duratracs. BAMF sliders
  13. May 20, 2013 at 6:32 AM
    replica9000
    2019 T4R ORP
    For the rear I have the stock shocks, not extended. When I get the 5100's for the rear, I'll need to extend the bump stop too right?
  14. May 20, 2013 at 6:39 AM
    Pugga
    Massachusetts
    Depends on which ones you get. The standard 5100's are fine, the extended version, you should cycle the suspension without the shock to get collapsed and extended lengths to determine whether or not you'll need to extend the bump stops. I went with a short lift to avoid those issues (UCA's and extended bumps and brake lines), you might get away with just using the stock bumps. How you intended to use the truck would be a factor also. Wheelers makes superbumps that are reasonably priced if you end up needing them.
  15. May 20, 2013 at 6:45 AM
    YOTA LOVER
    YOTA LOVER Stay Calm, and Fire For Effect
    NH
    2011 MGM Tacoma DCLB SR5
    A slew of pricey stuff my wife hates me for.
    Don't let OZ read you talking about "might get away with", LOL. We went back and forth about this issue in the OME thread. I agree with you, 2" of lift doesn't necessarily require them.
  16. May 20, 2013 at 6:54 AM
    ABA180
    ABA180 It burns when I pee....
    East Bridgewater MA
    Pioneer CD, Megaloud/JBL amps, Rockford/Polk speakers.
    Happy FML Monday..
  17. May 20, 2013 at 6:56 AM
    emelianenkov
    emelianenkov Santa/Alex Emeliahoweveryouspellhislastname
    Alex
    NORTH POLE
    Alex's Shitbox Emporium
    NE Special Rust Edition
    :ohsnap:
  18. May 20, 2013 at 7:02 AM
    BostonBilly
    Easton
    The lift I ordered is a 2" lift also and I went that route to avoid some of the issues associated with a 3" lift. I also didnt want to preload the springs. I did that with the torsion bars on my GMC and hated the ride
  19. May 20, 2013 at 7:04 AM
    BostonBilly
    Easton
    Hey Chris I posted up yesterday to try and finish your lights but you must have been busy. I am tied up for the next two weeks but we can try again
  20. May 20, 2013 at 7:16 AM
    Pugga
    Massachusetts
    Meh, if you measure and things work, no sense in spending money to replace parts that don't need replacing. I actually bought LR UCA's when I did my lift and didn't end up installing them since the stock ones work just fine.
    The bump stop thing should probably be checked out though, especially if you go with the extended length 5100's. They aren't meant to fit on a Tacoma and having the shock bottom out could break the shock or send the stem through the bed if you bottom out hard enough. Here's the thing though, think about how substantial the Dakars or All Pro leaf packs are and now try and think of when you would actually manage to bottom them out... I'm sure people manage to do it, but I'd also imagine it takes a hell of a hit to do so.
    I can't wait to see the Ironman lift, it seems like a nice setup!
