New England B.S. Thread
Discussion in 'North East' started by mach1man001, Feb 16, 2012.
  1. Feb 24, 2017 at 7:14 AM
    Cativelense
    Cativelense Well-Known Member
    Nuno
    CT
    2014 DCSB Black 4x4 TRD Sport
    -TRD oil cap -TRD radiator cap -TRD shift knob -2015 Entune system with Nav, -OEM roof rack -Front windows tinted to match back (20%) -BPK Skid Plate -Non clock hazard switch assembly -WeatherTech floor mats -AFE Stage II Pro Dry Intake -AVS Vent Shades -AMP Research bed extender -Horn relocation mod -Bob's Mirror -Redline hood struts -UltraGauge MX 1.3 -Debadged -Reverse LEDs & shifter bezel LED -Black steering wheel controls, black shifter bezel, black AC vent panel -Black gauge cluster rings + black tweeter rings -Morimoto XB LED fog lights -Anzo tail lights -Hilux 4x4 lighted switch -Bed mat -Hondo Garage radio knobs -OKLED 20" light bar mounted on BAMF behind the grill mount -CH4X4 LED light bar switch w/add-a-fuse -nd4spdbh fog light anytime mod (HUGE thanks to @tgriff) -Debadged bed -Secondary air pump filter -Retros (Morimoto Mini H1's and Morimoto Panamera shrouds with dual intensity LED DRL's & 5000k bulbs) -Tailgate Anti-Theft Device by @scleaf -OEM TRD Sport 17" wheels painted black w/Bridgestone Blizzak DM-V1 tires (Winter wheels) -Pro Comp Extreme 17" wheels w/Firestone Destination LE2 tires (Spring/Summer/Fall wheels) -Anzo blacked out third break light -HomerTaco Tacoma Ghost Raptor Insert -Rear diff breather mod (HUGE thanks to @jc11taco89) -Fumoto Valve -LEER 100R -Salex center console and glove box organizers -Power Pop N Lock -Mobtown Tailgate Skin -TRD Pro suspension with HS Progressive AAL (overload leaf in) -ECGS replacement bearing -Dust caps on rear drums to match front -Me-So Customs "The Gasshole" -ACEkraut license plate bracket -mesojdm's 2nd Gen Ultimate LED Dome and Map lights -Seat spacers from olecoot -Bullaculla Trailer Harness Relocation Bracket
    I know @surfandturf just did it recently because he posted info about it in our CT BS thread.
  2. Feb 24, 2017 at 7:16 AM
    mach1man001
    mach1man001 [OP] eh whatever
    Rob
    Bellingham, MA
    2024 Tundra Limited
    I love my new truck but miss my Tacoma
    Lots of us have done it. You don't leak very much. 1/4 a quart at most. It just drips out
  3. Feb 24, 2017 at 7:17 AM
    Bruce988jl
    Bruce988jl Well-Known Member
    Southern NH
    08 Tacoma Dbl Cab TRD Off-Road & 05 Mitsubishi Evo
    Guess I'll drain the fluid and replace it while I'm on it since I don't have OEM fluid to top it off. I don't want to mix and match.
  4. Feb 24, 2017 at 7:43 AM
    ABA180
    ABA180 It burns when I pee....
    East Bridgewater MA
    Pioneer CD, Megaloud/JBL amps, Rockford/Polk speakers.
    Which pre do you take?
  5. Feb 24, 2017 at 7:49 AM
    mach1man001
    Rob
    Bellingham, MA
    2024 Tundra Limited
    Good idea. When was the last time you changed all the fluids?
  6. Feb 24, 2017 at 7:49 AM
    Sloth
    Sloth Baby Ruth?
    Seth
    Democratic Peoples Republik of Massachusetts
    07 FJ Cruiser, 98 Landcruiser
    Stuff
    I use the optimum nutrition ammino powder as a pre since it's got a metric fuckton of caffeine.
  7. Feb 24, 2017 at 8:46 AM
    surfandturf
    surfandturf Well-Known Member
    CT
    2014 TRD DCLB
  8. Feb 24, 2017 at 8:53 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
  9. Feb 24, 2017 at 8:53 AM
    mach1man001
    Rob
    Bellingham, MA
    2024 Tundra Limited
  10. Feb 24, 2017 at 9:01 AM
    Bruce988jl
    Southern NH
    I have Motul at the shop at gear 300 75w90 which is actually what the dealership told me to put in. So I guess that will do. I guess I'll have to drop the skids to do this....
    It was apparently done at 100k before 8 bought the truck but all I have is the word of the dealership. I'm at 130k now.
  11. Feb 24, 2017 at 9:11 AM
    Cativelense
    Nuno
    CT
  12. Feb 24, 2017 at 9:12 AM
    mach1man001
    Rob
    Bellingham, MA
    2024 Tundra Limited
    I'd just do them all then, doesn't hurt and not very expensive to do.
    Cativelense likes this.
  13. Feb 24, 2017 at 9:24 AM
    replica9000
    replica9000 Das ist no bueno
    Lake Chargoggagoggmanchauggagoggchaubunagungamaugg
    2019 T4R ORP
    I was going to flush my power steering today since it's so nice, but it's windy af...
  14. Feb 24, 2017 at 9:53 AM
    Bruce988jl
    Southern NH
    I'll have to do the diff fluid for now as I'm going to be tight on time.
  15. Feb 24, 2017 at 9:58 AM
    Sloth
    Sloth Baby Ruth?
    Seth
    Stuff
    The older 2nd gens had Dino fluids from the factory so their service interval was 30k miles anyways. Not a bad idea to do them. Easy and relatively cheap, just a little time consuming due to using one of those stupid little bottle pump things. Also, that shit smells terrible.
    AutoZone carries Mobil 1 gear oil. I ended up having to go to 2 cause the first didn't have enough for me to do everything on my FJ this past summer.
  16. Feb 24, 2017 at 9:58 AM
    Sloth
    Sloth Baby Ruth?
    Seth
    Stuff
    Might as well do the tcase too since you're right there anyways....
  17. Feb 24, 2017 at 10:20 AM
    Bruce988jl
    Southern NH
    Hm.. 3L for the transmission fluid service but 10.9 dry capacity. Should I just have it pumped/flushed properly?
  18. Feb 24, 2017 at 10:26 AM
    replica9000
    2019 T4R ORP
    11 litres for the auto tranny? The manual takes 2 quarts.
  19. Feb 24, 2017 at 10:42 AM
    Sloth
    Sloth Baby Ruth?
    Seth
    Stuff
    That's just to drop the pan and refill, not the exchange all the fluid. You can do the whole exchange yourself, it's just time consuming. Last time I had the wife's T4R at the dealer I asked about a trans flush and it runs around $300 to do the actual flush. Dropping the pan and replacing 3l of fluid was cheap but doesn't really do anything
  20. Feb 24, 2017 at 10:43 AM
    jethro
    jethro Master Baiter
    Geoff
    Southern NH
    2020 Ford F-150 Lariat 5.0L V8
    This fucking weather SUCKS and swallows
