New England B.S. Thread
Discussion in 'North East' started by mach1man001, Feb 16, 2012.
  1. Sep 7, 2017 at 12:56 PM
    BigMacMcCoy
    BigMacMcCoy Cajun In Vienna
    Braedon
    Vienna, VA
    Silver 2010 Tacoma Access Cab
    All the dumb choices in one vehicle
    On my way to Chipotle for lunch today ( ;) @mach1man001 ) in Westford I passed a 3rd gen going the other way with the same NFab light bar and square lights on it. He also had the NFab bumper bar with 4 more square lights on it haha. Gave me a thumbs up and a wave as we passed. :fistbump:
  2. Sep 7, 2017 at 1:11 PM
    MTyota86
    MTyota86 Well-Known Member
    Haverhill, MA
    09 TRD Off-Road
    Airaid Intake, Magnaflow Exhaust, Diff Breather, SOS Concept Sliders, OME 3" Lift, SOS Concept rear bumper, Plasti-Dip grill and Badges.
  3. Sep 7, 2017 at 3:22 PM
    Bruce988jl
    Bruce988jl Well-Known Member
    Southern NH
    08 Tacoma Dbl Cab TRD Off-Road & 05 Mitsubishi Evo
    Reading up about the wookie strength carrier bearing...
    Edit - I'm thinking about going with the Inland Empire Carrier bearing and seeing if I can get it to work. Going to crawl under the truck next week to take a look.
    According to this thread the stock height mounting position for the DCSB would be raised up from the normal mounting surface however since I'm lifted I should be able to just mount it to the lowest mounting point and it'll act like a CB drop kit... if I'm reading the photo correctly...
    https://www.tacomaworld.com/threads...uy-iedls-polyurethane-carrier-bearing.421410/
  4. Sep 7, 2017 at 3:48 PM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    It's solid mounted, so if slight vibrations annoy you, it's not a good idea. You'll feel very slight driveline vibration that the rubber around the current carrier bearing absorbs. I'm sure it's much stronger and having a grease fitting will make it last longer but who knows how bad the vibrations would be.
  5. Sep 7, 2017 at 3:50 PM
    Jcyr
    Jcyr Midnightthetaco
    Jack
    North east
    3RZ 04 4x4 black ext cab
    2.5" lift king/total chaos Skids sliders rear tire swing
  6. Sep 7, 2017 at 3:51 PM
    Bruce988jl
    Southern NH
    I edited my post right as you quoted it reconsidering my decision exactly as you described lol
  7. Sep 7, 2017 at 5:10 PM
    Pugga
    Massachusetts
    That's awesome! I wish that solution existed when I still had my Tacoma! I like that it keeps the carrier in relatively th same spot. I did some reading abut dropping the cb and there are some compelling reasons why you shouldn't unless you're really lifted a lot. The reading I did actually lead you to slightly raising it a bit to get rid of vibrations.
    Bruce988jl[QUOTED] likes this.
  8. Sep 7, 2017 at 7:15 PM
    MikeyMcFly
    MikeyMcFly This is heavy, Doc.
    I'm a Masshole
    2016 TRD Off-Road 6MT / 2021 WRX STI
    Building a Broja
    Thanks for all the input! I will go through it and work on it in the spring. The Vette is on that side so it's not pressing and the small human is slowing my output.
    What is the best way to chip out the concrete? I don't have anything that will really work so it would be a HF trip regardless.
    I did get the wiring run for my powered sub today, I just need to do the terminations and securing.
    I ran my CB antenna wire for future work. It's going to kill me to power it with an add-a-fuse but since I don't have an aux fuse panel yet. I just have to decide which circuit to grab. I have a brilliant idea of how to integrate it into the truck.
    tacobell007 likes this.
  9. Sep 8, 2017 at 3:00 AM
    vssman
    vssman Rocket Engineer
    Paul
    Naugatuck, CT
    2013 SR5 double cab
    Morning all...
  10. Sep 8, 2017 at 3:31 AM
    smcgill
    smcgill Well-Known Member
    Sean
    South Easton Mass. not enough time in Cocagne NB
    Camry and Ram 1500 with a "HEMI "
    Friday ... :pccoffee:
    On my 2008 , crew cab ,long bed ... what would be the sequence to bleed the brakes ?
  11. Sep 8, 2017 at 3:32 AM
    smcgill
    Sean
  12. Sep 8, 2017 at 3:39 AM
    tacobell007
    tacobell007 Western Mass Automotive Coatings
    Drew
    Western MA
    06 Regular Cab Lifted
    Eibach springs, OME Dakars, Walker Evans remote resi coilovers with adjustable dampening, Icon tubular uniball UCAs, Icon ext travel rear shocks, Kenwood in-dash nav receiver, Kicker 10 inch sub in a ported truck box, Alpine 250 watt amp, stickers, Rigid 32" gang box, LED tool box lights, 35% tint, Flowmaster Super 44 muffler, 35x12.5x17 Mastercraft Courser MXT's, Fuel Off-Road Trophy d551 in 17x8.5, Retros, white corner marker bulbs, color matched front grille, custom satoshi grille mod with matching Toyota badge, aFe Pro5R drop in filter, diff breather mod, new frame from recall, SOS concepts front plate, SOS concepts rear high clearance plate with swing out and full size spare, SOS bolt-on sliders with kickout, 22" LED bar, flush mount pods in rear plate bumper for aux reverse lights, Rigid Industries dually's on SOS ditch light brackets, 5.29 Nitro gears, ARB front air locker, Detroit locker in the rear
    Farthest from the master and work your way closest. Pass rear, driver rear, pass front, driver front.
    Blais03, Pugga and Spare Parts like this.
  13. Sep 8, 2017 at 3:54 AM
    Cativelense
    Cativelense Well-Known Member
    Nuno
    CT
    2014 DCSB Black 4x4 TRD Sport
    -TRD oil cap -TRD radiator cap -TRD shift knob -2015 Entune system with Nav, -OEM roof rack -Front windows tinted to match back (20%) -BPK Skid Plate -Non clock hazard switch assembly -WeatherTech floor mats -AFE Stage II Pro Dry Intake -AVS Vent Shades -AMP Research bed extender -Horn relocation mod -Bob's Mirror -Redline hood struts -UltraGauge MX 1.3 -Debadged -Reverse LEDs & shifter bezel LED -Black steering wheel controls, black shifter bezel, black AC vent panel -Black gauge cluster rings + black tweeter rings -Morimoto XB LED fog lights -Anzo tail lights -Hilux 4x4 lighted switch -Bed mat -Hondo Garage radio knobs -OKLED 20" light bar mounted on BAMF behind the grill mount -CH4X4 LED light bar switch w/add-a-fuse -nd4spdbh fog light anytime mod (HUGE thanks to @tgriff) -Debadged bed -Secondary air pump filter -Retros (Morimoto Mini H1's and Morimoto Panamera shrouds with dual intensity LED DRL's & 5000k bulbs) -Tailgate Anti-Theft Device by @scleaf -OEM TRD Sport 17" wheels painted black w/Bridgestone Blizzak DM-V1 tires (Winter wheels) -Pro Comp Extreme 17" wheels w/Firestone Destination LE2 tires (Spring/Summer/Fall wheels) -Anzo blacked out third break light -HomerTaco Tacoma Ghost Raptor Insert -Rear diff breather mod (HUGE thanks to @jc11taco89) -Fumoto Valve -LEER 100R -Salex center console and glove box organizers -Power Pop N Lock -Mobtown Tailgate Skin -TRD Pro suspension with HS Progressive AAL (overload leaf in) -ECGS replacement bearing -Dust caps on rear drums to match front -Me-So Customs "The Gasshole" -ACEkraut license plate bracket -mesojdm's 2nd Gen Ultimate LED Dome and Map lights -Seat spacers from olecoot -Bullaculla Trailer Harness Relocation Bracket
    Happy Friday everyone.
  14. Sep 8, 2017 at 4:25 AM
    js312
    js312 Well-Known Member
    Joe
    New England
    23 F150 PowerBoost Lariat 502a
    Husky Weatherbeaters, OEM Mud Guards, Wheel Well Liners, Bullet Spray-In Bed Liner, Gator Soft Tri-Fold Cover, Michelin LTX M/S2 (Summer), Blizzak DM-V2 (Winter)
    Do yourself a favor at the same time and pull your drums off and clean them up while you're at it. Then make sure they're adjusted right. Mine weren't and that made a big difference in braking for me.
  15. Sep 8, 2017 at 4:25 AM
    Pugga
    Massachusetts
    For chipping concrete, you can use a good ole fashioned masonry chisel and a maul or a chipping gun. It's easy to get carried away with a chipping gun though. For the little pit you'll be doing, a chisel will work just fine. You're not trying to out a lot of material.
    x2
  16. Sep 8, 2017 at 4:29 AM
    Bruce988jl
    Southern NH
    Welp - it isn't the carrier bearing - it's a small pinhole leak at the top of the super rusty exhaust.... But I have a ton of play in the DS Carrier bearing so I might order one just in case....
    Super excited for the yota run - might be my last run for the year with my work travel schedule.
  17. Sep 8, 2017 at 4:32 AM
    Bruce988jl
    Southern NH
    Normally my go to is C4... but seeing as though you want the rest of the building to survive I have heard good things about demo hammers. Plus its fun to use... not this particular brand but I have used a makita and it was great.
    http://toolguyd.com/bosch-dh507-demolition-hammer/
    Sloth likes this.
  18. Sep 8, 2017 at 4:51 AM
    Pugga
    Massachusetts
    Like I said, the rubber around those bearings are sloppy on a good day. When I still had mine, I pumped RTV into the rubber (the rubber is hollow) to try to stiffen it up a bit and it did help some. The rubber around the Dorman bearing was significantly more rigid and all of my vibrations went away, the bearing itself was just garbage. When I went back to OEM, my vibrations came back but the bearing itself was much better quality.
    Haha, demo hammers are a lot of fun, but very easy to get carried away with. They can do a lot of damage in a very, very, very short amount of time.
  19. Sep 8, 2017 at 5:00 AM
    tacobell007
    Drew
    Western MA
    Demo hammers are a good time, most of the time. We occasionally had to use them when I did seamless epoxy floors
  20. Sep 8, 2017 at 5:25 AM
    mach1man001
    mach1man001 [OP] eh whatever
    Rob
    Bellingham, MA
    2024 Tundra Limited
    I love my new truck but miss my Tacoma
    Morning all
    Bad play by the Patriots last night
    Spare Parts likes this.
