New England B.S. Thread
Discussion in 'North East' started by mach1man001, Feb 16, 2012.
  1. May 23, 2012 at 11:14 AM
    #1381
    eborgie
    eborgie No Yotas Here
    Erik
    Bellingham, MA
    2023 Bronco Sasquatch
    I dropped it off friday and had it back the following wednesday. I was in the bed of my truck over the weekend. I didnt have the time to get it put back on.
  2. May 23, 2012 at 12:47 PM
    #1382
    johnnym
    johnnym Well-Known Member
    john
    NH
    87 4Runner Chevy 1500
    Sas 4.7tranfer case gears 5.29s Locked front/rear
  3. May 23, 2012 at 1:58 PM
    #1383
    64Wildcat
    64Wildcat Black Jeep of the family
    Denis
    New Hampshire
    2015 Rubicon
    Decided to make a Hi-lift jack mount myself, now all i need is the sliders!:D
  4. May 23, 2012 at 1:58 PM
    #1384
    eborgie
    Erik
    Bellingham, MA
    Nice set up
  5. May 23, 2012 at 2:05 PM
    #1385
    emelianenkov
    emelianenkov Santa/Alex Emeliahoweveryouspellhislastname
    Alex
    NORTH POLE
    Alex's Shitbox Emporium
    NE Special Rust Edition
    It had to be said lol
  6. May 23, 2012 at 2:12 PM
    #1386
    64Wildcat
    Denis
    New Hampshire
    2015 Rubicon
    Just playin! :p
  7. May 23, 2012 at 2:16 PM
    #1387
    64Wildcat
    Denis
    New Hampshire
    2015 Rubicon
    Thanks!
    I found a piece 0f 1/4" x 2" flat stock in the scrap bucket at work and figured i'd give it a shot.
    I'm going to try to make a cb antenna mount for the olther side and see if i can find a swivel base like you were talking about.
    Does the Firestik come with evrything (cable etc.)
  8. May 23, 2012 at 2:18 PM
    #1388
    BostonBilly
    BostonBilly Well-Known Member
    Easton
    2018 Jeep Wrangler JL Rubicon
    just got back from my second free oil change from Toyota also looked at a Hilander for the bride
  9. May 23, 2012 at 2:39 PM
    #1389
    johnnym
    john
    NH
    Looks good Denis
    Is that a piece of rubber on the other end ?
    I'll be doing this myself this weekend + making a cb mount as well . First trail lastweekend fucking broke the mount that came with the cb . Funny thing was even with the antenna laying in the bed I could still hear everyone fine .
  10. May 23, 2012 at 2:51 PM
    #1390
    64Wildcat
    Denis
    New Hampshire
    2015 Rubicon
    The piece on the end is from an old rubber mallet i had lying around i cut it in half(1 1/2" each side) and screwed it to the end of the flat stock.
  11. May 23, 2012 at 3:25 PM
    #1391
    johnnym
    john
    NH
  12. May 23, 2012 at 3:31 PM
    #1392
    64Wildcat
    Denis
    New Hampshire
    2015 Rubicon
    That's what i've been looking for,does the Firestik come with the cable and hardware?
  13. May 23, 2012 at 3:45 PM
    #1393
    johnnym
    john
    NH
    I bought mine as a package deal . So I'm not sure .
  14. May 23, 2012 at 5:47 PM
    #1394
    eborgie
    Erik
    Bellingham, MA
    Mine came with everything
  15. May 23, 2012 at 8:06 PM
    #1395
    emelianenkov
    Alex
    NORTH POLE
    Typically the Firestik antenna is by itself, and sometimes the mounts come with coax cable
  16. May 23, 2012 at 8:15 PM
    #1396
    Eagledynasty
    Eagledynasty The White Knight
    AJ
    Worcester, MassHole
    09 Super White DoubleCab Off-Road
    2009 SWDC O/R. Check Build!
    I'm getting one of those but for marine use haha. An the CB im connecting it too is handheld so I can take it off whenever.
  17. May 23, 2012 at 8:22 PM
    #1397
    Eagledynasty
    AJ
    Worcester, MassHole
    Quick question for my Taco Genius's out there....
    When I start my truck, and put it in reverse (sometimes forwards) I hear some form of trickling like someone is hitting a small wrench to a hollow metal pipe (pretty quietly but repeatedly) from the drivers side front wheelISH. Or just drivers side in general. I also hear it when radio is down to zero, and I'm off the gas enough to not hear the muffler and something solid is next to me to relay the sound back. Any ideas greatly appreciated!!! I'll see if you guys can diagnose the problem before I bring it to my local shop either friday or saturday for them to run a small checkup physical on my girl haha. I wont get anything done from those $$$ stealers
  18. May 24, 2012 at 4:28 AM
    #1398
    johnnym
    john
    NH
    Is there any way you could take a video of it?
  19. May 24, 2012 at 4:56 AM
    #1399
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    Make sure none of the dust guards are rubbing the rotor. I doubt that's the problem because it usually makes an awful sound but start with the small stuff!
    Does speed make the sound faster or louder? Any tie to engine RPM or only when you're moving? If you take a short drive, touch the wheel to see if it's hot which would indicate a brake disc dragging.
  20. May 24, 2012 at 6:42 AM
    #1400
    Eagledynasty
    AJ
    Worcester, MassHole
    I will try today. Probably need my brother to hold the camera when I put it in reverse. Will do it after work today!
    Could be I'll see how hot the wheel is after a ride.
    The sound does not increase the faster I go as far as I know. I will run some tests and give you guys a better evaluation after work. I don't believe its anything big it almost sounds like a lose bolt just shaking around.
    ALSO when you guys close the drivers side door/ drivers side rear door does your rear fender (bed fender) shake a little? Theres a missing tab from inside my bed on that side missing BUT I dont believe thats what holds it in place.
    Just a couple small fixes im going to work on over the next couple weeks. Any info helps! Thanks guys!!!
