New England B.S. Thread
Discussion in 'North East' started by mach1man001, Feb 16, 2012.
  1. Jul 25, 2021 at 6:14 AM
    AllTacosFloat
    AllTacosFloat If yours sank you’re entitled to compensation
    Boston ish
    Has lockers a skewp and a bit of droop
    jpereira2[QUOTED] likes this.
  2. Jul 25, 2021 at 7:55 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    is there a thread on it...
  3. Jul 25, 2021 at 8:04 AM
    js312
    js312 Well-Known Member
    Joe
    New England
    23 F150 PowerBoost Lariat 502a
    Husky Weatherbeaters, OEM Mud Guards, Wheel Well Liners, Bullet Spray-In Bed Liner, Gator Soft Tri-Fold Cover, Hankook DynaPro AT2 (Summer), Blizzak DM-V2 (Winter)
    Realized I never put up photos of the wheel well liners and vent visors that I got for free:
    O9HQCrA_tszNRe2JlhRpEeZ5lRX7F54-hgjHCyjI_587cb5686d7b38524be195f2aad9ddd6d52255c0.jpg
    71Qvj2tL5fz9muNXMvaaLqvUOtF0mm7YWbyaRkak_e0927d1e4dba384f1858f44b75b86ed4c69e62d8.jpg
    Also, we drove from home to Foxboro and back yesterday and this was my round trip mileage (plus one trip to work and back before):
    WwCORJDuxtJnxa8ZPUr30vWPHRNanvekaSv9IJnx_e31541bbc43246098c226dc3cd12af6390c82202.jpg
    Not bad for a 5300 lb truck with 470 ft lbs of torque!
  4. Jul 25, 2021 at 9:13 AM
    GarlicFarts
    GarlicFarts Bertolli Roberto
    Lil Rhody
    2020 White DCSB TRD OR
    SOS bolt-on sliders In-cab sleeping platform J-Dub IFS Skid
    rotors aren’t bad. If you can hobble down to a shop to do a full bleed after then you’re good. You have a compressor though so you can easy diy.
    Welcome to the thunder dome.
    just quoting this so I remember to look at it later. I’m doing my brakes soon probably before the winter. Have 35k on them.
    Brownmatthall[QUOTED] likes this.
  5. Jul 25, 2021 at 3:37 PM
    Pugga
    Massachusetts
    Another big thumbs up for the RV industry QC department... I think posted here when I bought a Furrion backup camera because my Keystone was prewired for one. Supposed to be a 10 minute ‘plug and play’ job. Plugged in the camera, no power. Called the dealer, they told me it should work, no fuses or other things to check. Finally dug into it today. You can’t get at the wiring from the inside without pulling panels down (not doing that). So I decided to pull the center marker light and use the ‘new install’ wiring pigtail that came with the kit. When I pulled the light, there were 2 wires that looked an awful lot like the Furrion wires I had in my hand, already tapped in. Give the, a tug, sure enough those are the wires. I can now see the whole wire, it’s not chaffed or damaged, ok let’s just cut the light wires and tap in the new kit. I wired them up the way the old one was wired (wires in the back of the camper are funky colors so you can’t tell + or - just by the wire color), turn on the lights, camera still doesn’t work. Switch the wires, camera works fine... In conclusion, the fine people on Keystone’s assembly line got the wires backwards at the factory. My 10 minute install turned in to about a 2 hour trouble shoot and re-wiring but, the camera works great and i’m very much looking forward to having that for our next trip!
    Bridge4, jpereira2 and dc welding like this.
  6. Jul 25, 2021 at 5:34 PM
    jpereira2
    jpereira2 Well-Known Member
    Massachusetts
    2013 double cab trd off road
    Bilstein 6112 4th notch Bilstein 5160 rear Camburg ball joint UCAs Old man emu dakar leafs 265/75R16 Cooper ST Maxx Crux stereo a/v interface UltraGauge ARE fiberglass cap Wet okole seat covers Retro fit source Led fog lights Superbrightled pods in rear bumper Superbrightled light bar in grill Rock blokz mud flaps SOS Rock Sliders RCI Skid Plates (to be painted and mounted)
    How big is your trailer? I get tempted but I feel like ours is small enough and I don't need it much for it to be worth it
  7. Jul 25, 2021 at 5:43 PM
    Pugga
    Massachusetts
    Mine’s a 24’ box so about 28’ tip to tail. In my opinion, length is irrelevant, it could be 10’ long an you still can’t see behind it. I back mine in to my back yard regularly and it’s a 10’ gate so sort of threading a needle. I figure any damage avoidance because I stop before hitting something I don’t see will be worth it. It has a night camera also which is sort of cool.
    Bridge4 and jpereira2[QUOTED] like this.
  8. Jul 25, 2021 at 7:10 PM
    replica9000
    replica9000 Das ist no bueno
    Lake Chargoggagoggmanchauggagoggchaubunagungamaugg
    2019 T4R ORP
    Damn, my 4Runner was getting about 400 miles driving range (before lift/tires), and you're getting that with half a tank. My tank is only 23 gallons though.
  9. Jul 26, 2021 at 3:30 AM
    js312
    Joe
    New England
    This is 36. It usually reads between 700 and 800 when full.
  10. Jul 26, 2021 at 4:18 AM
    Pugga
    Massachusetts
    I love the big tanks. I'm a little smaller and top out at 34 gallons but that extra range when towing is incredible. If the Titan or S&B tanks weren't so damn pricey, I'd love to have one and be able to hold 55 or 60 gallons of fuel but, the $1,000 they cost buys an awful lot of fuel...
    Bridge4, ABA180 and js312[QUOTED] like this.
  11. Jul 26, 2021 at 4:46 AM
    jethro
    jethro Master Baiter
    Geoff
    Southern NH
    2020 Ford F-150 Lariat 5.0L V8
    I've got those on my truck right now, they are hot garbage. Really bad tires.
    I got the 26 gallon tank and mine usually reads 520 or so when I fill up. I drove home from Pittsburg NH last night and the mpg was reading 21.5. When I hand calculate it's usually a half mile per gallon optimistic. That EB motor has impressive performance and economy.
    js312[QUOTED] likes this.
  12. Jul 26, 2021 at 5:04 AM
    js312
    Joe
    New England
    There's a way to correct that calculation. If you find it's always about 1/2 MPG high at around 20 MPG, you'd want to adjust to 97.5% of its typical reading. If I remember correctly, you hold OK while turning the truck on (but not starting the engine). It'll do a gauge cluster test then you can cycle through readouts for pretty much every sensor the truck has and eventually you'll get to "AFE (Average Fuel Economy) Bias". I think it says 1000 if nobody has ever messed with it, so you'd change it to 975. I changed it on my 2.7 so it was dead on, but I keep forgetting to hand calculate this one so I haven't adjusted on this truck.
    GarlicFarts likes this.
  13. Jul 26, 2021 at 5:22 AM
    GarlicFarts
    Lil Rhody
    Damn - must be nice! Maybe Forscan has something for that too?
    Anyway - I just use the fuelly method. I do my own excel sheet instead of using the fuelly app, integrated it into maintenance schedule too. I just use the odometer though, not gps tracking my mileage.
    Bridge4 likes this.
  14. Jul 26, 2021 at 5:40 AM
    mach1man001
    mach1man001 [OP] eh whatever
    Rob
    Bellingham, MA
    2024 Tundra Limited
    I love my new truck but miss my Tacoma
    I am no-way near as organized as you!
    Bridge4 likes this.
  15. Jul 26, 2021 at 6:02 AM
    GarlicFarts
    Lil Rhody
    It's a smidge of up front work. After that it's just basically writing the mileage on the receipt at the gas station when I fill up.
    Fuel fill up log:
    Input date, and fill up details (all off the gas receipt)
    Then I have a table that uses that data to tell me miles per month and MPG in that month too. Good show that winter sucks.
    Service dashboard - tracks services dependent on age or mileage, and pulls the most recent date and odometer reading - tells me how long until the next thing according to the toyota service interval. So I don't have that stupid window sticker in the dashboard.
    And I've added some things too. Alignment is cheap and I wheel it, so do that once a year etc.
    ....I work in quality assurance in aerospace maintenance, it might have bled over a little into my vehicle maintenance :spy:
  16. Jul 26, 2021 at 6:02 AM
    Pugga
    Massachusetts
    Amen. That and my mileage is down from all the towing during the summer. Lifetime average on the truck, since I bought it, is at 14.5. I'm getting 11-12 towing and anywhere between 18-20 unloaded. The dash read out is actually pretty close to the hand calc when I spot check it.
  17. Jul 26, 2021 at 6:03 AM
    Pugga
    Massachusetts
    Nice. All the maintenance items I generally write in on the back cover the Owner's manual. I don't track fuel economy but I track oil changes, alignment, new tires, tire rotations, air filter, diffs, etc.
  18. Jul 26, 2021 at 6:41 AM
    jethro
    Geoff
    Southern NH
    I just change oil when the light comes on. :crapstorm: And replace transmissions when the gears start disappearing.
    I don't really belong on a car enthusiasts forum.
  19. Jul 26, 2021 at 7:13 AM
    Pugga
    Massachusetts
    Fixed for you.
    And, let's be honest... We're really BS enthusiasts with an interest in cars.
  20. Jul 26, 2021 at 7:16 AM
    GarlicFarts
    Lil Rhody
    I only track fuel econ because it falls in place and the stuff's already there. And because I'm curious. Date and mileage is already there, add the gallons to fill up might as well. :notsure:
    Let's be honest - knowing me, there's a likely chance this will be on my lawn mower soon :rofl: nah - I do need to do an oil change there but that's it.
