New England B.S. Thread
Discussion in 'North East' started by mach1man001, Feb 16, 2012.
  1. Apr 22, 2022 at 6:22 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    Gates makes some good stuff.
    RobP62 likes this.
  2. Apr 22, 2022 at 6:23 AM
    tacobell007
    tacobell007 Western Mass Automotive Coatings
    Drew
    Western MA
    06 Regular Cab Lifted
    Eibach springs, OME Dakars, Walker Evans remote resi coilovers with adjustable dampening, Icon tubular uniball UCAs, Icon ext travel rear shocks, Kenwood in-dash nav receiver, Kicker 10 inch sub in a ported truck box, Alpine 250 watt amp, stickers, Rigid 32" gang box, LED tool box lights, 35% tint, Flowmaster Super 44 muffler, 35x12.5x17 Mastercraft Courser MXT's, Fuel Off-Road Trophy d551 in 17x8.5, Retros, white corner marker bulbs, color matched front grille, custom satoshi grille mod with matching Toyota badge, aFe Pro5R drop in filter, diff breather mod, new frame from recall, SOS concepts front plate, SOS concepts rear high clearance plate with swing out and full size spare, SOS bolt-on sliders with kickout, 22" LED bar, flush mount pods in rear plate bumper for aux reverse lights, Rigid Industries dually's on SOS ditch light brackets, 5.29 Nitro gears, ARB front air locker, Detroit locker in the rear
    I get mine from rockauto and they seem alright. I'd order Dayco or Gates pulleys, and just make sure they go in the right location. Someone put an upper idler in the lower spot on mine and it was causing premature failure
    RobP62 likes this.
  3. Apr 22, 2022 at 6:55 AM
    RobP62
    RobP62 NVR20LD
    Rob
    Street, Md.
    TTC Member #0125
    WUUUF! :drool::drool::drool: :bowdown:
    Looks like a Porsché?
    3Riverz88 likes this.
  4. Apr 22, 2022 at 6:56 AM
    Pugga
    Massachusetts
    Lexus LFA
  5. Apr 22, 2022 at 6:58 AM
    RobP62
    RobP62 NVR20LD
    Rob
    Street, Md.
    TTC Member #0125
    Thank you. We did all the work ourselves. There was a wood burning stove there but the bar suited our lifestyle better. We have a furnace and in an emergency, the grill can be rolled into the kitchen :D
  6. Apr 22, 2022 at 6:58 AM
    RobP62
    RobP62 NVR20LD
    Rob
    Street, Md.
    TTC Member #0125
    Can't like this one Rob.
  7. Apr 22, 2022 at 7:00 AM
    RobP62
    RobP62 NVR20LD
    Rob
    Street, Md.
    TTC Member #0125
  8. Apr 22, 2022 at 7:26 AM
    mach1man001
    mach1man001 [OP] eh whatever
    Rob
    Bellingham, MA
    2024 Tundra Limited
    I love my new truck but miss my Tacoma
    That's exactly what I did when I changed mine a couple of years ago. Now I'm just doing the tensioner and belt along with changing the coolant (last changed the coolant when I did the previous belt/pulleys too). All the new parts are already acquired. I probably won't get to installing them until Sunday though. I've got to work tonight and I haven't gotten any sleep yet.
    uurx[QUOTED] likes this.
  9. Apr 22, 2022 at 7:35 AM
    Bruce988jl
    Bruce988jl Well-Known Member
    Southern NH
    08 Tacoma Dbl Cab TRD Off-Road & 05 Mitsubishi Evo
    I have their brightest pnp bulbs in my fusion and tacoma (both tinted out) and they're awesome.
    Shoot me a PM with your zip code for shipping and I can throw something together.
    AllTacosFloat and tacobell007 like this.
  10. Apr 22, 2022 at 7:39 AM
    Bruce988jl
    Southern NH
    Are you doing the entire tensioner as well?
    Also for everyone looking into the pulleys here's a comparison I did a few 40k miles ago...
    https://www.tacomaworld.com/threads/4-0-idler-pulley-replacement-oem-vs-gates-reference.516475/
  11. Apr 22, 2022 at 7:55 AM
    BadDNA
    BadDNA Uh, huh huh... Member
    Eammon
    Cabot, VT
    '15 Blue Ribbon Metallic DCLB SR5 4x4
    OME BP-51s, JBA UCAs, Dakar leaf pack, Hammer Hangers, SOS Skids and sliders, Mobtown Tailgate reinforcement, Bussman fuse block, and stuff...
    I'm closing in on 145k and have never changed the belt, idlers or tensioner...I should probably make a point of grabbing those all to have on hand for when I do start hearing noises.
    Rexfordian13, JeffB and Brownmatthall like this.
  12. Apr 22, 2022 at 8:10 AM
    crashngiggles
    crashngiggles Tacomaworld's Resident Psych Dr.
    Jared
    Wilbraham, Massachusetts
    2013 MGM TRD 4x4 DCLB Trail Limo
    So going over that thread, would you recommend all of the Idler pulleys and tensioner from gates or directly replace with OEM? Should i replace the entire tensioner or just the pulley on the tensioner? I know that you were asked that question in the first couple of posts but now that you have had them for a while you might be able to give a better assessment of the gates ones.....
  13. Apr 22, 2022 at 9:39 AM
    Bruce988jl
    Southern NH
    Honestly if I went back and did it again, I'd take the OEM tensioner pulley off (if it was in good shape, mine was) press the bearing out and press a new one in. I actually kept my old pulley and pressed in a new bearing for when I have to do the maintenance again. The same applies for the OEM idlers, granted one of my idlers was pretty rough looking it polished up fine after putting it on the lathe and slowly removing the corrosion or whatever the build up was.
    If you're looking for a one and done job then grab the gates kit and swap the pulleys from the tensioner over. Install the belt and cycle it a few times and check the spacing of the belt on the tensioner pulley. I have 40k on the truck right now with this setup and an OEM belt with the only issue is if I hit some deep puddles and dirt gets up on the front side of the engine the pulleys might squeak for a bit a day later then it goes away. The reason why I needed to do my pulleys was because I went into some silt infested water down in RI and it got into the pulleys when I got stuck - it got worse over the next 5k miles until one of the pulleys blew up on the highway. I was actually still able to drive home, it wore down the belt but overall it still held just sliding on the inner race of the blown out bearing.
    tacobell007 and AllTacosFloat like this.
  14. Apr 22, 2022 at 9:42 AM
    AllTacosFloat
    AllTacosFloat If yours sank you’re entitled to compensation
    Boston ish
    Has lockers, a skewp and a bit of droop.
    218k and only ever changed the belt:anonymous:
  15. Apr 22, 2022 at 9:44 AM
    AllTacosFloat
    Boston ish
    In my defense I have the entire kit in the bed of my truck. It's insurance that that won't break.. Just stuff you don't have seems to fail.
  16. Apr 22, 2022 at 4:16 PM
    Clark27
    Clark27 Well-Known Member
    Springfield, MA
    2015 Lexus GX460
    Closing on a house now and going down the big shed and/or small barn route and it’s EXPENSIVE. I’m talking like 16x20 for 30-40k. It’s wild.
  17. Apr 22, 2022 at 5:53 PM
    DoubleRGirl
    DoubleRGirl Hello Kitty Edition
    Rebecca
    Rhode Island
    2015 DCSB TRD Sport 6speed
    After watching our house go up I can see why it's so much more expensive to build out than up
  18. Apr 22, 2022 at 8:33 PM
    Turd Ferguson
    Turd Ferguson Well-Known Member
    Taxachusetts
    2014 DC TRD Offroad Automatic
    How many miles do you have on your truck? I’m at 152K and only changed the belt once a lot of miles ago. Probably should change it again soon. Now I’m nervous about the pulleys.
  19. Apr 22, 2022 at 8:34 PM
    DoubleRGirl
    Rebecca
    Rhode Island
    We've found 7 ticks in the house in 3 days. Do we just burn it all to the ground at this point?
    mach1man001[OP] and GarlicFarts like this.
  20. Apr 22, 2022 at 8:42 PM
    ABA180
    ABA180 It burns when I pee....
    East Bridgewater MA
    Pioneer CD, Megaloud/JBL amps, Rockford/Polk speakers.
    Please share...not that I'm looking to do either but just curious
    Get the yard sprayed. Hate those damn things.
