New exhaust leak
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 6spdtaco, Mar 20, 2010.
  1. Mar 20, 2010 at 6:34 PM
    6spdtaco
    6spdtaco [OP] Well-Known Member
    VT
    Taco
    just installed the TRD exhaust. There is an air leak where the two flanges meet. Any suggestions for a fix? Sealant of some sort.
  2. Mar 25, 2010 at 8:47 AM
    6spdtaco
    VT
    Taco
    for anyone who might care, I put some high temp gasket maker on the OEM gasket. Seems ok for now. A little concerned the direct heat of the exhaust might burn up the sealant.
  3. Mar 25, 2010 at 9:26 AM
    Masada
    Masada Well-Known Member
    Taylor
    Laveen, AZ
    05 Tacoma 4x4 TRD Off Road
    All Pro Steel Plate Front Bumper| All Pro Light Bar| All Pro IFS Skid Plate| All Pro E-locker guard| PIAA 510 Fog Lights| Hella 700FF| Fox 2.5 Coilover| Bilstein 5100 on the rear| BHLM| Grill Craft MX Series insert| Added two D-rings to bed|AVID Off Road sliders| AFE Dry Flow S| Gibson Cat Back| Custom Bedbar with hilift mount| Camburg 1" Uni-Ball UCA's| Hi-Lift 48" Extreme
    I had a similar problem with my Gibson and I just bought a new gasket from autozone and it fixed the problem...
  4. Mar 25, 2010 at 9:38 AM
    mak90
    mak90 Well-Known Member
    Central Coast, Ca.
    06 Tacoma 4x4 TRD Off Road 6 spd
    TRD Exhaust, TSB springs,Weathertech mats,Bed mat, Wet Okole seat covers, TRD Pro Suspension
    When i put my TRD exhaust also bought the gasket so i did not not have any leaks. You might try changing the gasket.
  5. Mar 25, 2010 at 9:46 AM
    memario1214
    memario1214 Hotshot Offroad Moderator Vendor
    Colton
    Missoula, MT
    SOLD - 05 Dub Cab TRD Sport 4x4, CURRENT - '21 Tundra MGM Limited
    That shouldn't be happening... Are you sure that there aren't any imperfections in the metal on each of then ends? If that is the case, no gasket will fix it.
  6. Mar 25, 2010 at 6:26 PM
    6spdtaco
    VT
    Taco
    everything looked as it should. When I installed the exhaust I used a new gasket also. Haven't checked to see if the sealant worked yet, been riding bikes around since the weather is nice.
  7. Mar 25, 2010 at 6:37 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Correct. A good idea when changing exhausts, is to clean the gasket mating sufaces with some fine grit sand paper before installing the gasket/s. A thin film of Copper RTV doesnt hurt either.
