New frame difference ??
Discussion in '2nd Gen. Tacomas (2005-2015)' started by george3, Mar 3, 2016.
  1. Mar 3, 2016 at 2:23 PM
    george3
    george3 [OP] Well-Known Member
    new jersey
    tacoma
    Seat belt beeper, Cabelas (Weathertech) floor liner gray, Covercraft Seat Savers in Taupe, Protecta Heavy Duty Rubber Truck Bed Mat, Pop n Lock PL5200, Pace Edwards Full Metal JackRabbit, Wolverine oil pan heater, Scangauge2, afe pro dry s filter, Remote Underbody 4 Piece LED Light Kit (White) used as Bed light, DIY Washable Cabin Air Filter, PA15-TOY, 4x4 Illuminated Switch, full synthetic, Redline Tuning Hood Support, Smittybilt Nerf Steps black powder-coated
    Does anyone know if or what the difference is between the new frames they are using vs the rusted out frame - beside there is no rust yet ?? Any answer or link appreciated.
  2. Mar 3, 2016 at 2:33 PM
    DriverSound
    DriverSound Señor Member
    SoCaca
    2015 DCSB OR 4x4
    Too few to list.
    As far as I know, same frame just different rust coating.
  3. Mar 3, 2016 at 3:31 PM
    Fitz235
    Fitz235 Well-Known Member
    New Hampshire
    Black '05 AC TRD Offroad 4WD
    - Bilstein 5100's Set to 1.75" - Wheeler's 2" AAL - Toytec 1/4" Driver's Side Spacer - ECGS Bushing - Powdercoated Tundra Wheels - 265/70/17 Toyo Open Country 2's - TRD Catback Exhaust - Access Lorado Tonneau - Factory Tube Steps - Jumper's Interior LED Map/Dome Lights - Pioneer AVIC 5100 NEX - Sony Speakers - Depo Black Tail Lights - Kleerz Third Brake Light - HomerTaco Satoshi Grill
    I have a feeling this thread will die an early death.
    I have done a ton of reading on this subject, and I have no idea if anything is different. I asked the service writer at my dealer, and he said the drainage was different. He pointed to a couple of "new" drainage holes, which happened to be in the same spots as the old frame. His response wasn't very convincing. It is definitely a different frame from my original, but as far as anything being different with the drainage issue, I guess we'll have to wait, and see.
  4. Mar 3, 2016 at 4:04 PM
    george3
    new jersey
    tacoma
    Interesting - Thanks for the replies. So far I've got 1 1/2 times book for a 2000 in 2008 and a new frame for a 2008 in 2016 - that' every eight years - wonder what I'll get in 2024 when this frame rusts out - since it is the same frame I'm sure it will ?
  5. Mar 3, 2016 at 4:19 PM
    Clearwater Bill
    Clearwater Bill Sometimes when I close my eyes, I can't see.
    Billy
    Largo Florida
    '13 5 lug base AC w/convenience package
    I'm confused. How can you not know and know? Am I reading it wrong?
  6. Mar 3, 2016 at 4:27 PM
    Fitz235
    New Hampshire
    Exactly what I said, the frame is different, but I'm not convinced that the problem with the original design/rustproofing has been fixed.
    Nice work on the selective quoting though.
  7. Mar 3, 2016 at 4:36 PM
    Clearwater Bill
    Billy
    Largo Florida
    So you mean it's different, in that you know you got a new frame? Or it's different in some structural/visual way?
    I agree about not being convinced that the quality/rust prevention grade of material has changed....... one can only hope.
  8. Mar 3, 2016 at 4:41 PM
    Fitz235
    New Hampshire
    Well, I have an '05, and I believe the design changed in '07, '08, or '09 due to the problem many had with the motor mounts. So for me, structurally it's definitely different than the original. The body mounts also look different than the original.
    Clearwater Bill likes this.
  9. Mar 3, 2016 at 4:43 PM
    Clearwater Bill
    Billy
    Largo Florida
    Gotcha, thanks!
    Fitz235 likes this.
  10. Mar 3, 2016 at 4:51 PM
    Fitz235
    New Hampshire
    Anytime Sir.
  11. Mar 3, 2016 at 5:08 PM
    Cape Codder
    Cape Codder Native Son
    Jack
    Hangin' Out in the Atlantic
    2010 TRD Sport 4x4 Access Cab 4.0L V6 Auto - Silverstreak Mica
    SOS Concepts Sliders waiting for POR-15 Rust Abatement (Spring 2016), OEM Silver Tube Steps 'til then OME 2.5" Suspension w/885 Coils & Dakars / LR UCA's w/SpecRide Bushings / Lifetime Alignment Wheeler's "Super Bump" Bump Stops Front & Rear / OME Carrier Bearing Drop / 2.5° Axle Shims (Eliminated Vibration) Moog Greaseable LCA Cam Bolts / ToyTech Sway Bar Relocate Kit / Stainless Steel Extended Brake Lines (Front & Rear) TIRES - LT275/70R17 (32.2") Firestone Destination A/T's (and Matching Spare) mounted on (5) 17”x8” (4.5” BS) Machined Aluminum Alloy, with Light Gunmetal Accents, Konig SixShooter Wheels with Hofmann Anthracite Adhesive Power Weights / McGard 65002 Chrome SplineDrive Lug Nuts / Cloned Schraeder EZ Sensor 33000 TPMS SNOW TIRES - Bridgestone Blizzak DM-V1 - P255/75-17 (32.1") mounted on Stock TRD Sport Wheels (5.5” BS) w/BORA 1" Wheel Spacers (to = 4.5” BS), Wheels Locks & OEM Lug Nuts Wheel Master 36" Stainless Steel Mesh Spare Tire Inflator/Checker attached to Rear Bumper / Spare Tire Lock TRD Skid Plate / Husky Mud Flaps / Redline Tuning Hood Struts / UltraGauge / Frame Hole Plugs / OEM Chrome Exhaust Tip Salex SLX102 - '05-'13 Tacoma GloveBox & Console Organizers Combo Set / GRID-IT (Console Cover Organizer) Color Matched SATOSHI Grill w/ Individual Letters Toyota Emblem (from ‘86 Toyota Land Cruiser) Hella Fogs on Elusive Elements Light Bar mounted behind Grill / Relocated Horns & Outside Temperature Sensor SilverStar zXe Headlights / SilverStar Fogs / Upper & Lower Color Matched Eyelids / LED's @ Dome, Maps, Lic Plate & 3rd Brake / 866 Foglight Lamps for Back-Up Lights WeatherTech Headlight & Foglight Protection / AutoBahnd RoadBlock (3M) Paint Protection System on Front End & Tailgate Avid Hitch Step Color Match Powdercoated / Avid LightBar Color Match Powdercoated / DIY Front Plate Holder mounted on AVID Light Bar (NO Bumper Holes) Emblems DeBadged / CBoy808's Silver OME EMU, Medium Gray Mall Rated, TRD Skid & Matte Black US Flag Decals SockMonkey Medium Gray Shadow Only Bedside, Door, Hood Scoop & Tailgate Decals DeBadged Leer 100LX Cap w/ Adventure Pkg including Thule 48” & 60” AeroBar Locking Removable Racks, Removable Front Window & Rear Door Remote Lock Charcoal/Blk Wet Okoles (front & rear) w/Front Seat Back Waterproof Zippered Pockets, Front Pistol Pockets & Seat Heaters / Drop Stop Seat Wedge Fillers 6 CD Changer w/SubWoofer (TRD Sport OEM) / BluLogic Hands Free (Blue Tooth) / Lutron Maestro Pico Remote Control for Driveway Floods Pro-Fit & Pro-Clip Device Holders for Cell Phone & GPS / Beltronics RX 65 Blue Detector / Garmin 885T GPS 30% Tint on Driver/Passenger Windows / WeatherTech Dark Front Window Deflectors / AutoMate AM-7 Alarm w/Remote Start WeatherTech FloorLiners (Front & Rear) / WeatherTech All Weather Mats (Over Front Liners) TRD "Offroad" Front Recovery Hook (Color Matched) / 2" x 30' & 3" x 30' Recovery Straps ELITE OffRoad 2" Receiver Hitch Shackle / Daystar Black Shackle Isolator / LifeLong Locks Class 5 Locking Hitch Pin Viair 00088 88P Portable Air Compressor / Rockford 12,000mah, 200/400 Amp, Portable Power Source & Mini Jump Starter Pop&Lock PL5305 Manual Tailgate Lock w/Color Matched Handle / Driver's Door Keytechniques Keyhole Cover OEM Bed Mat / 4 Extra Military Issue Bed "D" Rings Attached with Bed Bolts / 4 Extra Bed Rail Tiedowns & 2 Mini Tiedowns H3R Performance Halguard Halotron® 1 (Clean Agent) - HG250C 2.5lb Chrome Fire Extinguisher and Extreme Duty Quick Release Bracket (Mounted in Bed) H3R Performance Halguard Halotron® 1 (Clean Agent) - HG100C 1.4lb Chrome Fire Extinguisher (In Cab Back Door Pocket) H3R Performance MX500R - 5lb Dry Chemical Fire Extinguisher w/ Vehicle Mount (On Cab Back Floor, Not Yet Mounted in Bed) ResQMe GB0-RQMTWIN-O Orange Keychain Version of the Original LifeHammer (Hanging Within Reach in Cab) FogLight Anytime / Differential Breather / A/C Condensate Drain / Tailgate Hoseclamp Anti-Theft Mods Toyota Extra Care Platinum Vehicle Service Agreement (VSA) – 8 Year / 125,000 Miles TSB's: Transmission TSB / Blower Motor TSB / Steering Intermediate Shaft Bushing TSB 90L Accelerator Pedal D0L Recall / Driver & Passenger Seat Belts Recall / Inspect Wheels & Tires "BOB" Recall The “TW EMPTY UR WALLET MOD” and a Pile of Stuff Waitin' for Install
    Growing up, I recall something about "Learn from your Mistakes" :notsure:
    CC
  12. Mar 3, 2016 at 5:20 PM
    balljoint
    balljoint Well-Known Member
    Dave
    Ontario
    '18 DCLB
    Hopefully it is the metallurgy that is different.
    oldtoyotaguy likes this.
  13. Mar 3, 2016 at 5:21 PM
    oldtoyotaguy
    oldtoyotaguy Well-Known Member
    Peter
    Ontario, Canada
    2018 4 Runner ORP
    Stock but with a Warn 10s winch Used to be a lightly modded Tacoma
    With the cost Toyota is absorbing from this recall, I can't believe they would continue making the same frame. Improving the steel would be better than a coating, IMHO. But who knows? Someone in Toyota must know.
  14. Mar 3, 2016 at 5:22 PM
    BlueT
    BlueT Well-Known Member
    NorthEast
    07 Dbl Cab LB with LSD
    No difference, and if you ask me paint job is even worse on new one than what was on old one. Atlas on old one nobody could see bare metal when it was new.
  15. Mar 4, 2016 at 12:52 PM
    Hot Tacoma Blown
    Hot Tacoma Blown Well-Known Member
    NewYork
    05 4×4 tacoma
    Super charged,urd u - conn computer 7th injector, headers, pipe bomb y pipe,high flow exhaust.etc....
    Just hAd frame replaced in my 2005 taco.Looks like my wife's 2013 Frame.Feels like new again. Slight variations in looks ONLY...
  16. Mar 4, 2016 at 2:36 PM
    fixnfly
    fixnfly Well-Known Member
    S.W.PA
    05 Access cab 4.0 4WD
    It still makes me wonder why Toyota has so many problems with rust. Do they ever learn from their mistakes?? Even GM can figure out how to make a good frame
