New fuel filter leaking
Discussion in '1st Gen. Tacomas (1995-2004)' started by pickuptruckguy, Jan 3, 2016.
  1. Mar 28, 2021 at 10:08 PM
    #41
    Toyoda213
    Toyoda213 Well-Known Member
    Jimmy
    SoCal
    2003 V6 dlbc Prerunner 4x4 converted
    i had the same issue when i replaced mine but my issue was i was not using a flared wrench so it was not tightening tight enough because i was almost stripping the fuel fitting.
  2. May 4, 2021 at 9:50 PM
    #42
    1997tacomav6
    Denver
    Same problem, the rear exiting line was leaking,
    Only way I could get it to stop was by putting another wrench connected to the box wrench in order
    to get more leverage.
    Using all my might the leak stopped
