new glass run?
Discussion in '1st Gen. Tacomas (1995-2004)' started by BrianPK, Apr 15, 2007.
  1. Apr 15, 2007 at 2:36 AM
    BrianPK
    BrianPK [OP] Offroad Enthusiast
    Modesto, California
    01 TRD 4WD V6 SR5
    CB Radio, 3'' fabtec spacer lift and 3'' body lift flowmaster dual exhaust, deckplate mod, silencer mod, Work in progress pioneer 7900bt stereo with 5X8 infinity speakers all around, and eclipse ex400 amp
    i started having some trouble with my driverside power window a few days ago. i thought the motor was going out, but the mechanic said i have a torn glass run. he also quoted me 300+ dollars to replace it ($122 for the part)
    i'm considering putting the part in myself to save some mulah... problem is, i don't know where i'd find a new one. local junk yards don't have anything above an 87 pickup.
    anyone know where i can buy a new one?
  2. Nov 23, 2020 at 5:29 AM
    AKsavanaman
    AKsavanaman Well-Known Member
    Lower 48 :( U.P MI
    01' Xtra Cab TRD, Kings, JBAs, Dakars and 295's on F5
    Kings, JBA's, Dakars, Prinsu Rack, ARB, Trail gear sliders... and rust
    This is gonna sound stupid, but mine was also very loose 5 years ago when I bought the truck... the glass would frequently fall out of the run because the motor just pulled them a apart. From what I remember I just used a couple strips of duct tape at the bottom of the window to make it fit more tightly.... it has worked for 5 years?!o_O:thumbsup:
    but if you’re replacing the run all together I’d imagine the hardest part is finagling it into place once the door panel is off, everything else should bolt right up.
  3. Nov 23, 2020 at 8:31 AM
    Rastopher
    Rastopher Well-Known Member
    Ras
    Sacramento, Ca
    2002 2.7 4x4 reg cab automatic
    Utility Shell, Ultra 062 wheels, bilstein 5100, OME880 coils, wheelers progressive AAL, Whiteline LCA bushings, poly sway bar and steering rack bushings, led dash cluster, shifter bushings, 4runner mirrors.
    Swing by your local Safelite or glass shop. Tell them what you’re trying to do. Even if they dont have the glass in stock (they wont) they’ll know exactly where to look and can tell you what other vehicles have that glass. If you’re nice.
