New guy about to start a build
Discussion in '1st Gen. Tacomas (1995-2004)' started by ttran, Jan 9, 2011.
  1. Jan 9, 2011 at 2:06 PM
    ttran
    ttran [OP] Expert Mallcrawler
    Tim
    Cary, NC
    06 DCLB Prerunner Sport
    TRD Sport Prerunner
    Hey, I've been lurking around this forum for quite awhile and I'm going to pick up my truck tomorrow. I want to start building it up soon but would like some input. I'm planning on going with a 3 inch suspension lift at least, along with the biggest tire I can fit without cutting anything. I also would like to get a new set of wheels. I'm planning on getting it line x'ed asap as the previous owner lost the plastic cover for the bed. Any input or advice would be greatly appreciated.
  2. Jan 9, 2011 at 10:03 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    2002 XtraCab TRD 4x4 SCv6 AutoTrans With Lots of Mods ADS COs w/Compression Adjusters Camburg Uniball UCAs Whiteline Lower Control Arm Bushings Kartek 7" Limit Straps Plastics Guy Front Bumpstops Custom Alcan Springs +800 lbs +3" ADS 10" Stroke Triple Bypass w/Resi Rear Shocks Custom Rear Shock Relocate All-Pro U-bolt Flip w/Timbren Bumpstops 4.88 Nitro Gears ARB Front Locker ARB Twin Compressor Black 17x8 Konig Countersteer Type X 285/70r17 Falken A/T3w Gunmetal 16x8 SCS Ray10s 255/85r16 Maxxis Bighorns Limited Edition (Relentless) Elite Front Bumper Smittybilt X2O 10K Winch Diode Dynamics SS3 Sport Selective Yellow Fog Lights in the Bumper Diode Dynamics SS3 Pro 4,000 Kelvin SAE Driving Lights with Clear Lenses on the Bumper Morimoto D2S Projectors XB35 Ballasts + 4300K Bulbs Badland Sliders FrankenFab Tire Carrier Swingout bumper w/kitchen BudBuilt Front & Bellypan Skids BAMF Rear Diff Skid Dometic CFX 55im Fridge/Freezer Alpha II Hardshell RTT Badland Custom Bed Rack Denso 210-0461 105 amp alternator Dual Northstar 24F AGM batteries BlueSea 7622 ML-ACR Battery controller Peak DBI Dual Battery Voltage Monitor Magnuson MP62 Supercharger w/2.37" Pulley Haltech Elite 2000 Standalone ECU Denso 650cc Fuel Injectors Doug Thorley Headers Aeromotive Stealth 340 Fuel Pump TransGo A340F Reprogramming Shift Kit Magnaflow Hi-Flow CAT, Magnaflow 18" Muffler w/Vibrant Resonator 13WL Brake Calipers Braided Steel Brake Lines ScanGauge II OBDII Scanner Kenwood TM-71A Dual Band Ham Radio Larson 70CM/2M Antenna Uniden 520xl CB radio 3' Firestik Adjustable tip antenna Pioneer DEH-P9400BH HU Alpine Amps & Type R components (F) and coaxials (R) Wet Okole Seat Covers Weathertech Digital Liners Deck Plate Mod 1" Diff Drop Carrier Bearing Drop
    Welcome to TW Tim. Congrats on a great choice of vehicles. Good luck with your build.
  3. Jan 9, 2011 at 10:07 PM
    Max-4_Yota
    Max-4_Yota The Welfare Cadilac
    Michael
    South Carolina
    3rd gen Tacoma
    Chicken lights, chrome and smoke tunes.
    Welcome to TW! Do you know what lift your going with?
    Check out the Southeast region section
  4. Jan 9, 2011 at 10:08 PM
    01tacoprerunner
    01tacoprerunner 01 4WD Prerunner
    Brian
    Raleigh, NC
    01 4WD Prerunner
    Welcome to TW!! Im just above charlotte in Harrisburg!
  5. Jan 9, 2011 at 10:10 PM
    AzogSS
    AzogSS Well-Known Member
    Andy
    Soda City, SC
    2008 Tacoma / 2011 FJC
    Wheels are to your taste... I put FJ TRD 16" wheels on mine and put an OME 3" lift on the front and an AAL on the rear over the TSB springs. My recommendation is to look around at different builds and take what you like best from each. Good luck and welcome.
  6. Jan 10, 2011 at 5:10 AM
    ttran
    Tim
    Cary, NC
    TRD Sport Prerunner
    Thanks guys! This will be my DD and I won't be doing too much offroading. I was thinking of going with bilstein 5100's for the front with ome coils ( i don't know which one to choose) and what would be an acceptable set up for the rear? Another bilstein with an aal? I've done some searching but i'm still clueless. For a 3 inch lift, I would also need new uca's and a longer brake line right. Sorry for all the questions, I appreciate all the help I can get!
  7. Jan 10, 2011 at 6:20 AM
    goomba
    goomba It is a Fluid Situation
    Josh
    San Antonio Fl
    96 White Ex. Cab Tacoma TRD 4X4
    3" lift Up front(Donahoe Racing ext. travel coil overs, Camburg UCA's), 1.5-2" lift in the back(aal and some billy 10" stroke short bodies), Bushwhacker Cut-Out fender flairs, 16"x10" Procomp Street locks, and 305/70 Procomp X-Terrains.
    No break line unless you get relay long shocks. If you tow a lot I would get a aal in the back but if you do not blocks or shackles will do. You may need ucas but you may not need them, I did not but i still got them. If you go with blocks for the rear I would lift the front drive it like 1 mile so the front can settle, then measure and see what lift you need in the back.
  8. Jan 10, 2011 at 6:28 AM
    goomba
    Josh
    San Antonio Fl
    This is what my truck looks like. It has camburg UCAs(from wheelers), OME 881 coils(toytec), and 1" thick spacer(from wheelers). My tires are 305/70/16s(like 33/12.5/15s), too big for my lift. I have a body lift to fix it.
  9. Jan 10, 2011 at 8:17 AM
    ttran
    Tim
    Cary, NC
    TRD Sport Prerunner
    Nice Rig! I was looking at JohnnyGato's build and I love the wheels he has the pro comp 7005's. I would like to pair those wheels up with some 285's or 33's depending on which would require less cutting. I wouldn't be doing much towing at all, just the occasional off road adventure. I did some searching around and anything above 3 would require me to upgrade a bunch of other parts correct?
  10. Jan 10, 2011 at 8:28 AM
    goomba
    Josh
    San Antonio Fl
    Yes you have to get ucas if you go to 3.5" lift then past that you will have to buy a drop bracket type lift(procomp or fab tec 4 and 6" lifts).
  11. Jan 10, 2011 at 9:41 AM
    ttran
    Tim
    Cary, NC
    TRD Sport Prerunner
    Hey goomba, what kind of gas mileage are you getting?
  12. Jan 10, 2011 at 10:00 AM
    goomba
    Josh
    San Antonio Fl
    I think i am getting like 16 mpg with these tires, but be for I got like 19mpg. I will try to get back with you on that one.
  13. Jan 10, 2011 at 10:48 AM
    ttran
    Tim
    Cary, NC
    TRD Sport Prerunner
  14. Jan 10, 2011 at 6:48 PM
    goomba
    Josh
    San Antonio Fl
    Yes, you would need spacers. The tire will be hitting your uca if you put even 32s on there. If you want the tire to just fit with 33s you will need at least a 9" wide Rim with 4.5" bs. I would go to tirekingdom.com and look at moto metal 951s. They look like this:[​IMG]
    Alot of ppl run these
  15. Jan 10, 2011 at 7:41 PM
    ttran
    Tim
    Cary, NC
    TRD Sport Prerunner
    I was looking at those also, dang I can't make up my mind. Either get a nice 3 inch lift or save up and go for a 6 inch. Or settle with something right in between
  16. Jan 11, 2011 at 6:53 AM
    goomba
    Josh
    San Antonio Fl
    You could also do a 3" suspension and 2" body(total of 5" lift) which I will be doing. For the body lift you will have to extend your gas fill line and your air conditioning low pressure line. To extend the the ac low pressure line you will have to take it to a mechanic to get the freon professionally drained so you do not ruin your ac unit.
  17. Jan 11, 2011 at 6:55 AM
    ttran
    Tim
    Cary, NC
    TRD Sport Prerunner
    hmm, don't body lifts make the truck look a bit weird? with that gap being there and all
  18. Jan 11, 2011 at 8:01 AM
    goomba
    Josh
    San Antonio Fl
  19. Jan 11, 2011 at 8:43 AM
    ttran
    Tim
    Cary, NC
    TRD Sport Prerunner
    honestly it looks pretty good imo, body lifts are pretty cheap right? how difficult is the installation though
  20. Jan 11, 2011 at 9:11 AM
    goomba
    Josh
    San Antonio Fl
    Yes my 2" body lift was like $170 including tax and shipping. Installation is not too bad, I only have experience in a 4Runner 2" body lift though. I have had my 2" body lift for a wile just have not wanted to drain freon out of my ac system(do it professionally or else you will destroy your ac compressor). When you do the body lift you have to extend radiator drop brackets, bumpers(the one I got has the front bumper bracket, I will have to fab up a rear bumper bracket to lift up my rear bumper), steering shaft, low pressure ac line, and gas fill line.
