New guy needs URD maf calibrator help
Discussion in 'Performance and Tuning' started by Goinmxn, Dec 7, 2014.
  1. Dec 7, 2014 at 9:42 AM
    Goinmxn
    Goinmxn [OP] Member
    Rappahannock Va
    04 SAS Double Cab
    3 linked, sas supercharged tons of armour
    I am a long time member on Pirate and TTORA and have posted this problem at TTORA to no avail. I have a 2004 Tacoma, that is supercharged with URD's 6 injector fuel upgrade kit. I installed the supercharger and fuel mods in 06 and have had no problems until now. So I have the URD fuel timing calibrator and the maf sensor calibrator. The truck will randomly stall, like the key was turned off, that quick. Sometimes it starts right back up, sometimes it takes 5 or 6 tries. Sometimes it will run great for a couple hours. I had it at toyota and they said all sensors were within factory specs during testing and they feel it is one of the urd units. I always get maf codes with occasional lean bank codes when it stalls. I have been messing with this thing for 2 months and am fed up. Does anyone have any way to verify if the urd units are working properly? I have put 3 mafs in at this point as well. Thanks for any help. My afr shows a slight leaning out usually right before stalling, and when starting it seem really rich based on exhaust fumes, (before it goes into closed loop).
    Here is the truck
  2. Dec 7, 2014 at 9:50 AM
    sander1036
    sander1036 Well-Known Member
    Snack Food Capital of the World
    02 SR5 TRD Double Cab 4x4
    THULE Roof Rack, Color matched grille w/ GrilleCraft, Toytec Ultimate, 33 x 12.5 Duratracs, Bushwacker Cut Out Flares, Cvt Mt Shasta, Cvt Awning, LEER Cap
  3. Dec 7, 2014 at 11:50 AM
    tfeltz73
    tfeltz73 That's greasy Ricky
    central Wisconsin
    2013 supercharged long travel thing
    That truck is effing tits, and idk if this helps but my dad had a chevy that did the same thing and no one could figure it out until finally someone found the a cam shaft sensor was junk, once that was fixed it never did it again. I'm not a mechanic but it could be something like that. I have had my maf calibrator on for a few months with no problems at all.
  4. Dec 7, 2014 at 3:08 PM
    tooter
    tooter play every day
    Greg
    Los Angeles
    2012, std cab, 5 lug, 2.7, 5 speed
    Built for maximum low end torque, tooter II.VII intake manifold spacer, LCE long tube header, Injen long tube intake, 2,900 rpm torque peak.
    If I was to hazard a layman's guess...
    ...it might be an intermittent electrical connection. If you are always getting a MAF code upon stalling, it's a good indication of either an intermittent broken communication link between the MAF and the ECU, or an intermittent loss of power to the MAF. Wiring that vibrates on the running engine would be the most suspect since the motion could make the failure random.
    It makes sense that everything would work fine at Toyota because your truck isn't in motion and bouncing around.
    Do you ever get just an engine stutter, but not an outright stall?
    Does it stall out more in off road conditions than on road?
  5. Dec 7, 2014 at 4:35 PM
    Goinmxn
    Goinmxn [OP] Member
    Rappahannock Va
    04 SAS Double Cab
    Thanks for the replies and compliments. The truck will stall sitting perfectly still after sitting there idling. I did continuity test on all the sensors, and no apparent breaks. I paid close attention to all my connections to the URD ftc and maf calibrator, they are soldered, and heat shrink covered then zip tied to prevent movement. I am going to give gadget a call tomorrow and see if he can test the units. URD is not far from here.
  6. Dec 7, 2014 at 5:02 PM
    tfeltz73
    central Wisconsin
    And idk if you have a boost gauge or not but my truck was at about 5 psi before the maf and now it's at about 6.5 psi, so that's how I can tell it's working for at least performance wise.
  7. Dec 8, 2014 at 7:01 AM
    Vassily28
    Vassily28 Well-Known Member
    Quebec, Quebec, Canada
    11 TRD SPORT 4x4 Quadcab LB
    TRD supercharger with 2.85" URD stealth pulley and OEM FPR mod. URD fuel pump upgrade, URD TB plate adapter 70mm, FJ/4 runner 70 mm Throttle body, URD exhaust cam gears URD performance thermostat TRD CAI 1st gen. with custom cover (coupe), ProDry S + Filter skin, Doug thorley long tube headers, URD spec U exhaust Icon LT 2.5 front coilover, Timbren front bumpstops, Total Choas UCA, Deaver custom leafpack 3 inch. lift, Icon 2.5 VS series rear resishocks, Timbren rear bumpstops, ARB front bumper with WARN 8500 lbs winch,Hella 500 blackmagic, AVID rear bumper, Allpro front IFS skid + Trans. skid + Transfercase skid. Total chaos LCA skid, SS braided brake line, URD O2 sims, URD MAF controller, Wetokole front seatcovers, Innovate MTX-L, MTX-D AFR and boost gage.
    Sorry but i dont think the MAF can affect the pressure produced by the SC. May the timimng calibrator but not the MAF. The air temp will affect the pressure.
  8. Dec 8, 2014 at 9:00 AM
    Ostrichsak
    Ostrichsak Don't taze me bro!
    Jer
    Northern Colorado, USA
    Supercharged '10 Tacoma 4x4 TRD
    TRD Supercharger + too much stuff to list. Click sig pic
    What you've described sounds more like a fuel pump than anything. It could be some electrical short causing it somewhere along the line but the culprits sounds like a bad fuel pump to me based on what you've said here.
  9. Dec 8, 2014 at 11:11 AM
    Vassily28
    Hey by the way, love the camo look of the truck. Looks like in WOT (World OF Tanks), or World Of Tacoma.:D
  10. Dec 8, 2014 at 5:04 PM
    Goinmxn
    Goinmxn [OP] Member
    Rappahannock Va
    04 SAS Double Cab
    Brand new fuel pump is installed. Weird story, I had a brand new pump from a yamaha waverunner (2008 fxho) that was exactly same as walbro, same flow, same plug, looks just like oem, but better built honestly. So I stuck it in, works perfect. I checked and the fuel pump is still running and getting signal until shortly after the truck stalls. I know its not a lack of fuel issue. I am having a hell of a time getting my laptop to connect to my ftc, you guys have any suggestions? I does the red countdown then says check my connection and ecu power. I have checked ecu power, it is good. I am going to play with it tomorrow again and see if I can retrieve my maps I spent so much time tuning.
  11. Dec 8, 2014 at 5:10 PM
    Goinmxn
    Goinmxn [OP] Member
    Rappahannock Va
    04 SAS Double Cab
    It isn't only a mall cruiser just in case you guys were wondering....
  12. Dec 9, 2014 at 5:36 AM
    Vassily28
    If your FTC is like the MAF controller, you have to identify the port and sometimes it can be difficult. So 2 choices look in the system of your computer and check which lpt port is activated or try each of them trough your FTC panel.
    Oh sometimes if you use a USP-serial converter, the converter can be the problem. So check if your cable working with the MAF.
  13. Dec 9, 2014 at 1:46 PM
    StAndrew
    StAndrew Wait for it...
    Hampton Roads, Va
    SR5 4x4TRD
    Intake, exhaust, lift. Typical stuff.
    You talk to Gadget URD? I recommend you remove it and sell/return it. While you CAN tune with the MAF when boosting, a MAP is much more effective. Get a piggy back tuner with a MAP sensor and tune with that and you will see much better power returns (and you wont have to deal with the current BS :p). You only use the MAF for low engine speed/idle tuning.
    This guy has an AEM FIC for sale at $270. You can tune the extra injectors, etc...
    I wired mine up and can give you the wiring scematic, its pretty easy. Ill have to find where I got my patch extension harness.
    Or you can get a plug in play boomslang harness: http://www.boomslang.us/aem-fic.php
    OR
    http://www.tokensolutions.net/toyota-truck-4runner-aem-fic-pnp-harnesses-aem-fic-optional/
  14. Dec 9, 2014 at 5:45 PM
    Goinmxn
    Goinmxn [OP] Member
    Rappahannock Va
    04 SAS Double Cab
    St. Andrew,
    Im interested, how quickly can I get this up and running? I don't mind picking up the harness pre made, and if I can get more out of it I'm all for it. Whats involved in tuning?
  15. Dec 10, 2014 at 4:50 AM
    Goinmxn
    Goinmxn [OP] Member
    Rappahannock Va
    04 SAS Double Cab
    What do you guys think as to performace, AEM FIC vs urds fuel timing calibrator with the air fuel ratio calibrator combined. I have spent many hours tuning my maps with urds ftc and am happy with the results, but I believe the ftc is bad, and thats $400 plus to replace. If the FIC is better I will do that. Thanks for the input guys.
  16. Dec 10, 2014 at 11:00 AM
    StAndrew
    Hampton Roads, Va
    SR5 4x4TRD
    If you have the AFR and fuel controller, the FIC won't net you much more. The FIC incorporates all tuning functions (except timing advance, can only retard) as well as the MAF calibration as well. Where the FIC excells is the MAP sensor with is much better for tuning boost than a MAF. In fact, the MAF tuning function is just to cap the MAF voltage to the ECU as high boost can sometimes throw a code due to high MAF voltages.
    For $400, AEM FIC def a better option.
    As far as tuning, its pretty much the same as the URD tables.
    Overview:
    https://www.youtube.com/watch?v=zIlHRTwEf0U
    Gauges
    https://www.youtube.com/watch?v=TqXa2bZLccM&list=UUAtvmuAESsvUPIIUqolbjdg
    Tables:
    https://www.youtube.com/watch?v=VX8-BrylebQ&list=UUAtvmuAESsvUPIIUqolbjdg
    O2 Tuning:
    https://www.youtube.com/watch?v=GZNDCT9UjQQ&list=UUAtvmuAESsvUPIIUqolbjdg
    MAF Cap (I can give you my table if you want):
    https://www.youtube.com/watch?v=9MwDfmGWJzw&list=UUAtvmuAESsvUPIIUqolbjdg
    Bad ass truck btw, you need a build page. Not a huge fan of "camo" paint but digging your look.
  17. Dec 10, 2014 at 11:10 AM
    Rons01TRD
    Rons01TRD Well-Known Member
    Ron
    Virginia Beach, VA
    2007 4Runner 4WD
    Also my truck would stall out at times, I checked everything as well and mine finally popped a CEL calling it a bad TPS (Throttle Position Sensor) The resistance will read good until it finally fails completely. Something to keep in mind after you finish with all of your other troubleshooting and you still can't locate the problem.
  18. Dec 11, 2014 at 5:30 PM
    Goinmxn
    Goinmxn [OP] Member
    Rappahannock Va
    04 SAS Double Cab
    Thanks for the info, and the compliment. I'll have to find my build thread on pirate. It was 2006 when I did it I think.
    2 things, I was able to log into my fuel timing calibrator and look at my fuel table and timing table. They both are fine. Now the truck has developed a pattern. It will start and run fine, holding idle at 14.7/1 fuel ratio no signs of problems. Once it warms up, it stalls. The air fuel ratio drops to 10.0/1 area before it stalls, so its dumping fuel. If I hold the gas down it will sometimes stay running, but it wont rev past 3k, almost like bouncing off a rev limiter, then other times it wont stay running or restart until it cools. I double checked all my ftc and afr calibrator connections today, no cold solder joints. All is good.
  19. Dec 12, 2014 at 9:59 AM
    StAndrew
    Hampton Roads, Va
    SR5 4x4TRD
    Did you remove your MAF calibrator? Its a waist of time, just return/sell it. If that doesnt fix your issue, could be a tuning issue.
    Its hard to tune the bigger injectors which is why the 7th injector kit is recomended.
  20. Dec 12, 2014 at 11:01 AM
    Ostrichsak
    Jer
    Waste of time based on what criteria?
    If you're running rich how is a 7th injector going to help you lean it out?
