New Head Unit backup camera question
Discussion in '2nd Gen. Tacomas (2005-2015)' started by FrozenNorth, Apr 23, 2018.
  1. Apr 23, 2018 at 7:15 PM
    FrozenNorth
    FrozenNorth [OP] New Member
    I have a 2009 SR5 Access that I would like to put in a new head unit for a bigger screen and backup camera. I was looking on Crutchfield’s website for a Nav/DVD/Backup combo but they told me i would have to also get a new camera for the units to work. My question is: has anyone made the change and if so was there a camera that swaps out so you can use the same tailgate setup and space? Thank you.
  2. May 13, 2018 at 9:27 AM
    sbates
    sbates Well-Known Member
    NJ
    2011 Tacoma TRD Sport Double Cab
    Extang Tonneau Cover, aFe Pro Dry S air filter, Weathertech Floormats, De-badged, Plasti dipped Toyota emblem black, Plasti dipped a/c control panel black, 48-led Dome Light, Tailgate Damper,
    Interested in this as well as I'm not sure a new HU can tap in to the existing camera wiring. Following thread.
  3. May 13, 2018 at 12:16 PM
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    The OEM camera can be made to work with an aftermarket head unit. Problem is the connectors, the Toyota camera connector is proprietary while the aftermarket deck uses a standard video RCA unit. Just need to cut and wire a new connector.
  4. May 13, 2018 at 6:32 PM
    Purpleman
    Purpleman Well-Known Member
    Anaheim
    15 PreRunner
    You can possibly retain the OEM camera, If you can find its harness in the cab.
  5. May 13, 2018 at 6:45 PM
    ace96
    ace96 Well-Known Member
    Western KY
    '11 SWB DC TRD SPORT
    AVS bug deflector, Weathertech digital fit floor mats, TRD skid plate w/ Sockmonkey decal, SOS Cocept sliders w/ Line-x, Pioneer 3500, Hybrid Audio Technology Mirus 6X9s & 6.5s, back up cam mod, Wet Okoles-front & rear, TRD exhaust, 17X9 XD Spy w/ Falken Wildpeaks, Avid light bar
    Yes, you can tap into the factory camera with an aftermarket head unit. There was a forum member on here by the name of nimrod or something like that. He made the harness. Pretty much plug and play except for one splice.
  6. May 14, 2018 at 6:28 AM
    pastorman
    pastorman Member
    Jeff
    2017 Tacoma TRD Off Road
    I put in a Sony XAV-AX100 with CarPlay into my 2009 Tacoma. It has the camera on rearview mirror. I was able to tap into existing camera. Ordered the unit from Crutchfield and it came with instructions on how to tap into the tailgate camera
  7. May 14, 2018 at 6:56 AM
    FrozenNorth
    How did you find the camera wiring? Meaning where did you tap into the wires to connect to the head unit? Thanks.
