New hitch is loose in receiver
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 58LesPaul, Feb 22, 2017.
  1. Feb 22, 2017 at 8:30 AM
    58LesPaul
    58LesPaul [OP] Well-Known Member
    Jeff
    Kentucky
    2013 Tacoma TRD Sport 4x4 DCSB
    2" Lift
    I bought a hitch for my truck and it has play in it both left to right and up and down. Is that an issue or is that normal?
  2. Feb 22, 2017 at 8:31 AM
    Aw9d
    Aw9d That one guy
    Normal. At least all of mine are a bit loose.
    Alexely999 likes this.
  3. Feb 22, 2017 at 8:36 AM
    08tacobear
    08tacobear Well-Known Member
    08 taco DCSB pre runner V-6 SR5
    12v accessory plug right rear bed bin,1gallon air compressor setup in left rear bed bin, 3-window bed topper.
    Normal. Annoying but normal. I cut Bike tire (the 18 speed skinny tire type) down the middle of the threads and then in two inch strips and stuck in around the spaces
  4. Feb 22, 2017 at 8:37 AM
    OffroadToy
    OffroadToy pull my finger
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Piaa driving lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    Snug it up with duck tape... problem solved.
  5. Feb 22, 2017 at 8:38 AM
    08tacobear
    ^^^^^THIS!!
  6. Feb 22, 2017 at 12:17 PM
    Kerrigan911
    Kerrigan911 Well-Known Member
    Dan
    05 TRD OR, AC, 4x4, V6
  7. Feb 22, 2017 at 12:30 PM
    Nate-O
    Nate-O Well-Known Member
    Nate
    PreRunner
    Exact same thing I did with a cargo carrier.
  8. Feb 22, 2017 at 1:48 PM
    ABNFDC
    ABNFDC Well-Known Member
    Granite State
    2008 4WD Access Cab TRD OR "Rugged Trail"
    265/75/16 Wildpeaks, Dakar rear, HS 2.5" front coils
    That is what I do. I'll also coat the hitch and pin with a thick grease to help prevent things from rusting together.
  9. Feb 22, 2017 at 1:51 PM
    medic2230
    Murph
    Bama! Roll Tide
    I can't hear it from where I'm sitting in the truck. :anonymous:
    LOLLY and cliffyk like this.
  10. Feb 22, 2017 at 2:42 PM
    cliffyk
    cliffyk Well-Known Member
    Cliff
    Saint Augustine, FL
    2009 DCSB SR5 TRD Sport 145k miles
    Yup, we've been towing for 45+ years and have never found it a problem...
  11. Feb 22, 2017 at 5:04 PM
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    Better that have into hammer it in because of the rust.
    91859706 likes this.
  12. Feb 22, 2017 at 5:07 PM
    Bishop84
    Bishop84 Well-Known Member
    No play would mean it would seize in and have a hell of a time ever getting it out.
    I like the duct tape idea.
  13. Feb 22, 2017 at 8:50 PM
    kn61408
    kn61408 Retired old fart
    western washington
    09 PreRunner DCLB sport pyrite mica
    12v always on power point mod, tailgate anti-theft, Addl bed tiedowns, flyzeye dash lights, map lites with dome lite mod, bed stiffeners, air bags, brake controller, always on fog lights,
    I tapped a wood shim into both sides and broke it off. Holds up well and still makes the hitch easy to take out.
  14. Feb 23, 2017 at 4:59 AM
    maineah
    Tim
    Maine
    4X4 SR5 V6 6spd
    It's a non issue looking for a problem that does not exist. Any thing you stick on or in the hitch will soon ware out.
  15. Feb 23, 2017 at 6:03 AM
    badger
    badger Well-Known Member
    07 SR5
    It doesn't hurt anything, but the clanking can be annoying. I drilled and tapped a hole in the top of my hitch for a 3/8 bolt with a lock nut. Slide in the hitch, tighten the bolt, tighten the locknut,...no rattling. You can also use it as a snugger, and just set it so the hitch barely slips in. That alone takes out most of the clanking.
  16. Feb 23, 2017 at 6:08 AM
    ejl923
    ejl923 Well-Known Member
    Eric
    Western Mass
    15 DCSB TRD Off Road
    agreed its not that big of an issue, but can get annoying if you have a bouncy trailer. I've had a piece of reinforced neoprene gasket on my hitch for seven years, still hasn't worn out.
  17. Feb 23, 2017 at 7:33 AM
    hobiecat111629
    hobiecat111629 Well-Known Member
    2015 Tacoma Access Cab
    Pretty normal, but it the weight of the trailer seems to keep it quiet.
    I had one rust itself into the receiver on my last truck and spent two hours with PB Blaster and an 8lb sledge getting it out. I've since learned to ALWAYS take it out when not in use.
  18. Feb 23, 2017 at 7:39 AM
    ejl923
    Eric
    Western Mass
    i spray the occasional fluid film in there. Sidenote: fluid film has become my new best friend in the snowblower chute
    File IFR likes this.
  19. Feb 23, 2017 at 8:01 AM
    anonemoose
    anonemoose Well-Known Member
    Bill
    Big Pine, Calif
    2015 White TRD Sport V6 DCSB
    Ride-Rites, Everything Weather-Tech Makes Added some 12 volt outlets with relays
    You buy something like this for $29.99 or get a muffler clamp from an auto parts store for a $1.99 - lighter trailers do travel better with less wiggle, larger/heavier one not much improvement.
    BugSpatteredJacket likes this.
  20. Feb 23, 2017 at 8:22 AM
    nh_yota
    nh_yota Well-Known Member
    Jeff
    Portsmouth, NH
    2010 DC V6 TRD-OR 6-SPD
    2" Lift with HS coils/AAL and 5100s, TRD Exhaust, TRD Skid Plate, URD Short Shift, AT3s
    A few wraps of electrical tape will fix it cheap.
    BugSpatteredJacket and File IFR like this.
