New Holster set up using the POS XD Holster
Discussion in 'Guns & Hunting' started by larz, Mar 28, 2010.
  1. Mar 28, 2010 at 11:50 AM
    larz
    larz [OP] Member
    Kennesaw, GA
    '10 DCLB TRD SPORT PRERUNNER
    Holster
    Ever wonder what to do with the POS holster that comes w/ your fine XD handgun? Well I've figured with the height of center console I'd be able to have a full size hand gun up-right in it. The following pictures are what I did.....First I got 8" cable ties and 1" X 1" adhesive cable 4-Way mounts. They are rated for 75 lbs tensile so it should be strong enough. And of course the POS holster that comes with the XD.
    Drill a hole about 7/32 on the bottom/center of the Holster. Also, I'd loosen the allen screw on the holster so that the fit is not too tight.
    Then loop 2 cable ties and the 4-ways on the top of the belt-loop rails and 1 on the bottom looping it through the drilled hole. This will give you stability both horizonally and vertically. Pull the cables tight and make sure that the mounts are flush.
    Place the gun in holster (UNLOADED!!) and kind of line it up where you want it. I have a Service and Sub-Compact and I set it up using my Service so I could use both if I wanted. My front of slide of the service almost touches the bottom....I put a small writing tablet (3/16") under it so it would give me a little space.
    Then take off the backers on the pads and press hard against it to make sure its secure.
    Picture looking down.
    Picture of side view.
    From the back seat.
    I suppose you could do this using similar guns/holsters....you'd just have to modify it based on the holster.
    I played with the set up a bit and it works pretty good....with the way you sit it's almost like having it on your side.
  2. Mar 28, 2010 at 11:55 AM
    Brunes
    Brunes abides.
    Rotorhead
    Rep for ingenuity!!
  3. Mar 28, 2010 at 11:56 AM
    Anathollo
    Anathollo www.saveadane.org
    Houston
    07 Tacoma TRD Sport
    Icon coilovers, Rear Fox Resi-shocks, 285/70/17 Toyo A/T's, Touchscreen JVC Headunit, Custom Rhino-lined sub box, Rocksford Fosgate components and Dual Rockford Fosgate 10" shallow subs, Pioneer and Rocksford Fosgate amps, 1250 watts total, Autometer Volt and Trans gauges with Lotek A-pillar, K&N Drop-in filter, WO Seat covers, Tint, NST WP pulley, Hi-lift jack, Diff breather mod, horn relocation mod, extra "D" rings, de-pinstriped, carrier bearing drop, Rear backup 886 bulbs, Camburg UCA's, AMW Catch can, BHLM, OME Dakars with AAL, Procomp 7089's, Front single hoop Demello bumper, Superwinch Tiger Shark 9500, Amsteel 3/8th synthetic line
    Nice!
    +rep
  4. Mar 28, 2010 at 5:50 PM
    Packman73
    Packman73 ^^^^ 3%er ^^^^
    The free state of Arizona
    2007 TRD Off Road
    Bilstein 5100's (front set @ .85"), OME 885's, chris4x4 anti-Taco-lean spacer on driver's side, Total Chaos UCAs, Rear Leaf Spring TSB, Toytec AALs, Black FJ TT Wheels, BFG 285/75R 16 AT Tires, TRD Exhaust, Viper Alarm, Fog Light Mod, De-badged, Blue LED Dome Light, EZ Clamped Tailgate, Wet Okoles, Satoshi Grill, 5% Tint, Engine Tick Fix, Black Rear Bumper, Black Center Valence, Exhaust Cut At Axle, Thanks for all the help chris4x4!
    I used my wife's XDgear POS holster in her closet up high so she can grab it quick. We hang a cowboy hat on it and no one knows it's there. I carry mine on me at all times so I don't need or want a mount in my truck.
  5. Mar 29, 2010 at 6:30 AM
    Zombie Runner
    Kevin
    Wichita Falls, TX
    2011 taco, sport 4x4
    oil change...
    Sweet man! I had been thinking about putting that shitty holster somewhere in my truck.
  6. Mar 29, 2010 at 6:49 AM
    Slimwood Shady
    Slimwood Shady I love your mom!
    Linwood
    Hampton, VA
    '17 Tundra; '16 Odyssey; ;14 A4
    ok, I may be the dumbest person here, but..where did you connect the zip ties to? Did you drill holes in your console?:notsure:
  7. Mar 29, 2010 at 7:07 AM
    centraltaco
    centraltaco Well-Known Member
    Central, Louisiana
    '10 Dub cab 4x4
    That is a nice set up. I am going to have to try something similar. Mine just rattles around in the console right now.
  8. Mar 29, 2010 at 9:21 AM
    larz
    larz [OP] Member
    Kennesaw, GA
    Holster
    You are....J/K....drill a hole in the bottom of the the belt loop and the other two around the vertical rails (this view is looking at the bottom)....maybe this larger pic will help.....
    don't drill your console.
  9. Mar 29, 2010 at 1:14 PM
    Slimwood Shady
    Linwood
    Hampton, VA
    Ah ha, Got it. I thought that the stickies where just some sort of double sided tape! I got it now.
  10. Mar 29, 2010 at 2:48 PM
    kiddwvman
    kiddwvman Well-Known Member
    leon
    WV
    06 4 banger
    weathertec floor liner,tinted windows,bilstein 5100 front .85,5100'S rear,window vents,K@N air filter
    hell yes :headbang:
  11. Mar 29, 2010 at 7:40 PM
    NraFan
    NraFan Join the NRA! Protect your freedom!
    JT
    SoCal
    2011 Sienna LE, rockin the mini van!
    Power sliding doors baby! WooHoo!
    Nice setup. I'll be looking to something similar with my glock and a cheap kydex holster.
  12. Aug 21, 2012 at 4:28 PM
    pmo
    pmo Well-Known Member
    Nova Scotia Canada
    2007 Tacoma 4x4, DC, 6 Speed Manual.
    quick question guys....why do you need to carry a handgun?...just wunderin'
  13. Aug 21, 2012 at 8:51 PM
    Ostrichsak
    Ostrichsak Don't taze me bro!
    Jer
    Northern Colorado, USA
    Supercharged '10 Tacoma 4x4 TRD
    TRD Supercharger + too much stuff to list. Click sig pic
    Because I can't fit my AR15 under my t-shirt.
    Ask a stupid question...
  14. Aug 21, 2012 at 9:22 PM
    WhatThePho?
    WhatThePho? Greg Graffin 2016
    Andre
    HCMC, VN
    2006 STi
    The things required to pull bitches
    They don't make a holster big enough for cops.
  15. Aug 22, 2012 at 5:43 AM
    larz
    larz [OP] Member
    Kennesaw, GA
    Holster
    Quick question....why do YOU think we would need to carry a gun?
  16. Aug 22, 2012 at 6:06 AM
    Zombie Runner
    Kevin
    Wichita Falls, TX
    oil change...
    derpppp
  17. Aug 22, 2012 at 9:28 AM
    PRBulldog36
    PRBulldog36 Well-Known Member
    Juan
    San Antonio, Texas
    2006 PreRunner SR5 TRD Off Road
    Bilsteins 5100's X4 front set at 2.5 and rear AAL,BFG Rugged Trail T/A P265/65R/17, Warrior 375 17X8 Wheels with Gorilla locks,Black Billet Grille top and bottom and replaced Toyo emblem with Dallas Cowboys Star by MetalMiller, Vent Shade window louvers and hood bug shield, Fog light anytime mod,Dome light Mod,Blue interior LED's, Six inch Black Chrome billet antenna,Firestik CB Antenna, Cobra 75 CB, 12Vt/DC outlet back of Center Console, CB external speaker, Sirius Satellite Radio, Westin tube step up bars (Chrome), Tinted windows (legal), Eyebrow on windshield (Limo),Leather arm rest mod,HID H4's(fog), HID plug and play 8000, Tailgate theft prevention mod and Tailgate Pop-n-Lock, Trailer hitch brake light,Garmin GPS Dashboard Mount, Baja Lights on the rear bed rail, In Bed Mt Bike carrier, Tail gate extender, N-Fab light bar with Four Hella 500's, Fold down antenna,WeatherTech digital floor mats, mount,Kenwood head unit, Polk Audio 6X9,Two 12 ' Subs MTX, Kenwood Excellon 5 1/4, Ke
    NICE JOB ! I guess I'll have to get mine out of the closet and get busy.
  18. Aug 22, 2012 at 10:19 AM
    Rmodel65
    Rmodel65 Yukon Cornelius
    Jawja
    1996 Yota 4x4
    Viper Red paint
    well when youre a free man you get to do things...but i guess your sovereign the crown doesnt trust you?
