New JVC Install...
Discussion in 'Audio & Video' started by sac130e, Mar 9, 2011.
  1. Mar 9, 2011 at 1:39 PM
    sac130e
    sac130e [OP] Well-Known Member
    Scott
    Milton, FL.
    11' TRD Off-Road 2wd
    JVC Nav. System and entire Memphis Audio Speakers/Amps
    Just ordered the JVC KW-NT3HDT kit from Crutch and looking for advise on self install or a pprofessional. I am comfortable doing this, just don't want to get in over my head and have to find a dealer to fix my mess.
    This will be with the sterring wheel control/BT and navigation wiring...
    Any help and advise greatly appreciated on getting this done.
    Thx
  2. Mar 9, 2011 at 3:09 PM
    01Tac0ma
    01Tac0ma Bash Fabriction & Off-Road
    Chad
    West Columbia, SC
    SAS 01 TRD 4x4
    Look at build!
    Should be pretty much plug and play, and pretty simple, Someone will chime in that has done this.
  3. Mar 9, 2011 at 3:23 PM
    Daudio
    Daudio Well-Known Member
    North Jersey
    '02 SR5
    avic-d1 sirius tuner Ipod adapter
    it all depends on your knowledge on 12+ electronics. It is not a hard install at all if you have even a little bit of experience in the area. If you aren't 100% confident then I would not try it. A good car audio shop shouldn't charge you more then $100-$150 to install everything, but if you try and fail it will cost you more. My companies policy is if its a fresh install its a set price, but if someone tries it first and doesn't complete it we charge $50 to uninstall everything and bench test everything then the initial charge to install it assuming nothing was damaged by the customer...You may have some luck asking someone on here that can help you, a lot of these guys will help you out for some beers and a few slices.
  4. Mar 9, 2011 at 4:53 PM
    01Tac0ma
    Chad
    West Columbia, SC
    SAS 01 TRD 4x4
    Look at build!
    ^ Bam. If your second guessing just take it somewhere and have it done, then you wont have anything o worry about.
  5. Mar 9, 2011 at 6:48 PM
    sac130e
    Scott
    Milton, FL.
    After seeing the threads here on install, I think I can handle this..just some questions:
    I have the steering wheel controls and ordered the Metra Axxess ASWC Universal Steering Wheel Control Interface..is this easy to install..any threads going over this here?
    Where does everyone stick the GPS attenna..I don't want it outside the vehicle, so looking at the dash in the corner..does this interfer with reception?
    As for the BT mike..anyone able to route to the overhead near the lights without any issues?
    I am guessing since this HU has the usb on the front, I don't need the IPOD cable during the install since there are no connectors for it on the back.
    Thx
  6. Mar 9, 2011 at 7:19 PM
    sac130e
    Scott
    Milton, FL.
    Does anyone know if the scoche faceplate from Crutch is textured silver or just smooth silver. I would like to keep the textured look that came with the truck.
    Thx
  7. Mar 10, 2011 at 1:09 PM
    sac130e
    Scott
    Milton, FL.
    Has anyone hooked there OE backup cam to there new HU?
    Was it hard..did you have to pull the wire from the rear view mirro and rerun to the HU?
    Thx
  8. Mar 11, 2011 at 3:06 PM
    sac130e
    Scott
    Milton, FL.
    Anyone....
  9. Mar 11, 2011 at 6:45 PM
    uood8
    uood8 If You Search...You Shall Find.
    Greensboro, NC
    '16 Sr5 4x4 DCSB
    Pretty much stock
  10. Mar 11, 2011 at 7:00 PM
    907taco
    907taco Alaskan Assassin
    Bobby
    Alaska
    2010 BlackSandPearl 4x4
    ultimate lift kit ( toytec ) ome dakar leaf pack , w/ extended length billies, LR uca's, Pro comp 7089s, KM2's 285 70 17, neoprene seat covers, weather techs, CBI sliders w/kickout, URD ss, cab mount chop, VHT night shade tint>tails,3rd B-light. Debadged. Grillecraft grille, rear diff breather mod. CBI Moab front bumper, warn M8000 winch, HID kragens 7", Hella's micro fogs. retrofit headlights HIDS, LED solutions maps/license! 886 back up light mod,
    you can stick the gps behind the head unit, reception wont' be affected. not sure about the back up cam to head unit. sounds like plug and play to me. good luck
  11. Mar 11, 2011 at 7:13 PM
    sac130e
    Scott
    Milton, FL.
  12. Mar 17, 2011 at 9:01 PM
    Jerry Bear
    Jerry Bear Well-Known Member
    Jerry
    Mesquite, Texas
    2010 Access Cab
    tint, topper, receiver hitch, trailer wiring, topper lighting, cruise control, intermittent wipers, backup camera, auto-dim mirror
    Many have done it with their Pioneer HU, the link above in another post tells how. However, it won't work unless you already have the rear view mirror with back-up display. The mirror/display powers the back-up camera. The camera uses 6 Volts, not 12 Volts, so you can't just hook up 12 Volts to power it.
  13. Mar 18, 2011 at 3:46 PM
    acozzens
    acozzens Well-Known Member
    98056 , washington state
    06 4d 4wd trd sr5 silver
    Michelin ltx m/s WSU (cougs) License Plate Holder $1.99 Gate Theft Mod DIY HU install DIY SWI-JACK install DIY rear speaker & baffle DIY ipod audio/video interface DIY HD radio DIY Alpine pdx 5 DIY front components install DIY RedLine Tuning Gas hood lift ( very slick ) DIY slimcubby gb hid head/fog DIY extang trifold trifecta DIY dynolock tailgate lock
    Here are 6 Quick Tips off the top of my head.
    #1: kill the battery
    #2: Do 1 thing at a time, then Test. requires lot of battery un plug plug in, but it's worth it. 1 thing at a time man... otherwise you turn it on, something's Fukked and you don't know what it was. I know 1 dude that fried his shiz by not unplugging juice.
    #3: JVC Tip (I have kamelion Single Din) Get an extra wire, my JVC's have worked quite well grounding the ebrake (green) bypass.. That way you can illegally and dangerously have video on while driving. Run it down by driver's feet, there's some screws down there you can ground to
    #4: get some cable ties, gonna be a snug fit
    #5: if installing steering wheel interface. do that separate, see #2
    #6: Sound Deaden thangs for optimal performance. RAAMMat / ensolite is my choice
  14. Mar 19, 2011 at 1:09 PM
    sac130e
    Scott
    Milton, FL.
    Thx for all the help...next is speaker upgrade.
    For now I want to swap the door speakers with some new quality ones.
    Looking for clear sound with bass and want to be able to just pull the old ones and plug in the new ones. I will add sound deadner to the doors also.
    In the next 6 months I will and amps/sub and rewire, but for now just the doors. Budget for the doors speakers and install kits is 500.00.
    On another note..been looking at full kits from *********..any thoughts on these?
    Will the new door speakers be damages in any way running them off the new JVC HU and stock wires? Don't want to spend the money and have them damaged.
    Thx
  15. Jul 13, 2011 at 11:24 PM
    TROY
    TROY Member
    Puerto rico
    2011 tacoma trd sport
    no u dont!
  16. Jul 13, 2011 at 11:29 PM
    TROY
    TROY Member
    Puerto rico
